Results 1 to 20 of 20
Thread: Cantilever Material Rack
    Jun 2016
    Texas Hill Country
    I posted this in my thread about learning nr232, but thought some here may want to see the rack I built yesterday. 12" ibeam and some angle cross bracing. The racks are short and at a 1/12 pitch (they were drops from the roof the rack is under)
  2. Likes Shootr, VaughnT liked this post
  3. #2
    Sep 2005
    Cave Creek AZ
    Re: Cantilever Material Rack
    Kinda like after they killed Bonnie and Clyde, they were asked why they were shot 140 times and they answered, ‘because we ran out of bullets’.
    I guess if its worth killin’ it’s worth overkillin’.
  4. Likes mbarasing, mcspeed liked this post
  5. #3
    Jun 2016
    Texas Hill Country
    If that rack so much as wiggles--im welding in some gussets!
  6. Likes Dave66, whtbaron liked this post
  7. #4
    Quote Originally Posted by mbarasing View Post
    Might I suggest some 1 inch plate and 2 foot triangles... now that ought to do it!!!!
  8. #5
    I have one in my garage that has 5 times that amount of steel on it and the frame is made of 1/4 that amount of steel. Its been standing for 10 years now . It is 6 ft tall and has 7 places to put steel. I put the larger stuff at the bottom and store lighter steel on each rack as they go up. I probably have 2000 lbs of steel on it at least. It only has 2 verticals 6' apart and I put 10 and 12 footers on it.
  9. #6
    Apr 2010
    mbarasing
    This is 'unintelligible gibberish' . . .
    Your [too much] welds are good . . .
    Pls post your design - it is the project . . .
    hth
    Opus
  10. #7
    May 2017
    Pitman PA
    mbarasing
    hth
    Opus
    Do you ever post anything without puttin a bunch of bull**** in the post? I see more of this unintelligible gibberish from you than anyone...almost as bad as Biden
  11. #8
    Quote Originally Posted by Popeye an old miner View Post
    Let's look at what they have in common. In way too many years haven't accomplished anything. Both afraid to leave the basement. Definitely the jibberish. Both are entirely full of shlt.
  12. Dislikes PDXsparky disliked this post
  13. #9
    I feel like an idiot...................but just what am I looking at?? What holds it up........I can't see where it attaches to anything
  14. #10
    Gravity and mass. Heavier items at bottom. Of course it's not perfect but with some care it should do fine.
  15. #11
    GEEZ...........I REALLY DO FEEL LIKE AN IDIOT NOW
    I looked at that damn picture for 5 minutes, and thought it was attached somehow to a STUCCO WALL
  16. Likes whtbaron, mcspeed, wb4rt, ronsii liked this post
  17. #12
    It's all good. The X bracing is a good idea. Many just use a stringer at top and bottom to tie them together.
  18. Likes ronsii liked this post
  19. #13
    Looking back at the sideways picture I can see where one would get the stucco wall impression. Lol.
  20. Likes ronsii liked this post
  21. #14
    Yes.................if one is a semi senile blathering old idiot
    I stand in front of the refrigerator sometimes, and just look into the damn thing. I literally forget what I wanted out of the stupid thing. K'kins will tell me "sausage", "mustard", or whatever she knows I ought to be getting out of the box. I think she secretly enjoys it
  22. Likes mcspeed liked this post
  23. #15
    I suppose that makes it really easy for someone to put words in your mouth.
  24. Likes ronsii liked this post
  25. #16
    Jun 2016
    Texas Hill Country
    mbarasing
    hth
    Opus
    Design and instructions for fixing up (or reclaiming) a trailer:
    1. Head down to the metal department (of your yard) and pull those short 4', 18", and 23" ibeam drops out of the weeds, tires and tin; there should be three of each.
    2. Cut 3 x 8' ibeams from that 24 footer stacked with all your drop-pipe.
    3. Weld together 3 vertcal sections of rack making sure that the angled cuts on the shortest pieces are against the longest pieces in such a way that material will stay put. Extra credit: Use a structural T8 wire that you've been practising--if you have the means, make it lifelike, i.e. weld it standing up.
    4. Place pieces level, 7' apart and parallel and weld in bracing.
    5. Remove that material from flatbed trailer and place on rack.
    6. Your trailer is ready to rehab (or go to work) and you've practiced a new process for structural work.
  26. #17
    Jun 2016
    Texas Hill Country
    Yup... sorry about that. If i knew how, I'd fix my pictures.
  27. Likes ronsii liked this post
  28. #18
    Is that the deepest beams you could get for the cantilevers ??
    Cut those in half horizontally and add a few more .
  29. Likes rhunt, ronsii liked this post
  30. #19
    Jun 2016
    Texas Hill Country
    When i run out of room that's the plan. Except I'll probably cut them in half diagonally to make triangles and use the pieces for more shelves.
  31. Likes BD1, ronsii liked this post
  32. #20
    Jun 2008
    New Plymouth ID
    I don't think you can build racks too heavy eventually its going to be completely loaded and your going to be fishing something out of the bottom of the rack with a forklift, and will not fall over.
Page generated in 1,713,270,745.51536 seconds with 19 queries
