Page 1 of 8 123 ... LastLast
Results 1 to 25 of 187
Thread: Welding Fixture Table
    I had been planning on building a new welding table for quite some time. I had a pretty good idea of how it should be but was (as usual) struggling somewhat with logistics.
    Since discovering the thread started by Rustyshackleford (Brett) I have been working with John from Texas Metal Works on a custom table with some unique features.
    I’m usually the type to build things myself but in this case.....My cost for locally laser cutting the pieces alone would have been considerably more than my entire purchase price having John build it.
    It has been a several month process incorporating my ideas into a buildable product from a manufacturing standpoint and John has been very patient with me. Hopefully my input will result in future welding table options/upgrades available from Texas Metal Works.
    Here are a few random photos taken during construction. The table size without extensions is 40” x 80” with a 1/4” table top braced from the underside to achieve and maintain flatness.
    A photo of underside. Note the 2inch square holes at each corner of the table. These line up with the oversized 3” square tube legs I specified to accommodate the 2.5” receiver tubing for four vertical receivers.
    Bolt on plates with custom slots to accommodate vertical receivers ...
    Heavy 11 gauge center mounted drawer with industrial slides ...
    To be continued.......
    Aug 2018
    'ta town, KS
    Re: Welding Fixture Table
    Nice little table
    Mac
  3. Likes William McCormick liked this post
    Quote Originally Posted by Mac's Crew View Post
    Nice little table
    I hope so. It just came out of the powder coat shop today. With a little luck they will ship early next week. I’m not holding my breath for a delivery date. It’s a long way from Texas to BC.
  5. Likes William McCormick liked this post
  6. #4
    Aug 2018
    'ta town, KS
    Well if it needs to rest for a couple years, I can give you my addy.
    Mac
  7. Likes leightrepairs, William McCormick liked this post
  8. #5
    Aug 2018
    'ta town, KS
    It is a long trip. HeHe
    Mac
  9. Likes William McCormick liked this post
  10. #6
  11. Likes William McCormick liked this post
  12. #7
    This is a pic of my welding table base (sitting on a welding table).
    I opted to delete the casters and add cross bracing to accommodate moving the table with a pallet jack. Adjustable height swivel pads will replace the casters and allow for levelling the table.
    The lower bracing also allowed for extra storage area. Initially I planned on two powder coated MDF panels mounted flush with the crossmembers so stuff could slide out easily but John from Texas Metals suggested black HDPE panels which dropped right in the cross bracing.
    No painting necessary or dealing with inevitable scratching. Plus totally moisture resistant.
    I had John laser cut and pedestal mount an intermediate shelf for storing sh*t but mainly for interest and aesthetics. Even had matching holes cut (but a few thou in diameter larger to allow for the paint).
    View from the underside of intermediate shelf showing streamlined gussets for the suspended pedestal look.
    And here’s a pic of the base with its special BLUE multi-coat powder process....
  13. #8
    Wow... that's going to look bright, even in your shop where there's a lot of shiny and bright. Sweeet...
  14. Likes ronsii, William McCormick liked this post
  15. #9
    Apr 2007
    Portland, OR
    Are you up for sharing cost prior to shipping?
    Looks great!
    Miller Syncrowave 180SD
  16. Likes William McCormick liked this post
  17. #10
    Quote Originally Posted by slodat View Post
    Looks great!
    If it helps. Keep in mind tables are shipped assembled.
    Might not be applicable as truck freight is based on deck space used. Unless they are able to double stack.
  18. Likes ronsii, William McCormick liked this post
  19. #11
    Apr 2007
    Portland, OR
    I’ve been looking at the 28mm tables from Build Pro and Seigmond. Interested in other options.
  20. Likes William McCormick liked this post
  21. #12
    I wanted mine nitrided but apparently no one in North America has tanks big enough.
    Most are done in Europe and Asia.
  22. #13
    It's BEAUTIFUL!!!!!!!
  23. Likes William McCormick liked this post
  24. #14
    GAWD THAT'S NICE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  25. Likes William McCormick liked this post
  26. #15
    Fredericksburg, VA
    It took a couple of seconds trying to figure this sentence out. At first, I couldn't see how you would drop 2-1/2" receiver tune into a 2" hole.
    I assume/remembered from some of your pics that you have a long section of 2" tube with a small collar of 2-1/2" tube welded to the outside to act as stop when you drop in into the hole. I am still on my first cup of coffee so I am a bit slow right now.
    Millermatic 252 MIG
    Miller Dynasty 200DX TIG
    Altas 12x36 Metal Lathe
    Bridgeport Milling Machine
    www.psacustomcreations.com
  27. Likes William McCormick liked this post
  28. #16
    Sorry Pat you're right. My attempt at describing the vertical receiver setup was unnecessarily wordy. You have probably noticed I have a bad habit of doing that ...
    IMO vertical receivers in the workplace are just so underrated. Their uses are only limited to one's imagination and the best part is they don't take up ANY valuable space.
    Here's an elevated offset swivel work table.
  29. #17
    And I thought you were going to whine about the color looking more purple than Miller blue....
    Nov 2019
    North East Ohio
    Amazing
  31. Likes ronsii, William McCormick liked this post
  32. #19
    And I thought you were going to whine about the COLOUR (color) looking more purple than Miller blue....
    Don’t you find it amusing how we deliberately misspell words so that we don’t look like high school dunces to our American friends?
  33. Likes whtbaron, ronsii, William McCormick liked this post
  34. #20
    Really amazing and I can't wait to see it in place, nestled comfortably amongst all your other goodies.
    I keep saying I'm going to rent a mag drill so I can make some holes in my bench. Gotta clean it first, though.
  35. Likes ronsii, Lis2323, William McCormick liked this post
  36. #21
    Feb 2015
    Texas
    That is a work of art Lis! Actually, from the photos you’ve posted your whole shop is a work of art! I’ve tried to keep a neat shop but usually after a full day I’m so worn out and sore the last thing I want to do is sweep up the shop.
    Miller 350 Dynasty
    Miller Trailblazer
    Miller 625 Plasma
    Died and needs a new circuit board so its an expensive boat anchor now
    Lincoln Power MIG
    Victor oxy/acetylene
    Hyperthem 85
  37. #22
    I've actually gotten so tired of Spelchek telling me I've spelled things wrong when I really spelled them right, that I've kind of joined them... I'm only 27 miles from the border...
  38. Likes ronsii, William McCormick liked this post
  39. #23
    Nov 2019
    North East Ohio
    Lis2323
    Your ears burning? I was at my LWS and a local company makes fixture tables. The sales man saw me standing there and put the press on. Damn they are neat
  40. Likes William McCormick liked this post
  41. #24
    Lis2323
    You guys are fortunate. In my area you’re lucky if an LWS even has a welding machine on their showroom floor.
    That is a bit of an exaggeration of course but not by much....
    What’s the plan? Acorn table? Build a fixture table?
    I think my table is being shipped today.
  42. Likes William McCormick liked this post
  43. #25
    Nov 2019
    North East Ohio
    My LSW is pretty nice.
    Still no plan on a table. I'm going to look at the those down the road I told you about. I do have this plan, no more gym equipment or I'm going to charge what I should charge. If they walk they walk. I try and stay under "Rogues fitness" price but I can not compete with a robot. If I lose work fine, I can work on the old car, do art and furniture. If I do art and furniture I'm will drop insurance. Plus the "maker space looks like its going to happen. I sold $22,000 worth of gym equipment but really did not net enough to amount to much. RANT OVER lol. I may send a PM about the art furniture world.
  44. Likes ronsii, William McCormick liked this post
Page generated in 1,713,290,850.52623 seconds with 18 queries
