Results 1 to 8 of 8
Thread: Electrical connection
    Nov 2020
    The electrical plug for the mig gun is not getting a good connection. Ever so often the connection will lose the connection.
    Any suggestion of what I can do without having to replace it? I have a Millermatic 140.
    Nov 2013
    Re: Electrical connection
    What do you do to fix that "bad connection"?
    Is this in the plugs receptacle or in the plug itself that you think it's happening?
    Los Angeles
    I'm not sure how it could lose connection at the machine side as it locks in place.
    perhaps a loose connection inside the gun at the trigger.
    You can open it up and check.
    MM211 (Sold)
    Klutch 120v Plasma cutter
    Nov 2020
    When it stops working, I unscrew the connection take it out and put it back in. Fixed the problem, may have to do it more than once. That is why I think its in the connection to the welder rather than out at the gun.
    Aug 2019
    northeastern PA.
    what connection are you referring to? Is it where the whip slides into the machine? If so, do you have it all the way into the seating area and the retaining bolt tightened? Are all of the wires inside the cabinet clean and tight? Is this a new machine or new to you? Does this situation happen after any particular operating time frame?
    Jun 2017
    AJO, ARIZONA
    put some pressure either up or down with a bungee cord & see if it fixes it t
    hen at least you'll have it narrowed down some.
    UNITWELD 175 AMP 3 IN1 DC
    MIDSTATES 300 AMP AC MACHINE
    JEFF
    Big Lake/Monticello MN
    Jiggle test.
    Next time it won't go, keep finger on the trigger and wiggle wires until you find where the problem is.
    Syncro 350
  8. Likes ronsii, Burning Rods liked this post
  9. #8
    Ceres, California
    one of three things, first the trigger wire is broken inside the plug.
    remove the cord clamp and unscrew the back shell. see if the wires are broken or twisted up. the pins are replaceable, but it take special tools. a pin extractor and a AMP pin crimper. plus new pins. some times the pins do push back into the plug.
    you can carefully pull the pin back out and lock it is place. If plug and wire are damaged you can buy from Miller a new trigger cord that is a short cord with the plug installed. You just open the miggun back handle and butt splice the cord to the old wires inside and close up the handle. Looks like new.
    Third problem is a problem with the receptacle. the socket could be push in or damaged so it is to large to contact the pin. You can try pushing it from the back side into the correct position. for to large you can some times use a very small screw driver and shrink the socket so pin makes a good connection.
    Use an ohmmeter and test pin to pin on the trigger plug. should be open then closed when trigger is pulled. When you see the closed circuit. move cord around and see if it is broken.
Page generated in 1,713,261,476.44250 seconds with 18 queries
