Results 1 to 3 of 3
Thread: Lincoln vantage 300
    Feb 2013
    Lincoln vantage 300
    Looking at a used one. I don’t weld a lot and when I do I wouldn’t turn it up to high . I would also use it if the electric goes out for backup.
    My question is would it wet stack. I want a diesel.
    Ceres, California
    Re: Lincoln vantage 300
    possibly. just find a way to work it hard every once and a while. that will help keep wet stacking away.
    Wet stacking is often from excessive idling and/or no load. It's bad for some engines but others isn't a problem. I'd do some searching on the type of engine in question or contact Lincoln if there's a problem using as a generator for extended periods.
Page generated in 1,713,257,008.34054 seconds with 17 queries
