Results 1 to 22 of 22
Thread: Shaft Extension for Door Latch
    Mar 2014
    Troy MI
    My customer made a custom door, which was considerably thicker than a standard door. This meant that standard door knob hardware would be too short to reach through the door. Door knob extension kits are available, but these were also too short. To solve the problem my customer purchased a second door knob assembly so that he could scavenge the two shaft parts that were required. The task was to weld an extension to the outer piece that looked like half of a pipe. The inner piece appeared to be made of pot metal and I was reluctant to attempt to weld it. I know that Muggy Weld makes a Super Alloy 1 product that can weld pot metal, but a kit costs $105. My customer and I decided to machine a sleeve to extend the shaft, which would be glued on using Loctite 680. The first picture shows the drawing and the parts that my customer provided.
    1. Drawing and parts
    Name:  1. Drawing and parts.jpg
    I was concerned that the sleeve would interfere with the numbs on the ID of the shaft so I ground them off.
    2. Grinding off nubs
    Name:  2. Grinding off nubs.jpg
    I like to remove the plating before I machine plated metal to avoid smearing the plating on the area to be welded, because the plating will cause porosity in the welds.
    3. Etch off plating in HCL
    Name:  3. Etch off plating in HCL.jpg
    4. Plating removed
    Name:  4. Plating removed.jpg
    The first machining task was to remove the radius on the end of the shaft in preparation for welding.
    5. Squaring off one end
    Name:  5. Squaring off one end.jpg
    Smith Oxyacetylene Torch
    Miller Dynasty 200DX
    Lincoln SP-250
    Clausing/Coldchester 15" Lathe
    16" DuAll Saw
    15" Drill Press
    7" x 9" Swivel Mast Saw
    20 Ton Arbor Press
    Bridgeport
    Lincoln LE 31 MP & Lincoln 210 MP
    Everlast PowerTIG 400 EXT
  2. Likes ronsii, farmersammm liked this post
  3. #2
    Mar 2014
    Troy MI
    Re: Shaft Extension for Door Latch
    Next, I trimmed the end of the outer extension shaft.
    6. Trimming off the other end
    Name:  6. Trimming off the other end.jpg
    Below are the machining tasks that were performed on the inner shaft.
    7. Facing end
    Name:  7. Facing end.jpg
    8. Center drilling
    Name:  8. Center drilling.jpg
    9. Turning OD
    Name:  9. Turning OD.jpg
    10. Nice coil chip
    Name:  10. Nice coil chip.jpg
    Lincoln SP-250
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
  4. Likes ronsii, farmersammm liked this post
  5. #3
    Mar 2014
    Troy MI
    Here are some additional tasks for the inner shaft.
    11. Parting shaft
    Name:  11. Parting shaft.jpg
    12. Drilling shaft
    Name:  12. Drilling shaft.jpg
    13. Reaming shaft
    Name:  13. Reaming shaft.jpg
    Next, I sanded off the mill scale in preparation for welding.
    14. Grinding off mill scale
    Name:  14. Grinding off mill scale.jpg
    Now I was finally ready for welding.
    15. Setup for welding
    Name:  15. Setup for welding.jpg
    Lincoln SP-250
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
  6. Likes ronsii, scsmith42, farmersammm, Larry4406 liked this post
  7. #4
    Mar 2014
    Troy MI
    Now the welding steps:
    16. Ready to tack weld corner
    Name:  16. Ready to tack weld corner.jpg
    17. Welded out
    Name:  17. Welded out.jpg
    18. Close up of weld
    Name:  18. Close up of weld.jpg
    I didn’t want to penetrate on the inside, because it would interfere with the inner shaft.
    19. Inside of weld
    Name:  19. Inside of weld.jpg
    The next step was assembling the inner shaft with 680 Loctite.
    20. Sleeve Loctited
    Name:  20. Sleeve Loctited.jpg
    Lincoln SP-250
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
  8. Likes ronsii, scsmith42, farmersammm, whtbaron liked this post
  9. #5
    Mar 2014
    Troy MI
    Here is the painted shaft.
    21. All done and painted
    Name:  21. All done and painted.jpg
    And here is the whole latch assembled.
    22. All done and painted
    Name:  22. Latch Assembled.jpg
    -Don
    Lincoln SP-250
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
  10. #6
    Sep 2005
    Cave Creek AZ
    I just use Schlage locks, they can do up to 2” without doing anything. Extension kits are about 15 bucks.
  11. #7
    Mar 2014
    Troy MI
    The door is about 4” thick, I couldn’t find any extension kits that would accommodate this.
    The extension kits that I could find only extend only the center shaft not the outer one.
    Normally this is ok assuming that you want the door strike on the outside of the jam, which would be lined up with the outside of the door.
    In this case the door has 1 x 4 trim on the outside so the latch needs to be installed deeper in the door.
    As a result the outer shaft needs to be lengthened as well, so that the latch can engage with the outer shaft.
    I do agree with you that an extension kit would have been a good solution, if it would work in this application.
    Thanks for mentioning this solution.
    -Don
    Lincoln SP-250
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
  13. #8
    Beautiful work!
  14. #9
    If you weld the key in, you'll never lose it
  15. Likes Capt B liked this post
  16. #10
    Feb 2016
    Myrtle Beach
    Well done!
    Lincoln 350MP
    Millermatic 350P
    Syncrowave 250
    1969 SA200
    HTP Invertig 221
  17. #11
    Mar 2005
    Under a Rock
    Nice work Don
    good thing you are retired....
    Hypertherm PM 45
    1961 Lincoln Idealarc 250
    HTP 221
  18. #12
    Darn nice work. Just keep in mind a good locksmith shop or door hardware supply vender can provide knobs for such problems. Got to pass up the box store stuff. Being to provide it in the style the customer wanted? On time ? Probably not, and thats when skills such as yours become so handy. Once again impressive work.
  19. #13
    NW New Jersey
    Nice job, and a really good job on the documentation. I really like that third hand you have there. Ground clamp, ground strap, adjustable, and bronze feet. Where did you buy that ? I could certainly use one in my shop.
    Thanks for sharing
    Miller Synchrowave 180 sd
    Miller Econo Twin HF
    Lincoln 210 MP
    Dayton 225 ac/dc
    Victor torches
    Snap-On YA-212
    Lotos Cut60D
    Primeweld 225 ac/dc
    Primeweld mig180
    Miller AEAD-200
  20. #14
    Mar 2014
    Troy MI
    Thanks for sharing
    This one is from Strong Hand Tool. I liked it because as you noticed it has the ground strap (work lead) on it.
    https://www.amazon.com/Stronghand-To.../dp/B01DL9Y7ZU
    -Don
    Lincoln SP-250
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
  21. Likes ronsii, whtbaron liked this post
  22. #15
    Bilbao, Spain
    If I ever need to make a living on my welding skills... I want every random customer to provide parts and drawings like yours! Beautiful work!
  23. Likes ronsii liked this post
  24. #16
    Mar 2007
    MidWest
    You obviously have the patience of Job and great attention to detail. Nice work
    Geezer
    Power Mig 255C
    185 TIG
    Blue 175 MIG
    Ranger 8 Kohler 20HP
    Victor/Harris O/A
    K 487 Spool Gun
  25. #17
    Looks great.
    I had do that a few times myself.
    Quote Originally Posted by Don52 View Post
    4. Plating removed
  26. #18
    Nice work, Don! . Not that any of us are surprised lol.
  27. #19
    Mar 2008
    Georgetown, Texas
    Very nice work but your buddy bought the wrong lock set. I too built my own outside doors and had to do the same exact thing. Some locksets use a square rod instead of that rounded one. I used key way stock the same size as the square rod in my lockset. I just had to thread each end. My door was about 3" thick. Oh, don't forget that you will also have to make a new strike plate with the little square hole in it.
  28. Likes albrightree, whtbaron liked this post
  29. #20
    Mar 2014
    Troy MI
    Nice looking door and hardware.
    -Don
    Lincoln SP-250
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
  30. #21
    Jan 2022
    Sugarland, GA
    Wow very nice. That’s a great idea and write up.
    Retired Old Guy
    Hobart 210
    Lincoln AC/DC 225/125
    Evolution 14” Saw
  31. #22
    wrong thread
Page generated in 1,713,303,628.14545 seconds with 19 queries
