Results 1 to 25 of 31
Thread: Drilling a hole in a magnet?
    Jan 2015
    Lewis Center/Powell Ohio
    Before I ruin this by experimenting I wondered if anyone here has drilled a hole in a magnet successfully. I need to put a 5/16" hole in this one and thought about starting with a small bit and incrementing my way up?
    Aug 2018
    'ta town, KS
    Re: Drilling a hole in a magnet?
    That works.. but is that magnet chipping? It will be challenging to do if it is already chipping
    Mac
    May 2008
    Orange, TX
    Never tried it myself but starting small and working up was my first thought as well. Sharp drills and go SLOW would be my suggestion.
    MM200 w/Spoolmatic 1
    Syncrowave 180SD
    Bobcat 225G Plus - LP/NG
    MUTT Suitcase Wirefeeder
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    May 2010
    Ct.
    Looks like a ceramic (ferrite)magnet.
    You could try grinding a hole with a Dremel
    tool , die grinder, Du-more grinder etc. with a small
    mounted stone.
    Miller a/c-d/c Thunderbolt XL
    Millermatic 180
    Purox O/A
    Smith Littletorch O/A
    Hobart Champion Elite
  5. Likes Denis G liked this post
  6. #5
    ca
    Syncrowave 250 w/ coolrunner
    MM210 W/spoolgun
    SP 135
    Victor O/A
    Ramsond cut 50
    Titanium Stick 225.
  7. Likes walker liked this post
  8. #6
    May 2007
    i had the same scenario u goin through i think. i had magnets come out of a $53 stabila torpedo . i tired to drill, but couldnt. ive seen torpedo magnets w/ holes through them though
  9. #7
    Oct 2019
    Australia
    You need a mag drill
  10. #8
    Jan 2015
    Home Depot has some Neodymium magnets with the right size hole in them but they're too strong for what I need. Guess I'll just start with my smallest bit and work up.
  11. #9
    May 2012
    Ontario, Canada
    I'd try an abrasive diamond grit bit.
  12. Likes William McCormick liked this post
  13. #10
    Sydney Australia
    Some magnets are Cobalt , now that would take some drilling .
    Some however are iron .
    A good guess is better than a bad measurement
  14. #11
    Jan 2015
    There's some of those over at Home Depot with the right size hole in them. But they're too strong for what I need it for. Guess I'll just start with my smallest bit and gradually go up. Don't know what it's made of, just some cheap magnet so maybe iron.
  15. #12
    Jan 2015
    I had to give up. A drill bit won't even make a pockmark in the surface. Moving on to find another solution.
  16. #13
    Feb 2016
    Six Mile SC
    Quote Originally Posted by JD1 View Post
    When a magnet is too strong, I often coat it with a layer or two of duct tape.
    CG
  17. #14
    Mar 2015
    Milwaukee, WI
    Try using the same type of bit used for drilling ceramic tile.
  18. Likes Capt B, William McCormick liked this post
  19. #15
    Nov 2019
    North East Ohio
    Try https://www.kjmagnetics.com/
    KJ has rare earth mag. many with holes.
    Magnets hate heat once you hit the curie point they lose mag.
  20. Likes William McCormick liked this post
  21. #16
    Aug 2018
    'ta town, KS
    I have drilled through speaker magnets on multiple occasions. To mount diamonds for dressing the grinder store. Very slow speeds and patience.
    Mac
  22. #17
    That kind of magnet is not very hard at all.
  23. #18
    A lot of the jewelry crowd uses micro core bits and other assorted diamond covered tooling. you could also rig up a redneck EM setup and bore through with electrical
  24. #19
    Aug 2012
    AR
    Quote Originally Posted by tackit View Post
    If that was a solid magnet, I would have tried to spot heat it in the center with a torch, and then drive a small center punch through it.
    As Reebz said, if you heat a magnet past the Curie point (temp), you will no longer have a magnet.
  25. Likes William McCormick liked this post
  26. #20
    Nov 2019
    North East Ohio
    Check out K&J magnet. They have them in all shapes and sizes. Neodymium mags. are amazing.
  27. Likes William McCormick liked this post
  28. #21
    Thinking about those ones that were available with the hole, but too strong. How about a variation on the duct tape idea, and coat them with fiberglass resin? Can't you weaken a magnet by dropping it? Not sure how many million drops that would take if you wanted it to happen though...
    Oct 2019
    Australia
    Q. What do you get when you heat a rare earth magnet?
    A. Rare earth.
  30. #23
    Sep 2014
    I would go with a wet diamond bit.
    https://www.amazon.com/Diamond-Drill...6787867&sr=8-7
    Sincerely,
    William McCormick
  31. #24
    Sep 2014
    These look better.
    https://www.amazon.com/uxcell-Diamon...WT5PZJ0KS&th=1
    Sincerely,
    William McCormick
  32. Likes ronsii liked this post
  33. #25
    Jan 2021
    To drill a hole in a magnet, you will need to apply the tip of a power drill onto the surface of the magnet and gently push it down into the center. For the best results, you should proceed with frequent stops to flush the holes with a coolant solution to prevent adverse effects.
Page generated in 1,713,298,881.35475 seconds with 19 queries
