Results 1 to 12 of 12
Thread: What is minimum size Pan Sheet Metal Brake would you recommend?
    Nov 2019
    North East Ohio
    Silly question because "It depends on ones needs". I hate buying something twice. Space is an issue. Trying to get out of making gym equipment and want to make arty stuff and furniture. I tend to make thick stuff, lol
    Re: What is minimum size Pan Sheet Metal Brake would you recommend?
    Minimum size (imo) would be 36” -16 gauge.
  3. Likes Reebz liked this post
    Sep 2005
    Cave Creek AZ
    I have a Chicago 12 gauge 48” leaf brake. It has been very handy! Also not cheap. Anything bigger that needs bent I farm out to the pressbrake shop.
    Jul 2007
    Murphysboro, IL
    I used to be a sheet metal worker doing almost all HVAC work. Admittedly most of my work was in a smaller operation and was duct work in residential and small commercial operations, we had a 10' brake in the shop and eventually we got a 48" box and pan brake. We used it alot but mostly in the 12-18" width range, I think it would go up to 18 gauge.
  6. #5
    Here's my 36" x 16 gauge Boggs Brown I sold this summer.
    I still have the equivalent sized import box and pan I bought new on sale 20 years ago.
    The quality is nowhere near that of the old school one but I realized it is more than adequate for my needs and skill set.
  7. Likes Reebz liked this post
  8. #6
    Nov 2019
    North East Ohio
    Thanks guys. Because I tend to make heavy thick stuff 16 gauge is probably important.
  9. #7
    Nov 2019
    North East Ohio
    Lis 2323
    That looks perfect. I like the table style as well
  10. #8
    Thanks Reebz. Depending on what you plan to make you might take a look at magnetic sheet metal brakes also.
    https://www.baileigh.com/metalworkin...t-metal-brakes
    Acquiring one was definitely NOT on my radar, but I came across an automotive body guy who purchased this unit for the sole purpose of building a set of body panels for his show car. He let me have it for half the price of new.
  11. Likes Capt B, whtbaron liked this post
  12. #9
    How difficult is it to line up those plates on the mag brake? Seen a couples on c'list here.
  13. #10
    Not difficult at all. You can have your workpiece and clamping bars held in position with half magnetic power. I can then use a small rubber mallet to tap square if necessary.
    FULL magnetic holding force is applied when you lift the handle to bend.
    If you have a lot of simple repetitive bends to make that don’t require the clearances this brake affords it is WAY quicker to use a conventional machine.
  14. Likes ronsii liked this post
  15. #11
    Jun 2015
    Louisville, KY
    Seems like a 4' 16ga finger brake is the 'internet standard' answer for garage type shops.
    I agree with that. The only finger brake I have is a 24" pexto 16ga but I have other brakes too. Most straight brakes have enough room at each end to do a 3 sided box (and 1/2 of the 4th side... so they can be more versatile that some think.)
  16. Likes tapwelder liked this post
  17. #12
    On my press I cannot build a 3 foot box on my 3 foot opening. Is there a capacity on a finger brake. My sides hit the uprights, so the box bottom size is minus the side height x2.
Page generated in 1,713,294,069.08255 seconds with 18 queries
