Results 1 to 7 of 7
Thread: 8020 counterbore
    Oct 2011
    Louisville Ky
    8020 counterbore
    I'm looking to get into mobile machine guarding. I will be using 8020 and have 1 stumbling block for a mobile setup. It's counterboring 13/16" dia 5/8" deep in a a piece. In the shop I use the mill, its quick and clean. In the field or in an enclosed trailer I can't see a mill traveling very well.
    I'm buying an enclosed trailed setup for field service work.
    DO you guys have any ideas on how to do this? I've thought of a drill press with a fixture. Do drill presses have enough rigidity to handle this?
    Aug 2018
    'ta town, KS
    Re: 8020 counterbore
    I think a drill press would have the rigidity needed, depending on how it is anchored... an 8 inch harbor freight sitting on a bench may have some troubles... but bolted to the bench would give it a better chance. Machine, set-up, feeds and speeds... that's what it would come down to in my opnion. If you could do it in your shop, with a drill press you should be able to duplicate it in your trailer
    Mac
    Oct 2011
    Louisville Ky
    IM all about anchoring stuff down. I hate when things are just bouncing down the road. i may have to try the drill presses in the shop.
    Ct.
    How about a mag drill with a base/centering jig?
    Drill might also be useful for drilling on machines.
    Miller a/c-d/c Thunderbolt XL
    Millermatic 180
    Purox O/A
    Smith Littletorch O/A
    Jan 2005
    It will not take much to drill into 80/20..Might even just use a wood router/jig with wd-40 as lube
    Blue Demon 140 MSI
    Blue Demon 200 AC/DC
    Esab 160i caddy
    Esab CV353
    INE 1500
    Lincoln 250 Idealarc
    Thermal LM-200
    Thermal 60i- 3phase
    Thermal 15c
    Topshak 40 plasma
    Miller Regency 200/LN-72
    Viking 250 mig/2410 feeder
    Weldcote 140
    NW New Jersey
    I have a jet 18" drill press and a Palmgren cross slide vise that I used to do some of the 8020 drilling, It was accurate enough but really slow. Most of the time I just order it, especially if it has mitered joints on it. Any good bench top drill press should be able to do the job, though it might help if you have Drilling Jigs You could also invest in a small bench top mill, Grizzly makes some nice looking ones.
    I chuckled when someone mentioned a Mag Drill, thinking its all aluminum. Upon further thought, and finishing jpumps5's post ,I thought it could be useful when doing the machine mounting itself. I used to weld , and install guarding for injection molding presses, and I would have loved to have had a mag drill when mounting those. Those machine were made from some thick cast steel. I spent lots of time hand drilling and tapping those.
    Snap-On YA-212
    Lotos Cut60D
    Primeweld 225 ac/dc
    Primeweld mig180
    Miller AEAD-200
  8. #7
    I wish I had a nickle for all the aluminum plats I drilled with a mag drill . Either bolt or clamp a 1/4" steel plate to the aluminum. The Op does not say what size through hole he is counterboring but any size can be purchased at an industrial supply house fairly inexpensive. Any drill press should be able to do the job. I have counterbored hundreds of holes in a drill press. If its too big for a drill press a mag drill used as stated above should work just as well.
Page generated in 1,713,252,473.04118 seconds with 21 queries
