Results 1 to 5 of 5
Thread: Helmet question
    Feb 2017
    Texas
    Helmet question
    Hey all,
    Used the search function, but I don't see my particular issue so I am asking.
    Home welder. MIG, Stick, TIG and do some plasma cutting.
    I currently have a Miller Digital Infinity the at I use. I like it OK, but in weld and X mode it seems to take a long time to transition from dark to light when I am using the stick. What I mean is that when I strike, the lens goes black and remains that way for probably 1-2 seconds. Tough to weld anything if you can't see the work.
    When plasma cutting in cut mode, it will randomly go to full dark for a second or two then back to shade 5 which is the lightest cut setting.
    I have changed batteries, cleaned the sensors on the front and changed front plastic for new. Is this just a Miller quirk or do I have a bad lens.
    I bought it used for $125 about a year ago, so if it's time to replace, so be it. I never get flashed doing MIG or Stick. Too new at TIG to know if it does it. Have played with sensitivity and delay with no success.
    Neighbor has a like new Speedglass 9100XX! for $200. Should I just go to that?
    Thanks,
    Steve
    Sep 2005
    Cave Creek AZ
    Re: Helmet question
    That is not the way mine works. Sounds like you need a new lens. Might give a try calling miller tech support. First maybe try dialing all the delay and sensitivity setting to minimum and then maximum to see if it has any effect. Personally, I only use X mode outdoors, and I almost never use grind mode.
    Jul 2018
    Cumbria, UK
    Re: Helmet question
    The delay timer is specifically for the time it takes to go from dark to light. If its not making any difference then it does sound like there's a problem
    The Speedglas 9100XX is a very, very good hood, its very ergonomic, and very durable too. Industry-standard over here for MIG, TIG and stick, especially in air-fed versions.
    The newer XXi filter is true colour and brings it up to date with the latest tech from Optrel, Viking etc.
    Los Angeles
    Re: Helmet question
    the Speedglass would be a good deal since a replacement lens for the Miller is more than $200.00 :0
    MM211 (Sold)
    Klutch 120v Plasma cutter
    Feb 2017
    Texas
    Re: Helmet question
    Bought the Speedglass. Will try that later today.
Page generated in 1,713,287,031.03634 seconds with 17 queries
