Results 1 to 9 of 9
Thread: Lincoln Ranger 8 Fuel Gauge Assembly
    Nov 2020
    I have a Lincoln Ranger 8 welder. Model number 10373. I need the fuel gauge assembly that goes into the tank, because mine is leaking when the machine is not level. I am also wanting to purchase the choke cable linkage, that goes from control panel to the carburetor. Can not seem to find the correct part numbers on the internet.
    Feb 2013
    Re: Lincoln Ranger 8 Fuel Gauge Assembly
    What’s your part numbers ?
    Nov 2020
    Part number for fuel assembly gauge, 9SS22934. I cannot find the choke assembly cable part number.
    Feb 2013
    Searching that number I see several for 120 to 130 dollars.
    Nov 2020
    Ok. Thanks for the help.
    Go to NAPA auto parts or your favorite auto parts store.
    ask for a universal replacement choke assembly cable.
    Just cut to fit.
    Lincoln's suggested sale price is $130.00 for the gauge.
    your local welding supply will sell for around this . If they are Lincoln authorized.
    Nov 2020
    Ok, will do. I have another question. How long should the Lincoln Ranger 8 welder stay in high idle after I stop welding? The reason I am asking, I used to have a Miller Legend welder and when you stopped welding, the welder stayed in high idle for about ten seconds. When I stop welding with the Lincoln Ranger 8 welder, it returns to low idle immediately. Thanks
    Stokes County, NC
    The choke cable appears to be S-7525-18 for an Onan engine below code 10900.
    The fuel gauges I've seen have a rubber or cork gasket under the sight window. And if the window is cloudy, as most are, it will usually clean up pretty well and be usable. Unless you know the gasket is good and that the gauge is leaking elsewhere I'd cut some gas resistant gasket material and try that first.
    Best regards to all,
    Lance
    Lance R
    1994 Lincoln Ranger 8...Kohler CH18 with 87 hours
    Smith Torch set
    Nov 2020
    Ok. I will try to cleanup first. I think it is leaking around the gasket. Thanks
Page generated in 1,610,799,858.68247 seconds with 12 queries
