Results 1 to 25 of 44
Thread: Striking anvil/vise stand
    Oct 2013
    Ohio
    I got a scrap piece of 1" steel given to me. This is what I made...Name:  IMG_0927.jpg
Size:  82.5 KBName:  IMG_0928.jpg
    Big Lake/Monticello MN
    Re: Striking anvil/vise stand
    Looks handy and is way better than hammering on the little vise anvil.
    Syncro 350
  3. Likes whtbaron, robson1015, ronsii liked this post
    Looking good... you're going to like that. I made an upright anvil out of a chunk of tool steel and a railroad rail. I use it a lot.
  5. Likes robson1015, ronsii liked this post
  6. #4
    Jun 2016
    Texas Hill Country
    So nice that it deserved that bigger hammer
  7. Likes robson1015 liked this post
  8. #5
    Mar 2005
    Under a Rock
    Quote Originally Posted by robson1015 View Post
    I got a scrap piece of 1" steel given to me. This is what I made...]
    Very nice.
    I made a smaller version and glued a piece of rubber on the bottom
    So I could pretty much throw it anywhere if I need to bang on something.
    Comes in handy.
    Hypertherm PM 45
    1961 Lincoln Idealarc 250
    HTP 221
  9. #6
    Aug 2012
    AR
    John, that's a beast. What are the dimensions of the top?
  10. #7
    That's awesome !!
    An anvil isn't just for Blacksmithing. It is great for center punching metal too.
    I'll guarantee, that when you get one you'll always have a use for it.
  11. #8
    That's awesome !!
    Hard to see here, but mine has a hole in the center... I use it for knocking out broken bolts and old rivets all the time. My father and grandfather used it on the bench for the same purpose before me. It's a tough chunk of metal.
  12. Likes robson1015, ronsii, Lis2323 liked this post
  13. #9
    Oct 2013
    Ohio
    Looks like an old rail plate - what is the green thingy hanging ??
  14. #10
    Yep, I used the rail plate and support for a Hardy in case I want to cut something. If you look close under the flat piece, it's held in place with a loose bolt I can unscrew by hand. The round green thingy was a busted tractor spindle that I made a mount for. If I want to beat something flat, I use the flat steel, if I want to bend something round I can use the top of the spindle in it's place. Bad camera angle makes the base for the flat piece look crooked.
Size:  22.0 KBName:  036.JPG
  15. Likes ronsii, robson1015, Lis2323 liked this post
  16. #11
    Nice!!!
    I didn't know the deere colors came in 'hammered'
  17. Likes whtbaron, Lis2323 liked this post
  18. #12
    Oh, that's back when I first made it and the paint was fresh. She isn't that pretty now...
  20. #13
    Apr 2010
    robson1015
    'Paint it green' - and hide it - 'in the tall grass' . . .
    [is that overspray on your Ground/Pearled shop floor?]
    Your masterwork hosts - the highest concentration - of
    "what not to do", not seen for a while on the WW . .
    Details later . . .
    Opus
  21. Likes Joegreen02 liked this post
  22. #14
    Aug 2019
    OP, the design an execution looks very nice. I made a similar construct which I call a cold anvil. I have a PW 130 pound in the garage but there are times where a sacrificial cold cut w chisel is in order or if I am riveting or straightening. I stay off the anvil and use the cold anvil. Mine is out of an old piece of scrap I split and joined.
    You may wish to add a hardie type receiver hole. This is useful to get at small areas. Wheels a plus too.
    Here’s mine
    Regards.
  23. Likes whtbaron liked this post
  24. #15
    Sep 2016
    Detroit, Michigan
    I'm still waiting for someone to tell me what a non-striking anvil is?
    Yes to the "cold anvil" concept. Proper blacksmith's and farrier's anvils are far too hard to hammer on cold metal....very easy to damage them that way.
    I have a 5lb chunk of H13 that I plan to turn into something along these lines and save my anvils for smithing.
    http://mivise.com
    Hobart Champion Elite
    Everlast PowerTig 210EXT
  25. Likes whtbaron liked this post
  26. #16
    Oct 2013
    Ohio
    robson1015
    Details later . . .
    Opus
    That is overspray !! Painted it on the floor while it was snowing outside......Eventually I will mop it up with some thinner to make it pretty again.
  27. #17
    Oct 2013
    Ohio
    Quote Originally Posted by Continuum View Post
    Here’s mine
    Regards.
    Why the wooden wheels and handle?? How did you attach them?? looks good...
  28. #18
    Aug 2019
    Thank you. Integral wood shaft. Turned wheels. Simple handle. I have a small shop so space is at a premium. I don’t use the cold anvil often but it’s nice to access quickly when I’m building. The system tucks under the corner of my trestle bench. I added the handle so I can pull it out, work it, then push it back. Lifting slightly engages the wheels as such.
  29. Likes whtbaron, Garfield43 liked this post
  30. #19
    Nov 2012
    pittsburgh,pa.
    Those are some nice pounding ponies!!!
    either you LIKE BACON or you're WRONG!!!! "There are three kinds of men.The ones that learn by readin'.The few who learn by observation.The rest of them have to pee on the electric fence for themselves"-Will Rogers
  31. #20
    Mar 2005
    Under a Rock
    The top is 6”x 6”
    Base is 6x8
    About 6” tall
    Hypertherm PM 45
    HTP 221
  32. #21
    Nov 2014
    PDX PNW
    Very nice.
    Comes in handy.
    Looks like u sent it out to be welded
  34. #22
    Aug 2012
    AR
    Handy size, easy to move around. I might have to copy your idea...just need to find a slab of 1".
  35. #23
    Mar 2005
    Under a Rock
    Yeah,
    my Butler welded it up for me.....
    Hypertherm PM 45
    HTP 221
  36. #24
    Nice design. I like it!
  37. #25
    Everyone should have a striking anvil of sorts for center punching and general beatings
    I use a hunk of I beam ...
  38. Likes robson1015, whtbaron, ronsii, Garfield43 liked this post
Page generated in 1,713,297,278.19063 seconds with 19 queries
