Results 1 to 24 of 24
Thread: Arch flash
    Apr 2019
    Arch flash
    I was welding today and I have to keep lifting my helmet up to see. I got flashed a few times and I was wondering if I should worry about my eyes? Is there like an extensive amount of time you have to be flashed before you get arch flash or can it be just a few short flashes? I'm an amateur at welding so this is why I'm asking.
    Thanks for the help.
    Sent from my Pixel 3a XL using Tapatalk
    Laredo + Midland/Odessa
    Re: Arch flash
    Quote Originally Posted by Destroyr72 View Post
    Should you worry about your eyes? Did you really just ask that.
    Stop lifting your helmet up while you're still welding. Seems simple enough. Perhaps I'm not understanding something that is getting lost in the translation. Please do explain why you have to raise your helmet while you are still welding. That part just makes no sense to me.
    Soda springs,Id
    Re: Arch flash
    If by lifting your helmet while welding could you see any better?? Probably not. Sounds like you have a filter lense problem or improper setting on an AD helmet. The painful part of arc flash is actually a sunburn on the surface of the eyeball and just like sunburn on skin takes a few hours usually overnite to heal. Retinal damage is also a possibility. You say your an amateur so I'm guessing you can't see because you're concentrating on the arc instead of the puddle and what's going on around the puddle. I know this sounds crazy but it's fact so try it.
    Ol' Stonebreaker
    Hobart G-213 portable
    Miller 175 mig
    Victor O/A setup
    Makita chop saw
    Re: Arch flash
    "Doctor, Doctor! It hurts every time I jam broken glass in my eyes!"
    "So stop jamming broken glass in your eyes!"
    Sep 2016
    Detroit, Michigan
    Re: Arch flash
    What kind of helmet are you using?
    http://mivise.com
    Hobart Champion Elite
    Everlast PowerTig 210EXT
    Re: Arch flash
    Minor flash feels like someone is pouring sand in your eyes in the middle of the night. Major flash you will have an eye patch for a week or so and could have potential eye damage. Yes to what helmet and what shade of lens you are using? On thin material the lowest you should go is shade 9 but generally shade 10 is the most common for general welding. Make sure the lens and cover plate are clean and not covered in smoke and spatter. If you still have trouble seeing a low diopter (1-1.50) cheater lens is better than going too low on the shade of lens. If you suspect a flash but aren't sure, it's always good to have a Dr. check to make sure you have nothing in your eye.
    Los Angeles
    Re: Arch flash
    Arc Flash is certainly a concern since you will experience discomfort like sand in your eyes.
    Couple arc flashes is not the end of the world.
    As others have mentioned, don't lift yer helmet.
    The shade function on a helmet is for comfort- they have general guidelines but each person is different.
    Even in a low shade setting you are protected from Arc Flash- you could actually use a clear shield and be protected from Arc Flash. You will have severely fatigued eyes though.
    Again, as mentioned- either get yer eyes checked for prescription or add more light to the area you are welding in so that you can see the puddle better.
    MM211 (Sold)
    Klutch 120v Plasma cutter
    Re: Arch flash
    Really? Never heard that one before! (Not sure I'd test it, either!)
    Re: Arch flash
    Wrong. You are protected from UV rays with the coating on some clear lenses. You are not protected from the brightness of the arc.
    Re: Arch flash
    A few times for most people will not have problem like cataract.
    I am 66 and do not have cataract
    But wait be for lifting the hood
    Los Angeles
    Re: Arch flash
    yeah, that's why clear safety glasses protect you while working around welding. (Besides keeping material out of yer eyes.)
    You are more likely to get Arc Flash/welder's eye being close to welding than actually welding.
    Your brain forces your eyes closed if you were actually welding since it is so bright but walk away a couple feet and you can still keep your eyes open letting in the harmful UV rays.
    MM211 (Sold)
    Los Angeles
    Re: Arch flash
    read what I wrote again.
    The shade protects you from the brightness.
    MM211 (Sold)
    Los Angeles
    Re: Arch flash
    and just so people UNDERSTAND....
    I did not say one SHOULD where a clear face shield , but it offers MORE protection than lifting one's helmet and having ZERO protection.
    MM211 (Sold)
    Los Angeles
    Re: Arch flash
    From Lincoln:
    Q: What is the correct lens shade to use in my welding helmet to properly protect my eyes?
    Vista Auto-Darkening Welding Helmet from Lincoln Electric
    A: Many people mistakenly think that the lens shade number corresponds to the amount of protection that is provided to the eyes and hence the higher the number, the better the protection. But in reality, all well-constructed quality welding lenses, have a screen that filters out 100 percent of the harmful ultraviolet (UV) and infrared (IR) wavelengths and provides protection to the eyes. The number just denotes the amount of darkness provided by that particular lens and should be used by operators as a guide to select the one that is most comfortable and yet provides good visibility for the particular application.
    Of course, there are some suggested lens shade numbers that you can use as a guide if you are unsure what to select for your application. These correspond with the amperage being welded. Always select a shade that allows you to see the weld puddle clearest and that most aids your welding ability.
    MM211 (Sold)
    Apr 2010
    Re: Arch flash
    Destroyr72
    . . . Is there like an extensive amount of time you have to be flashed
    before you get arch flash or can it be just a few short flashes? . . .
    Original post 01/19/15 - Arc eye!?
    You may be attributing two distinct phenomenon into one causality.
    For lack of proper medical terminology: I'll call the 1st an Optic-Flash,
    momentary blindness; and the 2nd - a Flash-Burn - the sand in the eyes feel.
    The first: you usually get from yourself as a result of a split-second fumble
    of a hood flip, lead snag, or a surprise from a co-worker. Instantly all you
    can see: is the big-white-light we all know.
    The Retina is the interior lining of the eye which transmits optic message to the
    brain; it has been over stimulated, and simply requires sometime to normalize.
    Repeated intense Optic-Flashes have been associated with retinal detachment,
    and the incident is slightly higher in near-sighted individuals [glasses?]. All we
    can do is to be careful.
    A Flash-Burn: the 'sand in the eyes pain' which is so celebrated, occurs when
    the Sclera - the white outer wall of the eye - gets sunburned. Unless you have
    painted the inside of your hood silver and placed a mirror behind you while
    welding you cannot get this from yourself. A Flash-Burn occurs from prolonged
    exposure to indirect, oblique light, typically from welding going on around you.
    Prolonged-exposure multiplies intensity. Portable welding shields are the simplest
    prevention.
    hth
    Opus
    Re: Arch flash
    You wrote " you could use a clear shield and be protected from arc flash. You would have fatigued eyes". Seems to me your saying a clear shield will protect you to some degree from the arc.
    Re: Arch flash
    I'm guessing the OP has a non-AD helmet.... and is re-positioning the rod to restrike... hence the lift-up of the helmet probably the OP is not very steady with hands or something???
    Jun 2008
    New Plymouth ID
    Re: Arch flash
    If you get burn you will know it you will not be wondering. I where standard prescription glasses under my hoood when welding with multiple operators and have Never been burned. But my brother will not weld without sunglasses inside his helmet because he has been burned so manytimes by weldors working around him. Took Him about 4 times to learn, Last time i thought he was going to have to go in tto the doc, took 2 nights before he could sleep.
  20. #19
    Jan 2011
    W. Wisc
    Re: Arch flash
    From Lincoln:
    Ed is correct. Auto dark lenses PASSIVELY protect the user from UV and IR. The shade setting represents how much of the visible spectrum gets through. As most know, the visible spectrum is the slice between UV and IR that we see in. Even if the lens is turned off, your eyes are protected from UV and IR, but not from visible light. If you light up an arc with it off, you will be seeing spots for sure and it isn't good for your eyes, but you aren't going to get a flash burn from the UV, for example.
    -Dave
  21. #20
    Re: Arch flash
    Bottom line is don't take chances with your eyes. You only get one set. Repeatedly getting flashed is not good for them and can lead to permanent damage.
  22. Likes G-ManBart liked this post
  23. #21
    Nov 2004
    Southern Montana
    Re: Arch flash
    Destroyr72
    Opus
    While the sclera may get "sunburned," it is most often the cornea that is burned/affected, due to, usually, extreme exposure to a UV producing source... hence, the gritty feeling. When an eye doctor evaluates the extent of corneal damage he/she introduces a drop of sodium fluoresceine dye to the surface of the eye. This chemical has the unique property to temporarily stain damaged corneal cells, causing them to glow bright green under innocuous, filtered UV light. The extent of cellular damage is then, easily, evaluated at the microscopic level by using a slit lamp (stereo microscope). Damage that is apparent shows up as tiny green spots, scattered across the cornea. A healthy, undamaged cornea will not absorb any of the dye... cool!
  24. Likes ronsii liked this post
  25. #22
    Re: Arch flash
    From Lincoln:
    OK, yeah. I've been (kinda) flashed when my Miller Digital Elite didn't work right. It was bright, but it didn't hurt like an actual arc flash.
    I thought you were suggesting that something like a clear plastic grinder face shield would protect your eyes from arc flash. Because I've been flashed wearing one of those by both UV (from welding arc) and IR (from O/A torch). In my experience, infrared from an O/A torch hurts more than arc flash.
  26. #23
    Los Angeles
    Re: Arch flash
    remember kids- You only have one set of eyes !
    MM211 (Sold)
  27. #24
    Feb 2010
    Bandera,TX / MN
    Re: Arch flash
    The great thing about IR is that you know its there. The bad thing about UV is that it does not show as dangerous. We build UV and IR ovens and the shielding required for UV is essential as your eyes don't register the danger like IR.
Page generated in 1,713,297,575.20368 seconds with 19 queries
