Page 2 of 2 FirstFirst 12
Results 26 to 32 of 32
Thread: Anti vibration for 8" grinder?
    Re: Anti vibration for 8" grinder?
    I use the single point diamond dressers myself... never liked the bar type like you posted...
    But like all the dressers you must make sure it is not moving in/out when you use them!!! at least if you want a nice true finish
    Attachment 1719834
    Same type I use, and with the same cautions.
  2. Likes ronsii liked this post
  3. #27
    Here's a better pic. of the Huntington style dressers. They have a few other styles as well.
    http://desmond-stephan.com/index.php...ngton-dressers
    https://www.desmond-stephan.com/
  4. #28
    Apr 2014
    MN/WI
    Did you also use your dial indicator on the motor shaft? If the grinder got knocked over at some point in it's life, then the shaft may be bent.
    Lincoln Idealarc TIG-300
  5. #29
    Jan 2015
    Lewis Center/Powell Ohio
    I got the difference down to .007 from almost .030. I found the low spot, marked it on the side, then vice gripped my dresser to the rest so it barely touched the highest spot. Ran the grinder until that was gone and worked my way down. The hose clamp wasn't near precise enough and although it rode on the edge of the rest that wasn't enough to keep it from following the high/low points and it would be completely impossible manually, at least for me. Vice grips did it.
    In order to get that down to next to nothing, I might have to have a jig where I could incrementally dial the dresser in. It's too hard to take a high spot out unless you have some way to lock the dresser down so it won't follow the contour. It's also tricky to tweak it closer without getting it too close while keeping it locked down unless you have some kind of dialing jig.
    Sometimes in the process I got it a hair too close to a high section and the motor startup wasn't strong enough to get it going so I had to help it manually until that spot ground down enough after a few revolutions. There's still some vibration which I'd like to figure out, but the grinder is useable now.
    I have one of those dressers with wheels and have used it on another grinder. It's OK for cleaning out the grit, removing grooves and taking a bevel out of the face but IMO completely worthless for truing a high spot out of the face. Not very precise.
    If I get bored this winter and need a project, I might try to make one of those jigs. I've seen one for the diamond point dressers but it and that dresser are probably more than I ought to spend for intermittent use.
    PS. I will try the dial indicator on the shaft, both sides. The wire wheel is a Weiler Vortec and has a little vibration to it but there's not much can be done other than rotating it.
  6. #30
    I use a shaft collar to set my depth on the round dressing nubs. Gives you quite a bit more bearing surface against the tool rest.
  7. #31
    Los Angeles
    Quote Originally Posted by JD1 View Post
    Nvm??
    NVM = Never Mind
    MM211 (Sold)
    Klutch 120v Plasma cutter
  8. #32
    Jan 2015
    I'm done.
    1) Got the runout down to .003
    2) Accidentally found that even at that, the wheel has a heavy side.
    3) Small vibration with the Weiler wire wheel plus the heavy side of the grinding wheel was combining to aggravate the overall vibration.
    4) Rotated the grinding wheel in 1/8 increments and found a spot that mostly offset the Weiler wheel. The Weiler wheel was already rotated to it's best position.
    5) No runout in the shaft. No vibration at all when the motor ran by itself.
    Some rubber washers and a rubber mat and it's good until I have to replace the grinding wheel. I'll look for a better grade then.
  9. Likes whtbaron, bead-boy liked this post
Page generated in 1,713,259,186.24092 seconds with 18 queries
