Results 26 to 50 of 66
Thread: Fireball Square recommendations
    Re: Fireball Square recommendations
    Texas Metalworks make squares up to 24” x24” x6”
  2. Likes ronsii, Capt B liked this post
  3. #27
    Somehow that just doesn't look like a picture in your shop???
  4. #28
    Hey. They can’t all be pics from my shop. Lol.
  5. Likes ronsii liked this post
  6. #29
    Thanks guys.
    Ok stepping on my own thread. What do you use to spread a work piece? Like two uprights need spread apart.
    I forgot about this Strong Hand clamp that exerts horizontal clamping forces that may work also
  8. #30
    Texas Metalworks make squares up to 24” x24” x6”.
    The Certi-Flat folks also offer a style like that, though their's doesn't go up to 24".
    https://weldtables.com/collections/fabsquares
    Also not in your shop....
    I have the original adjustable square from Fireball Tools and love it, but it looks like Weldtables.com has done something a little different and maybe even more handy. I might have to put that on the list of things to buy in the near future!
  9. Likes ronsii, whtbaron liked this post
  10. #31
    Quote Originally Posted by VaughnT View Post
    Wow!!! that does look cool!!!! all kinds of possibilities just need more money...
  11. Likes VaughnT, Lis2323 liked this post
  12. #32
    Honestly, it's the only one I've seen that I really like. Every other DIY square is set up to give you a 90ş, but never a 45ş, 30ş, 60ş, etc. That's pretty limiting in a shop, and Jason at Fireball is the only one addressing that issue. A couple of his Minion squares might very likely be on the short list of things that need to be added to my little corner of the world simply because they are so versatile.
  13. Likes ronsii, N2 Welding, whtbaron, Larry4406 liked this post
  14. #33
    Do you guys use anti spatter on those nice tables? I'd be sick if I got a big ol' blob of metal on that surface. But, I guess that most wire process's don't put out much in the way of spatter that will stick to anything.
  15. #34
    Oct 2019
    Australia
    I made my own table and blued the surface and wiped down with enox spray. I find mig spatter pops right off with the back of a hacksaw blade if it sticks at all. Usually bounces off.
  16. Likes ronsii liked this post
  17. #35
    Fredericksburg, VA
    These are a great idea. I have not seen these before and will be added to my wish list.
    Millermatic 252 MIG
    Miller Dynasty 200DX TIG
    Altas 12x36 Metal Lathe
    Bridgeport Milling Machine
    www.psacustomcreations.com
  18. #36
    Fredericksburg, VA
    Thanks guys.
    You can get pipe clamp ends that work as a spreader. That way you can adjust the length of the pipe to whatever you need.
    Millermatic 252 MIG
  19. Likes ronsii, Lis2323 liked this post
  20. #37
    I keep a nice thick coating of natural iron oxide on mine keeps the hot berries at bay!!!! but just another reason I use flux core cause it doesn't stick very good you just tap the blobs and they go scurrying away, or if you put a weld bead in the worng place... just whack it with a hammer and it's gone...
  21. Likes VaughnT liked this post
  22. #38
    Sep 2014
    I have both size Bessey square clamps. But these look pretty wild for the price and they hold up to 2 3/4" material.
    https://www.amazon.com/Hobart-770565...GC0V62ZNK&th=1
    Sinerely,
    William McCormick
  23. #39
    Quote Originally Posted by Woznme View Post
    I had to Google enox . I use Walter products also , the anti-spatter in particular.
  24. #40
    Nov 2019
    North East Ohio
    I'm glad I asked, always learning. I have not seen those strong hand clamps. I drilled my table and love there clamps. I have seen the hydraulic porta power at HF and thought about that. I have to watch some videos I have never seen one in action.
    Lis2323 and Pscustom. You never setter me wrong
    Thanks again Happy new year
  25. #41
    Give us time, Reebz....LOL
  26. Likes psacustomcreations liked this post
  27. #42
    Fredericksburg, VA
    Terry and I love to help someone else spend their money.
    I am still trying to convince Bob he needs a lathe.
    Millermatic 252 MIG
  28. Likes Lis2323 liked this post
  29. #43
    Feb 2019
    Snyder TX
    Regular turnbuckles make good spreaders also. Use jaw & jaw TB's & you can make all kinds of ends that pin in for different uses. Excellent way to rack a square or rectangular frame that has drifted out of square. clamp ends on a diagonal & screw!
  30. #44
    This type of pipe clamp can be reversed to SPREAD....
    Whereas this style doesn't.....
    Just an FYI before you run out to buy. Actually just realized only two of mine are capable of spreading.
  31. Likes William McCormick liked this post
  32. #45
    Fredericksburg, VA
    And of course Terry has a set that can spread. I picked up about 8 sets of the ones that don't spread made for 1/2" pipe. I only paid $5 each including a short section of pipe, so I was still happy.
    Millermatic 252 MIG
  33. Likes VaughnT liked this post
  34. #46
    And don't run out to buy a Porta Power. A cheap hydraulic bottle jack would work. Check to see if it will work horizontally though.
    Or a mechanical scissor jack.
  35. Likes ronsii liked this post
  36. #47
    On a budget ? Get creative and tack a tab on your table and use a wedge .....
    Or coupling nuts with bolts of assorted lengths.
    Or watch for machinists screw jacks at garage sales. Most are homemade and SOOO handy.
  37. Likes ronsii liked this post
  38. #48
    Sep 2015
    West coast of Florida
    It seems he's referring to Inox spray?
    Richard
    Website
  39. #49
    And of course Terry has a set that can spread. .
    Yeah but I didn’t know that at the time.
  40. Likes ronsii liked this post
  41. #50
    Nov 2019
    North East Ohio
    Thanks again.
    I learned from the pictures, some items I had not heard of. Last night I was looking at the pipe jack and knew it could be reversed to spread but it was not "making sense". In my defense it was at the end of a long day. lol
    I may go to HF and look at a porta. I hate buying foreign tools
Page generated in 1,713,297,875.18622 seconds with 18 queries
