Results 1 to 25 of 35
Thread: Table saw as a welding table
    Dec 2020
    I have yet to fire up my YesWelder MIG-205DS and since I'm a total n00b and will just be practicing with fluxcore and all the sub $250 tables seem to have issues of one sort or another, was thinking about holding out for a non working steel top table saw on craigslist. Some have slots, etc. that could be used for clamps and the like.
    Workable idea or should I take up knitting?
  2. Likes Shootr liked this post
  3. #2
    Fredericksburg, VA
    Re: Table saw as a welding table
    It is a very workable idea. If you can find an old cast iron one, they are great. They are typically very flat, strong, and have slots or webs so you can insert a clamp.
    Edit:
    Here are some pics of saws for sale near me. They have solid top and ones with webs. Since some are cast, you have to be careful clamping too hard or finding a spot that is flat on the underside for the clamp.
    Millermatic 252 MIG
    Miller Dynasty 200DX TIG
    Altas 12x36 Metal Lathe
    Bridgeport Milling Machine
    www.psacustomcreations.com
    Los Angeles
    I have one of these as an extra to my regular welding table, and yes it is thin gauge, but it does quite nicely.
    beats welding on the floor.
    $69.00 at HF.
    MM211 (Sold)
    Klutch 120v Plasma cutter
    Sechelt, BC
    I have that Craftsman iron saw for my table, mine's on casters. It works great in a small space and the work clamp can go anywhere on it. Just trying to figure out how to add a vise...
  6. Likes Lemarque liked this post
  7. #5
    Quote Originally Posted by Lemarque View Post
    I think that would be totally doable, but I’d take up knitting also just to cover all bases....
  8. Likes ronsii, psacustomcreations, tackit liked this post
  9. #6
    Soda springs,Id
    Buy the 2-1/2" hitch receiver that bolts under the bumper and mount it under the table. Then buy some 2" x 3/16 sq tube to fit in it and build a vise mount to weld to it. I also made a mount for my bench grinder so it and the vise can interchange.
    Ol' Stonebreaker
    Hobart G-213 portable
    Miller 175 mig
    Victor O/A setup
    Makita chop saw
  10. Likes Lis2323, ronsii liked this post
  11. #7
    Or you could buy a working table saw, and build a removeable steel cover/top to put on it...
  12. Likes ronsii, tackit liked this post
  13. #8
    Actually that's not a bad idea.
  14. Likes ronsii, Lemarque, tackit liked this post
  15. #9
    How ironic. There's a guy over on the Fine Woodworking Forum looking for a cheap table saw.
    Can't find one but sees a couple of welding tables on Craigslist. He's considering cutting a slot in the top and mounting a saw blade arbor and motor underneath....
  16. Likes 12V71, ronsii, whtbaron, ccogg, wb4rt, MinnesotaDave liked this post
  17. #10
    Our first "table saw" was a Black and Decker with a broken guard screwed to the underside of an old wooden dining table. Wired the switch on and used an on/off switch on the table leg. Worked alright except for the worn bearings in the hand saw.
  18. Likes Lemarque liked this post
  19. #11
    Dec 2020
    Just what I had in mind. But in my neck of the woods they're referred to as 'vintage'. A guy want $500 for this //edit - can't seem to upload an image
  20. #12
    Dec 2020
    Considering that one if all else fails.
  21. #13
    Dec 2020
    I've got an add craigslist for someone to hold the yarn
  22. Likes farmersammm liked this post
  23. #14
    Dec 2020
    Great Idea! I'll check the junk yards.
  24. #15
    Dec 2020
    True story - a few years ago I bought a decent table saw for a project I had in mind. After getting all the doodad's, one night at dinner my wife says - " Don't cut your fingers off"
    I sold it on CL the next day.
    Yes, I'm superstitious.
  25. #16
    Dec 2020
    I'm not sure how this forum works; if I'm top posting or what. But anyway, great minds think alike.
  26. #17
    If you are replying to a specific post, sometimes it helps to use the "reply with quote" button instead of straight reply, so people know which post you are referring to....you'll catch on.
  27. Likes ronsii liked this post
  28. #18
    Agreed. the "great minds think alike" comment could refer to all of us (almost)
  29. Likes ronsii, Lemarque liked this post
  30. #19
    Dec 2020
    Before this post finds its way to the bit bucket...
    Using this table purely as an example:
    https://www.amazon.com/dp/B07QYQRZN2...v_ov_lig_dp_it
    Where would one find the welding fixtures like those that come with
    //edit This site looks reasonable:
    https://fireballtool.com/search.php?...ection=product
    https://www.amazon.com/dp/B00D3JKUQE...v_ov_lig_dp_it
    Easy enough to find welding clamps at HF but nothing anywhere that's affordable for 16mm holes. I've looked at a Grizzly table that's in my budget but they want $115 for a swing clamp!
    Going to give myself another week to find a used table saw but as an example, there's one on CL for a nice 15 year old Craftsman however they want $425 which as I understand it is more than they cost new back then.
    In closing I really like the Strong Hands https://www.amazon.com/dp/B00D3JKUQE...v_ov_lig_dp_it
    and if I can ever sell an item I have on CL, I'll probably pull the trigger on that.
  31. #20
    Apr 2016
    CA
    A quick look at the last link you provided for the strong hands table listed on amazon shows a very if not exact copy of that table made by the same manufacture in China for a Clutch table
    The strong hands table is made in China check the questions customers ask.
    Here is the Clutch table for half if not cheaper than the strong hands table you linked. It’s your money.
    https://www.amazon.com/Klutch-Steel-..._t1_B00D3JKUQE
  32. Likes whtbaron liked this post
  33. #21
    And very similar to the one Princess Auto has on sale up here this week for $250 Cdn. for the bare table.
    https://www.princessauto.com/en/24-x...t/PA0008663833
    Shoot. Even when you add in currency exchange PA retails for more and still has the accessories kit to upsell you.
  35. Likes Lemarque, whtbaron liked this post
  36. #23
    Dec 2020
    Well N2, tag your it.
    With $20 coupon I found online and joining their 'club' for $39.99 = $215.47 tax included and shipped free 'cause of the membership. Minimal savings over AMZ but now I'm a member of a CLUB
  37. #24
    Dec 2020
    Thanks but I've fudged around long enough and pulled the trigger on the Klutch.
    A n00bs gotta start somewhere/sometime
  38. Likes whtbaron, ronsii liked this post
  39. #25
    And it looks like they will export into Canada... didn't try to order though.
Page generated in 1,713,256,451.83581 seconds with 19 queries
