Page 1 of 4 123 ... LastLast
Results 1 to 25 of 82
Thread: Hobart g213 welder
    Dec 2020
    Hobart g213 welder
    I am older than this welder and I still work!! Hope to get this old one back working after pulling from brush pile, Need to find a manual and parts list for it . it has a flat brass( looks like) coil that has broken in 2 parts I do not know if this is a open air transformer or maybe some type of choke. Any help will be appreciated
    Apr 2020
    Re: Hobart g213 welder
    I had good luck getting the manual from over at Hobart forum.
    Apr 2020
    I found the manual do you have a email I can send it to?
    Dec 2020
    Quote Originally Posted by Johndough05 View Post
    My email is lkoontz2@logantele.com Much thanks Hey everyone JUST SLOW DOWN!!
    Dec 2020
    Want to thank you for the manual, got it now need to find coil AAW3944 thanks again
    Apr 2020
    You can find the Wisconsin engine manual online also I don’t have that in email form though.
    Soda springs,Id
    lazy733,I have the engine manual if you need it. PM me if so.
    Hobart G-213 portable
  9. #8
    Morton, Washington
    I just picked up a G-213 circa 1954 with the TJD-2 engine. Serial number AAW-72876. It appears to use the EEA100 starter. It turns over slow on 6V and about right on 12V. Looking at the parts breakdown the motor is a YA61. Can anyone confirm 12V is correct? It's using coil ignition so I'd assume 12V.
    I found these engine parts manuals online if anyone needs them.
    http://www.pittauto.com/customer/pia...ter_motors.pdf
    http://www.pittauto.com/customer/pia...d_final_v1.pdf
    Where is the best place to buy parts? I don't presently have any spark so I may need to source a few parts. Does anyone have the Wisconsin service/rebuild manual?
    mla2ofus I sent you a PM about your manuals.
  11. #9
    Aug 2004
    North Central Indiana
    Will you please turn your repair into another one of your traffic and interesting repair threads? Haven't seen one in awhile now. forhire, what was the Aussies name that helped you make the sign for the forge. Man I miss him, he had a lot of good information to share, I wish he would come back. If you would PM me his email I would ask him to.
  13. #10
    Morton, Washington
    You are thinking of Mick. I believe he was banned during the DotMatrix meltdown. You should be able to reach him here: https://snapncut.com/
  15. #11
    Morton, Washington
    I confirmed it's a 12V system... it was right in front of me on the regulators.
    I replaced the missing starter button and battery cables.
    I cleaned the sediment bowl with acetone. The varnish from the old gas was really stuck on. I also bead blasted the clamp parts and re-plated them with zinc. The finish isn't great but it was heavily pitted.
    When I removed the top cover to drain the fuel tank this giant house spider was waiting to attack me. The tank was surprisingly clean.
  17. #12
    Morton, Washington
    The distributor was heavily rusted. My heart sank when I realized it completely frozen. I feared the bottom end would be completely destroyed.
    Fortunately this doesn't appear to be the original distributor and as luck would have it the pinion wasn't engaged on the worm. It clearly wasn't fully installed. I am so lucky!
    So I proceeded to clean it up. I stripped everything down. Bead blasted what needed to be cleaned.
    I then re-plated all the parts with zinc. I didn't really get any pictures of the plating process.
    After re-assembling the distributor, and installing fresh points, I now have very strong/healthy spark. Tomorrow I'll set the timing. Napa didn't have the cap, rotor, or condenser in stock but I have spark so I can continue while waiting for the parts to arrive. I suspect the carburetor will need some attention. Any recommendations on degumming the carburetor without tearing it down?
  18. Likes ronsii liked this post
  19. #13
    Hobart g213 welder
    Come on now...
    You were doing so good with this project don’t screw it up now.
    Take it apart and clean it.
    But if you want to Try firing it with the carburetor as-is, i’ve had moderate success with spraying Seafoam spray or deep creep before and after it fires.
  20. #14
    Morton, Washington
    Come on now... You were doing so good with this project don’t screw it up now.
    Take it apart and clean it. But if you want to Try firing it with the carburetor as-is, i’ve had moderate success with spraying Seafoam spray or deep creep before and after it fires.
    I know you're right. Considering the fuel line from the tank barely passed fuel, even overnight, I can only imagine the state of the carb.
    I did get it to belch a little this morning...
    Here's a photo of the distributor after replating everything.
  22. #15
    Jan 2005
    Not sure of the model, but looked at one yesterday. Not really sure if the guy wants to sell it. or if the price is right? It was the guy's dads unit, and has value to him there.. Anyway It's a twin, and mag/crank style twin ..Told me not to wrap your thumb around the handle when turning it over.. Both pistons rise, and fall together
    Esab/Lorch ET-220i
    Esab 160i caddy
    Thermal Pee-Wee 85s
    Thermal Drag-gun 35C
    INE 1500
    Klutch 140i
  23. Likes ronsii liked this post
  24. #16
    Dec 2009
    Scott sounds like a Norton Commando
    Esab Multimaster 260
    Esab Caddy160I
    Esab 161 STL
    ESAB powercut 650
    Esab 220i tig
    Lincoln Precision Tig 225
    Lincoln IdealArc 250
    INE SKYLINE 1500
    Klutch 140i
    MEASURE TWICE IS FOR MORONS
  25. #17
    Jan 2005
    Quote Originally Posted by jim cafarelli View Post
    I don't know, because I never heard it run.. I did hear a story of how it broke the owners arm one day.. I guess you need to be a old/ tough/ welder to use one.. I am one out of three..
    Esab/Lorch ET-220i
    Esab 160i caddy
    Thermal Pee-Wee 85s
    INE 1500
    Klutch 140i
  26. Likes ronsii liked this post
  27. #18
    Soda springs,Id
    Mine is the TJD model which has the crank throws 180* apart whereas the THD has the crank throws as you describe.
  28. Likes ronsii liked this post
  29. #19
    Jan 2005
    About time for Hobart to bring out a 270 degree unit...
    Esab/Lorch ET-220i
    Esab 160i caddy
    Thermal Pee-Wee 85s
    INE 1500
    Klutch 140i
  30. #20
    Morton, Washington
    My engine is a TJD and is missing the hand crank. My push button works pretty good. I need to get a crank and try it once I have it running. I priced them out and I may have to make one. The crank model number is U212, according to the manual.
    I pulled the carb today. Float is definitely bad. Cracked, rotted, and full of fuel. I need to order a rebuild kit. Napa lists a kit without the float. I may end up ordering something online. I believe it's a Zenith series 68, L-63-BC is stamped on it. It was definitely gunked up. I loosened it up using acetone and then put it in the ultrasonic cleaner with some diluted oil-eater. It cleaned up fairly well. I'm quickly remembering why I prefer diesel.
  32. #21
    Quick search turned this up... from overseas.Looks close... but I'm not 100 percent certain it's an exact match???
    https://www.ebay.com/itm/Carburetor-...wAAOSwUIRfh~MU
    Ooops... posted wrong link at first..
    This one comes at a higher price and without the floats but says it's for a 63/2003 series... I couldn't find the differences from the 61,62,63's... so I don't know if the floats are the same or not???
  33. #22
    Morton, Washington
    I found a good picture of the series 68 kit here: https://www.carbkitsource.com/kits/ck0950.html
    I bought this one for for $12.67... all I really need is the float and gasket: https://www.ebay.com/itm/183776351256
  34. Likes ronsii liked this post
  35. #23
    That good price.
    Make job of rebuilding the carburetor easy.
  36. #24
    Jan 2005
    Got mine home today, 1945 model year..(from what I heard anyway..)
    Esab/Lorch ET-220i
    Esab 160i caddy
    Thermal Pee-Wee 85s
    INE 1500
    Klutch 140i
  37. Likes ronsii liked this post
  38. #25
    Thumbs up Re: Hobart g213 welder
    I like it
Page generated in 1,614,269,061.66200 seconds with 15 queries
