Closed Thread
Results 1 to 25 of 41
Thread: Yesterday afternoon I taught myself to mig aluminium.
    Jan 2021
    Yesterday afternoon I taught myself to mig aluminium. The key was finding the right volts, wire feed, stick out, speed and watching the heat build up, that had me stumped for a bit, wondered why each successive run was worse than the last - heat build up!. Stick out was a bit excessive when starting as you can see, but not too bad considering. Oh, a steady hand also helps, but that's beyond this old codger now, hence the wobbly runs. As a test, after welding an external edge joint, I ground it down flat then belted the hell out of it trying to separate the joint, distorted the hell out of the metal before it split. Not too bad for an hour or so practice. A whole new world of aluminium fabricating has opened up now, should have taught myself to weld aluminium year's ago. Talk about messy though, splatter everywhere and plenty of black soot, higher gas pressure me thinks. And I burnt the crap out of my arm from flash, the flash is 10 times brighter than when welding steel.
    Quick reply to this message Reply
    Dec 2016
    Re: Yesterday afternoon I taught myself to mig aluminium.
    are those crocks osha approved?
  3. Likes ronsii, G-ManBart, rhunt liked this post
    Jan 2021
    Yep! Safety crocks.
  5. Likes ronsii, farmersammm liked this post
  6. #4
    Mar 2014
    Congratulations, you now know NOTHING other than the effects of UV radiation. keep wearing those shoes. Soon, a big ol' berry will make you discover a new dance move. Maybe of a youboob M. Jackson quality. You may have a heretofore undiscovered talent.
  7. Likes jeverich liked this post
  8. #5
    Sep 2014
    Quote Originally Posted by Yofish View Post
    In high school shop class our instructor was an old codger who had zero tolerance for shenanigans or failing to adhere to clearly defined safety gear and dress. One day this guy shows up in shorts and sandals, so what does teach do? Puts the guy on the cutting torch burning out blanks for one of our projects. Guy had boots, jeans and a denim shirt on every day for the rest of the year.
    They’d fire and jail the teacher these days.
  9. Likes Munkul, mcspeed liked this post
  10. #6
    Jan 2021
    When I started work in a metal fabrication business in the mid 60s, there was no PPE: no glasses, no gloves, we all wore shorts and short sleeve shirts, about the only nod to safety was boots, not steel caps either as I don't think they were even available then. And we only wore boots because they lasted longer than tennis shoes. Wrap yourselves up in cotton wool all you like, I'll keep going as I have for the last 55 years.
    When I served in the RAAF as a police dog handler, I had half my left tit ripped off, 15 stitches worth, still have the scar 45 years on. I had a 50c size chunk ripped out of my arm, and later on spent two weeks wrapped in bandages from shoulder to finger tip on both arms after being mauled. We didn't have PPE then either, no ear protection on the range, no full padded suit when being attacked, just a padded arm protector and some fancy arm and foot work, and you know what, I still went to work, still trained dogs, still got bitten and still have all my fingers toes and skin. And most importantly, in my 70th year I have no regrets!
    Pussies!
  11. Likes Dave66, bfjou812 liked this post
  12. #7
    Jul 2018
    Cumbria, UK
    Not bad looking beads it looks like you're still getting some spatter, perhaps turn the voltage up a bit more.
  13. #8
    Jan 2021
    Yeah, it's all a matter of trial and error.
    This is the dog that put me in bandages for two weeks, still wear the scars 45 years on. RIP PD576 Dante. No PPE back then!
  14. Likes mcspeed liked this post
  15. #9
    Mar 2012
    Australia
    Quote Originally Posted by hovasacc View Post
    Pussies!
    I know many blokes like you with 9 fingers or 1 eye, and know of many more that are dead.
  16. Likes Munkul, mcspeed, Shootr liked this post
  17. #10
    CT
    are you pulling or pushing those beads? Looks to me like maybe you are pulling. You will get much better results if you push the bead (keeping the argon gas pointed out in front of the puddle). Are you using pure argon? There shouldn't be that much spatter.
    Miller Multimatic 255
  18. #11
    Laredo + Midland/Odessa
    To add to that, it looks like you need a larger nozzle and more gas flow. 40-50 CFM with a 3/4" nozzle is not out of the question. Makes a HUGE difference in the cleanliness. But perhaps you are using 5356? It is definitely sootier than 4043 due to magnesium.
  19. #12
    Nov 2014
    PDX PNW
    I’m pretty sure he learned a few things about welding also but your to arrogant and negative to talk about the welding part. You just wanna belittle him to cover up the problems you have to make yourself feel better
  20. Likes bfjou812 liked this post
  21. #13
    Nov 2014
    PDX PNW
    I think it looks pretty good. Try a very straight gun angle towards Your weld joint and that should help with the black. I used to have almost no black when running the spool gun we had and the lines and gun had big leaks
  22. #14
    NW New Jersey
    What welder do you have ?
    Spoolgun or liner, volts and wirespeed, type and dia. wire, gas and flow, type and thickness of plate. The guy in this other thread is probably dying to know.
    https://weldingweb.com/vbb/showthrea...luminum-tubing
    Last week I was mig welding some heavy aluminum, and lit the paper towels someone had dropped under the bench on fire. Lifted my hood, and saw more smoke than I should have. Those little aluminum balls make such a mess too.
    Cheers.
    Miller Synchrowave 180 sd
    Miller Econo Twin HF
    Lincoln 210 MP
    Dayton 225 ac/dc
    Victor torches
    Snap-On YA-212
    Lotos Cut60D
    Primeweld 225 ac/dc
    Primeweld mig180
    Miller AEAD-200
  23. #15
    Jan 2021
    And yet I have 10 fingers, 10 toes, two eyes, all my skin and, I'm still alive at 70. No cotton wool overalls in my shop, I just do the job.
  24. #16
    Jan 2021
    I have a Unimig 180, no spool gun, tossed the teflon liner in favour of the standard steel one. I'm using .8mmm 5356 wire with nozzle drilled to 1mm. I've had the gas set on everything from 10 - 25. Don't know the volts or wire feed off hand, I'll have a look after my morning coffee.
    Pushing rather than pulling and I have a tapered nozzle of around 10-12mm, I'll try a larger nozzle, that sounds reasonable, although fillets might be a problem with a larger nozzle.
    I welded some 1.5mm ally plate with out any problems and yet I've read 3mm is the thinnest recommended???
    The project: Welded the seat pan together, tail light bracket, exhaust pipes and bracketry and header clamps and some tabs on the frame. Currently making a polished aluminium battery box and rear guard, hence the ally welding. Also fabricated the headlight brackets, upper and lower engine brackets, pipes, pipe brackets and clamps. Not too much has been left standard. paint job came up well too.
  25. Likes bfjou812 liked this post
  26. #17
    "Yesterday afternoon, I taught myself to MIG weld Aluminum" is gonna draw some ire.............especially if the stuff yer doin' isn't pristine. Learn to be sorta humble, and it goes a long way.
    I mean........it looks ok (I don't do luminum), but I've seen better. And, if it was steel...........I'd scream FOUL.
    Caveat...............I'm slowly going blind in my left eye, so I can't really say that my crap is gonna be up to par from this point on. So, I can't really cast stones too much.
  27. Likes Lis2323 liked this post
  28. #18
    Jan 2021
    Only from fools. Where did I say my aluminium welding was excellent, didn't even say it was good, only that I'd taught myself how to weld aluminium. That means, I read up on it and practiced until I could run a bead. I didn't even say the bead was excellent or good, only that I'd taught myself how to weld aluminium. Over the years I've also taught myself how to paint, how to polish aluminium, how to fabricate metals, how to fix engines, how to sail, how to abseil, how to do lots of things, is that going to draw some ire as well. You people aren't just a lot of pussies, you're also foolishly egotistical and pretentious. Funnily enough you only get this sort of nonsense on American sites.
    For someone who can't really cast stones too much, you're doing an excellent job!
  29. Likes bfjou812 liked this post
  30. #19
    Jul 2018
    Cumbria, UK
    You could wind your neck in a bit... we're all friends here, but you have to learn to take criticism in a positive light
    That doesn't make you big or clever, does it? It just makes you lucky.
    There's a few professionals on here, and THEY didn't make it to this point in their lives by being lucky. They made it by starting humble, learning how to do a job whilst balancing safety/speed/quality, and wearing the sensible equipment when required.
  31. Likes Lis2323, 12V71 liked this post
  32. #20
    Mar 2005
    Under a Rock
    Only from fools. Over the years I've also taught myself how to paint, how to polish aluminium, how to fabricate metals, how to fix engines, how to sail, how to abseil, how to do lots of things !
    Wow
    Can you post show & tell pics of All your achievements in life?
    We are all waiting on the edge of our seats.
    Hypertherm PM 45
    1961 Lincoln Idealarc 250
    HTP 221
  33. #21
    Mar 2005
    Under a Rock
    Only from fools.
    You people aren't just a lot of pussies, you're also foolishly egotistical and pretentious!
    That’s not a very nice thing to say.
    Hypertherm PM 45
    HTP 221
  34. #22
    Wow
    I think we should compare scars! GRRRRRRR WOOOF!
  35. #23
    Apr 2020
    pekin, IL
    Gotta love social media, in whatever platform.
  36. #24
    Big Lake/Monticello MN
    Are you welding in spray or short circuit? Spray transfer is what you want for aluminum mig.
    Also as mentioned above, push, not pull.
    Syncro 350
  37. Likes shovelon, flushcut liked this post
  38. #25
    Jan 2021
    5356 wire leaves a black soot due to magnesium content and spray transfer requires at least 25 volts and is only good for thick material. My welder tops out at 25 volts and the material I was welding was 1.5mm and 3mm thick. It appears you all missed those two little facts. So much for all the expert opinions.
    Perhaps you should all consider different vocations, welding is just not your thing apparently. Then again, you are Americans, the people who voted in a lunatic and then ransacked your own capitol building.
  39. Likes Insaneride liked this post
Closed Thread
Page generated in 1,713,243,005.90137 seconds with 19 queries
