Re: Lincoln Ranger 8 Fuel Gauge Assembly
The choke cable appears to be S-7525-18 for an Onan engine below code 10900.
The fuel gauges I've seen have a rubber or cork gasket under the sight window. And if the window is cloudy, as most are, it will usually clean up pretty well and be usable. Unless you know the gasket is good and that the gauge is leaking elsewhere I'd cut some gas resistant gasket material and try that first.
Best regards to all,
Lance
Lance
Miller/Smith heavy duty torch set
Multimatic 255 w/MDX-250 EZ-Select gun
9" Evolution circular saw
