Page 2 of 2 FirstFirst 12
Results 26 to 34 of 34
Thread: Lincoln SP175T DOA????
    Mar 2009
    Re: Lincoln SP175T DOA????
    Quote Originally Posted by rexcormack View Post
    Just wire one side of the 115 fan motor to LS1 or H2 (doesn't matter) and the other side to case ground.
    I can't believe I didn't think of that
    Is this for real or are y’all yanking my chain? I haven’t let any magic smoke out yet and I’d like to keep the genie in the bottle.
    Quote Originally Posted by Pipeliner View Post
    240v is made from (2) 120v lines..... with respect to neutral... or ground depending on how you look at it so instead of hooking the fan up to the 2 - 240v lines you only hook to 1 of them and get 120v... but you are now returning to ground instead of neutral....
    ps. Ignore the L1 , L2 stuff... this is just an internet pic for illustration purposes
    Mar 2009
    Quote Originally Posted by Dan View Post
    You might consider looking in to whether or not there is enough room to fit a fan for a Hobart Handler 190 inside the machine. It would give you the 230 volt input fan and 24 volt AC output too.
    Those do look very similar in size. I wish I could compare them side by side.
    Oh well, I've ordered the 220/120 transformer and 115v fan. Hopefully by this weekend I can put it back together.
    Dec 2008
    Yes I'm serious. Many household appliances use this approach like the timer in you electric dryer or the clock in the electric oven in your kitchen.
    Here in North America 240vac is just 2 115vac lines that are 180 degrees out of phase from one another so either side of the 240 is 115 with respect to ground.
  5. Likes ronsii liked this post
  6. #30
    Jan 2008
    Richmond, Virginia
    Are you recommending using the case ground as a current carrying conductor (neutral)?
    Syncrowave 250 w/ Coolmate 3
    Dialarc 250, Idealarc 250
    SP-175 +
    Lincwelder AC180C (1952)
    Victor & Smith O/A torches
    Miller spot welder
  7. #31
    Dec 2008
    For milliamps yes.
    10s of millions of home appliances, industrial equipment and even welders were wired this way before the code changed to require a 4 wire cord.
    Is it the best way to do it, no but in this one instance it would be fine.
    Besides Pipeliner has already ordered an isolation xformer which is the best way to repair it.
  8. Likes ronsii liked this post
  9. #32
    Mar 2009
    Thanks to all who contributed..........it turns and burns once again.
  10. #33
    Jun 2009
    Draper, UT
    For milliamps yes.
    That's how I added a 120v outlet to my Tig cart to run the Tig Button..
    MillerMatic 252, HTP 221 w/cooler, Hypertherm PM45, Lincoln IdealArc 250 AC/DC, victor Oxy/Acet
  11. #34
    Dec 2022
    Hey man, which transformer did you end up using and is she still holding up? I am exactly in the same boat as you were. Sucks Lincoln doesn’t offer any solution to this problem. I already got the 110 fan. Let me know thanks
Page generated in 1,713,266,814.29786 seconds with 19 queries
