Results 1 to 25 of 27
Thread: Welding Deep Fryer Baskets
    Jan 2021
    Hey All,
    I own a restaurant and my cooks are constantly breaking my Deep fryer baskets. The baskets cost $120 ea new and that is a cost i don't need with the state of things for restaurants currently. I bought a welder and learned how to weld a few years ago so that I could fix other pieces of equipment that kept breaking. Do you know if I can use 316L wire to Mig weld the fryer baskets and it will be safe to be used in a fryer? I don't think regular wire is food safe, and I have heard 316L is, but any help would be much appreciated.
    Re: Welding Deep Fryer Baskets
    316 would be right. Getting the grease off will be another story.
    Mig? The fryer baskets I have repaired were thin wire. I typically TIG. The ones i repaired broke from repetitive flex when they hang them or shake them while hooked.
    You might get multiples repaired for the price of one. One less thing for you to do.
    Good luck
    Aug 2006
    St. Paul Park MN
    I have done 6-8 of them and they are a pain to do even with TIG. A time consuming pain.
    Mount Tabor VT
    I'm not clear if you are talking about MIG or TIG.
    I would say research what your baskets are made of. Ignorant, I'd guess 304. If you can learn the numerical compound of the baskets, we can intelligently address the filler.
    I believe this is absolutely a TIG job.
    Rule of thumb has always been "Use a filler numerically higher than the stainless you are welding."
    I might ignorantly try 308L, see how it holds up.
    I doubt there is anything toxic in any stainless filler. The two risks with stainless are:
    Oxidation Will oxidation allow bacteria to harbor in the not smooth surface?
    Sugaring whenever you heat stainless above a given temperature, it will rapidly oxidize. As most stainless welding is under shielding gas, there is less risk on the face where
    welding is happening. Back side sugaring is a big concern. Too much bacteria growth happens in the nooks & crannies of sugared stainless.
    When you TIG stainless, a great many things could go wrong. Most often the failures are bad gas coverage. The weld must be gas protected front & back of surface. It must remain gas protected until cool.
    Wrong filler is another fail. Most of us either research the required filler, or guess, using a higher number than the material being welded.
  6. Likes shovelon liked this post
  7. #6
    Generally 316 is used for food service. I would think the baskets are resistance spot welded. You could see if there's a manufacturer of welded wire mesh products in your area that has a spot welder. Food grade silver solder might be a good option as Mig or Tig could be tricky to do.
  8. #7
    Sep 2005
    Cave Creek AZ
    It would be easier to train your cooks.
  9. Likes filetobeef, 12345678910 liked this post
  10. #8
    If anything like the basket I repaired and from normal use, then It is a design /function issue. Stainless eventually work hardens and fractures.
    Zblue since they are yours, perhaps youn could address the failure issue.
  11. #9
    Apr 2018
    Montana
    Just a few questions to help flesh this skeleton out... Pictures would help immensely too. What part(s) on the basket are breaking? The mesh? The handle? The corners? Connection points? Spot-weld failures? Is the basket the wire mesh or the perforated metal style? Can the basket be "upgraded" to be better suited for the use and abuse it sees on a normal basis? Is the crew bashing it against something when emptying it and that's when the problem occurs, or is it out-of-the-blue while in or out of the fryer? Is it better for the basket to be the weak leak or the thing the basket is getting smacked against (possibly to empty it???)?
    One would think a person could get some perforated stainless sheet, trace out a foldable basket, brake-press into shape, TIG/MIG/Spot overlaps, attach a handle (if not incorporated in design), and come up with a pretty heavy duty use basket. Something that could be pretty bash-resistant, 200lb gorilla proof that would damage the thing hit rather than the basket... Might have to be careful what we wish for here. :-P
    Lincoln 140HD solid .023 and 75/25% Ar/Co2 or 100% Co2
    Lincoln SP-140T innershield .03 or Aluminum spool gun
    Dayton 230A AC Stick
    Harris Oxy/Ace torch setup
    Chicago Electric Stud Welder
    LTP 5000D Lotos 50A Plasma
    Vulcan Protig 205
  12. #10
    Apr 2010
    Zblue
    Years ago, I did - major structural, glass over bars, art signage
    . . . and repairs 'after a Major Muscle Night . . .
    I was eventually/constantly asked to repair S/S in the kitchen.
    I feel your pain . . . Fry Basket fractures were frequent . . .
    Your supplier is not the manufacture - they only sell . . .
    The manufacture is so far removed from the end-user he never
    hears feed-back . . . and doesn't care . . .
    They give Engineering Awards for A Better Mouse Trap - but no
    one cares -about a better Fry Basket . . .
    The manufacture sells more - the supplier sells more - and you
    'benefit from this symbiosis' . . . ?
    I, no longer repair - but my Client Base still asked - what to do,
    and where to go - for Remedy . . .
    From new - fry baskets come from a highly specific tooling shop,
    due - to their etherial components necessary for function -
    Fractures/failures are not easily repaired - You have two options,
    buy a higher quality produce [if available] or . . .
    Preemptively reinforce the the fracture areas before you put them
    in service . . . this is probably beyond your ability . . . due to the
    skill level necessary for Sanitary Welding . . .
    In short: you are screwed - without special/intense weld training
    you will have to outsource = more expense . . .
    If you can - buy a better product . . .
    hth
    Opus
    Last edited by OPUS FERRO; 01-21-2021 at 01:29 AM. Reason: . . . 24.5 minutes of buffering . . .
  13. #11
    Sep 2005
    Cave Creek AZ
    Tell your cooks you have 500 bucks to give them as a bonus every 6 months, but fryer baskets have to come out of that pool of money.
  14. Likes Welder Dave, 12345678910 liked this post
  15. #12
    CT
    Also make sure you aren't dealing with nickel plated fry baskets. That adds another layer of complexity that you don't need.
    Syncrowave 250
    Purox Metalmaster
  16. #13
    I would look on internet for lower cost.
    https://www.webstaurantstore.com/13-...xoCf78QAvD_BwE
  17. Likes filetobeef liked this post
  18. #14
    SoCal-LA
    Quote Originally Posted by Zblue View Post
    Hey All,
    You would have to buy or rent a special bottle of TriMix gas to mig weld stainless steel or StainMix if your LWS has it. That may be a cost breaker for you as I would never mig weld SS fryer baskets.
    What I would do is buy a few more baskets, rotate them in, and when you have some broken ones take them to an experienced (308 or 316 filler) SS tigger to repair weld under their minimum charge. I do 3 or 4 basket repairs for the local eateries under my minimum charge of $40. I would think your tigger could repair yours for some $20 each.
    I had a Chinese restaurant with antique implements, knives, spatulas, ladels, fry baskets, ect. that was bought in the depression and used for decades. When they broke they brought a box full over. I spent the time to repair and they even gave me food vouchers for tips. Our families became close but sadly the family died off or moved on and the restaurant closed.
    MillerDynasty700DX,Dynasty350DX3ea,Dynasty200DX,Li ncolnSW2002ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig4ea,MigMax1ea.
  19. #15
    Mount Tabor VT
    In an early stage of seek advice, try that, my son wanted to repurpose beer kegs for various beermaking equipment. The local Airgas manager was enthusiastically providing information. I made a stab at MIG stainless. It was a failure!!!!!
    I later traded my Try Mix tank for a helium tank. Once you go pink, you won't go back!
    If I put more effort into MIGging stainless,...don't know, maybe it could be done. TIG is absolutely the process you will use if, and when you reach success.
  20. #16
    Soda springs,Id
    Don't know about handling food products but no one has mentioned O/A and brass with a small tip and small brass rod.
    Ol' Stonebreaker
    Hobart G-213 portable
    Miller 175 mig
    Victor O/A setup
    Makita chop saw
  21. #17
    Can you get stainless steel rods for O/A welding? Thanks
  22. #18
    Soda springs,Id
    Don't know if it's made and not sure how well it would work with gas welding.
    Ol' Stonebreaker
    Miller 175 mig
    Victor O/A setup
    Makita chop saw
  23. #19
    Mount Tabor VT
    I'd be pretty surprised if it works well. Stainless is pretty tricky about gas coverage & more so about excess heat. It must be surrounded by argon, or helium until cool or you get some bad oxidation.
  24. Likes whtbaron liked this post
  25. #20
    You can get food grade silver solder. Wouldn't require actually melting the stainless but would be very strong and easier to control heat. Would take a little practice though.
  26. Likes tapwelder liked this post
  27. #21
    Does silver bridge gaps? Are the silver fillers that will bridge. I habitually only use 45%.
  28. #22
    Interesting there is a flux especially for oxy act welding stainless steel
    https://www.tinmantech.com/products/...lding-flux.php
  29. Likes tapwelder liked this post
  30. #23
    That reminds me. I have not seen my can of Solar Flux in forever.
  31. Likes LtBadd liked this post
  32. #24
    I would think on a deep fryer basket you'd be able to clamp it together. There are some silver solders that will fill gaps better than others.
  33. #25
    Sep 2015
    West coast of Florida
    The Harris 45T is good for that
    SAFETY-SILV®45T
    Performs like a 45%
    silver, cadmium-bearing
    alloy. Lower melting
    temperature than SafetySilv® 45. Excellent
    fillet forming qualities.
    Produces high-strength,
    ductile joints. Listed with
    NSF 51 listed for use with
    food equipment materials
    Richard
  34. Likes whtbaron, ronsii liked this post
Page generated in 1,614,494,292.66201 seconds with 12 queries
