Results 1 to 23 of 23
Thread: Infinity cube
    Oct 2020
    Richmond, Canada
    Infinity cube
    Wish I had more time and used more clamps. But at least I got it done.
    Still need to do some cleaning with the grinder. But yup, definitely learned my lesson to use some good clamps and magnets and to get better mitre cuts with the chop saw.
    Sent from my Pixel 3 XL using Tapatalk
    Aug 2018
    'ta town, KS
    Re: Infinity cube
    I sell those with glass and painted black for $300... with a waiting list. Buy your clamps.
    Mac
  3. Likes N2 Welding liked this post
    Re: Infinity cube
    Very cool!
    I've got some 1-1/4" square tube that would work for it, and need an excuse to buy some Fireball squares.
    What dimensions did you go with? What are you going to do with it now?
    Jun 2008
    Re: Infinity cube
    I like.....hard on the head but zI like it
  6. #5
    Oct 2020
    Richmond, Canada
    Re: Infinity cube
    I went with this calculator here:
    https://everythingmetalandwood.com/p...ty-cube-table/
    17" on the long pieces and 15" on the short pieces.
    I am going to powder coat this black and add a glass top to it. Just trying to figure out how to mount it.
  7. #6
    Nov 2019
    North East Ohio
    Re: Infinity cube
    I too want make one. Looks great
    Mac how do you market your stuff? I'm tired of gym equipment (no money).
    If any one would share steel dimensions or any details
  8. #7
    Aug 2018
    'ta town, KS
    Re: Infinity cube
    My dimensions are 16 inches and 14 inches.. and my market has been word of mouth or a couple consignment shops near the house. I just shoot Chevy high gloss black on mine. Oriely's mixes it with the hardener cheap.
    I stole the idea from here and made the first one for my wife... ahem I got to play and she got a table.
    Mac
  9. #8
    Aug 2018
    'ta town, KS
    Re: Infinity cube
    Quote Originally Posted by Ch4p View Post
    Go to the hobby lobby or whatever home depot might sell them... but the sticky bubbles are what I use. Wife gets them for me when I need more. Sorry no help on that but I do know they are cheap.
    Mac
  10. #9
    Oct 2020
    Richmond, Canada
    Re: Infinity cube
    Thanks Mac.
    And I should also add. I used 1" square tube.
  11. #10
    Aug 2018
    'ta town, KS
    Re: Infinity cube
    I like 1.25... but 1.5 works well too... the tables in the house are 1.5. But they were also what I had when I started. 1 inch seems dainty to me. I know it will hold the load but I work with 2x to 12x at work too.. may be a bias
    Mac
  12. #11
    Nov 2019
    North East Ohio
    Re: Infinity cube
    Thanks Ch4p I did not see that before.
    Mac I will give it a shot.
  13. #12
    Jun 2016
    Texas Hill Country
    Re: Infinity cube
    M.C. Escher stuff right there! Well done.
    Is it for a table?
  14. #13
    Nov 2019
    North East Ohio
    Re: Infinity cube
    Quote Originally Posted by VaughnT View Post
    Very cool!
    Which Fireball clamps do you like most?
  15. #14
    Apr 2010
    Kenai, Alaska
    Re: Infinity cube
    ch4p,
    just as a note about the design part of this project; a small variation would be to have the lower most (floor foot) and the top most horizontal frames even with the outside of the sides? This would make each horizontal frame larger by a couple of tube sizes but...
    I think it would make for an interesting variation that would still be interesting to the eye?
    Cheers,
    Kevin Morin
    Kenai, AK
  16. Likes ronsii liked this post
  17. #15
    Oct 2020
    Richmond, Canada
    Re: Infinity cube
    Quote Originally Posted by Kevin Morin View Post
    ch4p,
    Cheers,
    Kevin Morin
    Kenai, AK
    That would be interesting, I might try that out that next chance I get to build one of these again.
  18. #16
    Jan 2015
    Martha Lake, WA
    Re: Infinity cube
    Question for those that have built one. What kind of deflection have you seen in use? I know square tube has a pretty good resistance to bending but figure the side opposite to the legs attached to the base must droop some with weight on the table.
    Edit - looking at the geometry again is it possible it compresses uniformly and acts like a spring so that the top stays relatively level under load?
    Tweco Fabricator 211i
    Sieg X2
    AMT radial arm drill press
    AMT belt/disk sander
    HF 4X6 bandsaw
  19. #17
    Aug 2018
    'ta town, KS
    Re: Infinity cube
    Tack the sides to keep it square until all sides are tacked together. Then weld it out. If you do the flats first then the inside fillets, and finish with the outside corners it stays square. And I haven't seen deflection if all pieces are tacked together before weld out, it does work against itself.
    If you try the inside corners first then you see the deflection and it is a pain to fix. But weight not really as 14 gage is plenty stout for most coffe/end tables.
    Mac
  20. Likes ronsii liked this post
  21. #18
    Jan 2015
    Martha Lake, WA
    Re: Infinity cube
    Thanks Mac - I'll use that sequence. I was also wondering about deflection/stability after it is built. If you put something heavy on a standard table the legs are pretty much equally in compression and the load is reacted by the base or the ground. With this design, the load is carried by bending so I was wondering if there was any noticeable deflection.
    Sieg X2
    HF 4X6 bandsaw
  22. #19
    Apr 2010
    Re: Infinity cube
    Ch4p
    . . . Still need to do some cleaning with the grinder . . .
    Just read the entire thread . . . 'a grinder is not a primary
    metal fabrication tool'
    Before you build another - you need to build 'your welding
    skills 10X'
    - or you are just 'peeing in the wind' . . .
    The higher your welding skills - the fewer clamps, mags,
    and fixtures [corrections] you need . . .
    Dressing a weld, can be correct - grinding a weld, means
    it is all wrong . . .
    hth
    Opus
  23. #20
    Apr 2016
    CA
    Re: Infinity cube
    So by looking at it I’m trying to figure out the best way to weld this up. If my theory is correct I would need 18 almost identical pieces metered 45 at the corners then weld up 6 sections of 3 pieces per section in the shape of a C. Then weld those 6 sections together. Does this sound about right?
  24. #21
    Apr 2016
    CA
    Re: Infinity cube
    Quote Originally Posted by Mac's Crew View Post
    So this is a hot ticket item for you huh?
    this would be cool in SS or plain steel with blues golds oranges purples etc from tig welding and heating from a torch and then clear coated to show off the rainbow of colors and craftsmanship of assembly.
  25. #22
    Aug 2018
    'ta town, KS
    Re: Infinity cube
    N2.... it is not a hot ticket, but a consistent. I sell 4 to 6 a month which is plenty for me. They are all 45° angles just laid out in different directions. I don't ship which cuts my customers down, but I don't care. I do not want the hassle.
    Mac
  26. #23
    Ct
    Re: Infinity cube
    I have some #4 finish stainless tubing left over from a job, I might ty to make one of these, although I'm not looking forward to the warpage that will happen with the stainless.
    Sent from my moto g power using Tapatalk
  27. Likes ronsii liked this post
Page generated in 1,713,308,013.38809 seconds with 18 queries
