Results 1 to 8 of 8
Thread: Aluminum welding
    Jul 2020
    Aluminum welding
    Do you need AC power to Mig weld aluminum or can it be done with dc. I don't know much about electricity. a lengthy explanation would be appreciated.
    Los Angeles
    Re: Aluminum welding
    MM211 (Sold)
    Klutch 120v Plasma cutter
    Los Angeles
    Mig welding Aluminum uses DC
    Tig Welding Aluminum uses AC **
    DCEN Tig Welding Aluminum
    https://www.weldingtipsandtricks.com...-using-dc.html
    MM211 (Sold)
    Los Angeles
    and not to confuse it more.
    Both processes use regular AC Input power from the wall.
    MM211 (Sold)
    SoCal-LA
    To pickup on Ed's posts, alum mig uses inert gas typically argon set to DCEP polarity current. The arc for alum will always be in spray as alum as a metal is too conductive to short arc weld. High speed pulse features do help with arc stablilization and puddle stability, and low speed pulse over high speed pulse can give you the mig like tig look on alum. Personally I only use alum mig for tacking and fill. Everything else is tig.
    Like this project I start with parts, tack them up with open corners and then fill weld with the mig. After filling I blend and radius the outside corners.
  6. Likes LtBadd, ronsii, Munkul liked this post
  7. #6
    Mar 2006
    Yuma, Arizona
    Hey Terry, what are those? Looks cool.
    Lincoln Power Mig 210MP MIG
    Lincoln TIG 300-300
    Lincoln Hobby-Weld 110v Thanks JLAMES
    My brain
  8. #7
    SoCal-LA
    Quote Originally Posted by Joker11 View Post
    Stage truss 6 way corner blocks. Like the ones we made shown here at the top of the arch.
  9. Likes ronsii, Munkul, Broccoli1, Brazin liked this post
  10. #8
    Mar 2006
    Yuma, Arizona
    Dude, that is awesome!
    Lincoln TIG 300-300
    My brain
Page generated in 1,713,293,413.57520 seconds with 19 queries
