Results 1 to 5 of 5
Thread: Plasma cutter questions
    Jan 2016
    I'm considering the Hobart 27i, the Miller 375 extreme, or the Hobart 40i plasma cutter for home/hobby use. Several questions:
    1) The Miller 375 ans Hobart 40i have a pilot arc controller that essentially provides a pilot arc as needed. This is said to work better in situations where the arc might be extinguished during use - for instance with painted metal or expanded steel products. The Hobart 27i has only a starting pilot arc; if the arc is extinguished due to the example conditions noted previously, the operator has to pull the plasma gun trigger again to restart the arc. How important is this feature (a pilot arc controller vs. starting arc only)?
    2) The larger Hobart 40i requires a greater airflow (6 vs 5 scfm @90psi). I'm assuming that the airflow increase is due to larger airflow at the tip, which at the same 90psi pressure would mean that the airflow hole in the tip is larger. Is this likely to increase the width of the cut (kerf), and buy how much? Has anyone tried both the 27i and the 40i and can comment on this question?
    3)The Hobart 40i comes with an XT40R gun can use 30a or 40a tips, but the manual suggests that 40a tips are required with 240V input. Since the 30a tip should produce a smaller/thinner cut, I'd like to use it whenever I need 30aor less. Can I run a 30a tip on 240V as long as I keep the amps set below 30a?
    4) Anyone with experience using either/all of these plasma cutters who can comment on their experience?
    Thanks ins advance,
    Beuford
    Jan 2005
    Re: Plasma cutter questions
    Yes,
    and it's what you should be doing.
    Esab/Lorch ET-220i
    Esab 160i caddy
    Thermal Pee-Wee 85s
    Thermal Drag-gun 35C
    INE 1500
    Klutch 140i
    Jan 2016
    Thank you for your response.
    In the end, I decided on none of the above. I went with the Hypertherm Powermax 45 XP instead at ~ $450 over the cost of the Hobart 40i or the Miller 375. I mean, as long as I'm already committed to spending $1500... Who needs food, anyway?
    Thanks again.
    Beuford
  4. Likes Kevin_Essiambre liked this post
    Can't go wrong with Hypertherm on plasma cutters, IMHO. And if you ever run into problems, I think Jim Colt (rep of Hypertherm) posts here. PowerMax 45 is a nice unit.
    Just remember. the nozzle size should match the cut amps selected.
    lower amps than the nozzle size doesn't cut well. higher amps than nozzle and the nozzle wears out fast. set air pressure correctly and make sure air is clean, dry and oil free. Consumables will last a lot longer.
  7. Likes driz liked this post
Page generated in 1,611,012,352.55367 seconds with 14 queries
