Results 1 to 7 of 7
Thread: My Miller CST 280 won't turn on at all
    Jan 2021
    I bought this machine for 100 bucks through Facebook. The guy said he didn't know what is wrong with it. The machine will not turn on at all. I took the cover off and checked the fuses. The big cartridge fuse on top is blown. Will this fuse cause the machine not to turn on at all?
    Re: My Miller CST 280 won't turn on at all
    Quote Originally Posted by WelderAaron28 View Post
    It is possible but very unlikely. Most probably is that you have a cascade board failure. When the caps on the boards fail the fuse will blow. That is my experience with my inverter machines anyway. Mostly Miller AeroWaves(hybrid), and warrantied Dynastys.
    Jan 2021
    Thanks for the advice. My HVA-2 fuse will be here tomorrow. I have my fingers crossed.
    You might want to take some good hi resolution pics of the boards and their components to post up here... maybe we can spot a problem sometimes it's easy to see defects on certain components and get them fixed before you start burning up more!!!
    May 2007
    if thats the fuse that goes to the switch in the back under the metal door w/ two phillips screws to select b/t 220 and 480, id bet it would keep it from turning on.
    Tennessee
    Tagged CST280
    I just bought one on evilbay. Tested all outputs and thank God it all worked fine. My buddy said the local repair shop said these were pretty solid and bulletproof units. Most of the repairs are from dropping them from the lifts.
    "Stick-man"
  8. Likes ronsii, albrightree liked this post
  9. #7
    Big white fuse, I replace them with the PTC kit from Miller and you never have to replace it again. Fuse blows because the welder is set for 230 and 460 has been applied. The PTC was built into the newer units and the fuse removed.
Page generated in 1,713,269,927.69316 seconds with 20 queries
