Results 1 to 11 of 11
Thread: Making a 22 1/2 deg elbow out of a 45.
    May 2015
    Central PA
    So i am installing a heater in my garage. It is supposed to have stainless vent. I ordered a 45 elbow, but now realize that i need something closer to 22 1/2. Problem is that i can only find a 15 degree.
    How bad of an idea will it be to cut out 22 degrees of the 45 and weld it back together? I dont Tig, but i can mig (if that matters)
    Sep 2005
    Cave Creek AZ
    Re: Making a 22 1/2 deg elbow out of a 45.
    Is it jus a B type vent pipe? What size?
    May 2015
    Central PA
    4" single wall (not sure if that is a B type or not)
    The damn thing was $50. Otherwise I would have already hacked it up.
    From fabrication strand point. You will have some misalignment if angles do not match on the mating surfaces. It may not be a significant gap?
    Jun 2016
    would using a backup piece work if small enough to not interfere with flow?
    lincoln 125sp
    dayton 250 ac/dc
    miller 211 w/spool gun
    ahp 200 sx tig
    lotos ltp5000d
    kubota b3200 FEL BH
    of course duramax diesel
    May 2015
    Central PA
    Alignment won't be an issue...I will have enough play to make up for some error.
    My issue is more with welding the stainless. Anything I need to know? It will be inside, so it has to be pretty air tight. Not sure rust will be an issue, which I'm sure would be the case if it were out in the weather.
    Just use flex
    Quote Originally Posted by Ron_J View Post
    May 2015
    Central PA
    Just use flex
    Can't (or not supposed to) has to be Cat III (stainless and gasketed pipe).
    Nat. gas heater....?
    May 2015
    Central PA
    Well that SUCKED! I got it cut and it lined up pretty darn good. But it is much thinner than I am capable of welding and have it look good. I got it, but blew a lot of holes in the process. I probably spent more time filling the holes I made than actually welding the two pieces together. But, it's done and air tight...guess that is all that matters.
    May 2015
    Central PA
    Propane. But I am venting it horizontally, so it has to be the Cat III.
Page generated in 1,713,308,279.21071 seconds with 18 queries
