Results 1 to 25 of 28
Thread: TIG Welding on the Floor?
    Oct 2020
    I am getting into tig welding and wondering if there were some tips to welding on the floor. I have a Primeweld 225x and I was wondering if I really need to use a hand amptrol to make this viable. Any tips from seasoned pros? Putting the long beams on any kind of table is just not viable.
    Re: TIG Welding on the Floor?
    Quote Originally Posted by kraythax View Post
    I've used my knee or elbow on the pedal... Seriously. But if you're doing steel, go MIG, you'll get more done.
  3. Likes ronsii, gnm109 liked this post
    Oct 2020
    Meh, not a production shop dependent on speed. And I like TIG better, except when crawling on the floor. Just getting used to a push button amptrol
    Jul 2018
    Cumbria, UK
    Never used a foot pedal with TIG (apart from trying out a machine once) - torch buttons and properly set up slopes on the machine work well for nearly everything
  6. Likes shovelon liked this post
  7. #5
    Sep 2014
    The only time I used a torch control for TIG was when I was welding stainless steel bow rails on a boat in the water, and the person that wanted them welded loaned me the machine. It was ok but after you use a pedal a lot, you can weld with a pedal on a ladder or on the ground. I use the side of my foot if I have to be on my stomach. Anything else and I use it normally, laying on your side you just use it normally.
    Sincerely,
    William McCormick
  8. #6
    SoCal-LA
    I used a button on a day job. I got drunk that night and bought an amptrol. Took a few days for the crick in my neck to go away.
    Best amptrol hands down is the SSC finger4. Cheap too. I one for Miller, and one for Lincoln.
    MillerDynasty700DX,Dynasty350DX3ea,Dynasty200DX,Li ncolnSW2002ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig4ea,MigMax1ea.
  10. #7
    Jul 2018
    Cumbria, UK
    crick in your neck? From what? lol
    seriously though, I've been through loads of fab and welding shop visits in the last few years, in the UK, and I've have never seen a foot pedal in sight... maybe on dedicated aluminium jobs (although our aluminium sheet metal guys don't bother with them either)
    I got a Lincoln amptrol-button combo for one of our lincolns, the welder who uses the machine says he occasionally uses it... lol
  11. #8
    Feb 2016
    Myrtle Beach
    I've done quite a bit of welding inside aluminum boats with the pedal between my legs.
    Lincoln 350MP
    Millermatic 350P
    Syncrowave 250
    1969 SA200
    HTP Invertig 221
  12. #9
    Oct 2020
    Which hand amptrol are they using? I am guessing they know what is good and what isnt . I have a button that came with my torch but its primitive.
  13. #10
    NW New Jersey
    Tack weld everything you can on the floor, then put it on saw horses, or stands to finish welding. You'll do a much better job if its in a comfortable position.
    I'm pretty sure the Primeweld has all the 4t settings available for you to tack together with just a torch switch. Did the primeweld come with a finger switch or torch mounted amptrol, or just the foot pedal ?
    Even if you want to TIG the structure , it would save a lot of back bending to tack it together with MIG, or 6011 (stick) . You can grind the tacks back a little, and TIG right over them, no one would ever know. Post some pic's when you get it tacked.
    Good luck
    Miller Synchrowave 180 sd
    Miller Econo Twin HF
    Lincoln 210 MP
    Dayton 225 ac/dc
    Victor torches
    Snap-On YA-212
    Lotos Cut60D
  14. #11
    Jul 2018
    Cumbria, UK
    https://www.lincolnelectric.com/asse...ochure-eng.pdf
    One of these (potentiometer unit)
    On my own machine, used for part-time business, I have this torch
    Used for repetitive jobs paid by the unit, it's superb. Dial in two programs to get exactly what I want, save them as jobs, and switch between them in job mode on the torch. Saves time, ups quality. In amp mode, it does what it says on the tin.
  15. Likes Capt B liked this post
  16. #12
    Jun 2008
    When I worked at a welding shop 30 years ago, never had a remote control other than on and off. Welded aluminum and s/s rails, some aluminum 6" piping and made loads of repairs in everything from engine blocks to whathave you. That and I walked uphill to work.....both ways :-) ......Mike
  17. #13
    SoCal-LA
    Yeah a crick in neck from shaking in disbelief on every weld coupled with frustration.
    Modern tig machines have remote contactor and remote current controls. On thin alum the amptrol is vital to start a puddle quick with full amps and while tootling along reduce amps on the fly. Otherwise undo canning and warpage gives me trouble. And I like to taper off amps at the end to prevent crater cracks. I am an old aerospace guy that just learned that way. I am sure buttons work for you but I am too old to learn something new.
    To me the SSC amptrol is too cool for school.
  18. Likes Munkul, 12V71, ronsii liked this post
  19. #14
    Sep 2016
    Detroit, Michigan
    I'm a big fan of SSC products, but that looks awful...it's huge and looks awkward. Having 25% increment steps seems limiting as well.
    The TIG Button amptrol looks 80% smaller and doesn't have steps....infinite like a pedal. I think that's worth the extra $100 or so.
    https://www.6061.com/tigbutton.htm
    http://mivise.com
    Millermatic 350P
    Spoolmatic 30A
    Hobart Champion Elite
    Everlast PowerTig 210EXT
  20. #15
    SoCal-LA
    Works like a charm for me and does not require any peripheral power input. The separate power source was a deal breaker for me. That and the SSC costs some $140 shipped from a member here.
  21. #16
    Sep 2005
    Cave Creek AZ
    On steel you can simply not use a remote and scratch start.
  22. Likes tapwelder liked this post
  23. #17
    I like my touch 4. Movement / positions is almost imperceptible. Feels continuous.
    I suspect any hand controller is better than carrying a foot pedal/extra cord around a car chassis. Over, under, untwist, unwrap, need more cord....
  24. Likes shovelon liked this post
  25. #18
    Laredo, Tx
    Care to wager on that?
    HTP Invertig 400
    HTP Invertig 221
    HTP ProPulse 300
    HTP ProPulse 200 x2
    HTP ProPulse 220MTS
    HTP Inverarc 200TLP
    HTP Microcut 875SC
  26. #19
    What are the stakes?
    Lots of tig machines will not even accept remotes. I don't use one in the field.
  27. Likes filetobeef liked this post
  28. #20
    Sep 2005
    Cave Creek AZ
    On whether or not it can be done? Sure, I did it for years.
    On whether or not the OP can do it on what I am assuming is a cheap chinese welder? Not so much.
  29. #21
    Sep 2005
    Cave Creek AZ
    The machine has stick mode, so with a manual G/V torch head it should be fairly easy to do.
  30. #22
    Oct 2020
    Good luck
    It comes with a button that I have gotten used to now. I spent half ofg yesterday on the floor. The stuff i will be welding is too big to put on a table anyway.
    And its not made in china :P
  31. #23
    SoCal-LA
    Well that is a start. Where is is made?
  32. #24
    Oct 2020
    Pennsylvania
    Great support. Called asked which wheel amptrol was compatible and they volunteered to send me one for free in 2 days.
    Love this rig. Primeweld TIG 225X rocks and no, I dont work for them.
    Oddly I find welding on my belly actually gives me a decent puddle view. Just need some gel elbow pads.
  33. Likes shovelon liked this post
  34. #25
    SoCal-LA
    Pennsylvania
    I've heard good things about Primeweld.
Page generated in 1,610,861,216.33063 seconds with 12 queries
