Results 1 to 25 of 35
Thread: Miller Dialarc 250, Minneapolis, $275 obo
    Sebeka and Bemidji MN
    70's model Dialarc, nice welding machine. Welding leads are possible with some negotiating
    $275 obo
    (218) 556-3316 (cell)
    dmjweldingmetalwork@gmail.com
    Syncro 350
    Re: Miller Dialarc 250, Minneapolis, $275 obo
    Syncro 350
    Anybody looking for good proven welding machines, these are fire sale prices. Don't wait or they will be gone.
    Jan 2008
    Richmond, Virginia
    Nice and good price, less than $1/lb.. I have one just like it from 1974, one of the earliest ones made with an HD serial number.
    Syncrowave 250 w/ Coolmate 3
    Dialarc 250, Idealarc 250
    SP-175 +
    Lincwelder AC180C (1952)
    Victor & Smith O/A torches
    Miller spot welder
  5. Likes MinnesotaDave liked this post
  6. #5
    HD is 73. First year they used the letter date codes. J codes for the 80's start at JA for 1980. Funny Miller doesn't use I in date codes. Maybe so it doesn't get confused with a 1?
  7. #6
    Jun 2014
    Southern Illinois
    They are great machines for sure. I had one for several years then back to a Lincoln Idealarc250. I’m just a Lincoln guy I guess, both machines are better than I am. Lol.
    Steve
    Miller Dialarc 250 (1990)
    Miller Maxstar 140 STR (2003)
    Lincoln MP210 (2015)
    Victor and MECO torches
  8. #7
    Jun 2014
    Southern Illinois
    I found this picture of mine. It was a 1980 Blackface. I had the custom tread plate hood made for it. Smooth welding machines
    Steve
  9. #8
    They did a great job on that top
    Syncro 350
  10. #9
    Sep 2016
    Detroit, Michigan
    Wow, that's a steal! I haven't seen a decent one under $500 in quite some time.
    http://mivise.com
    Millermatic 350P
    Spoolmatic 30A
    Hobart Champion Elite
    Everlast PowerTig 210EXT
  11. Likes MinnesotaDave liked this post
  12. #10
    Jan 2008
    Richmond, Virginia
    The manual for mine is dated Nov. 74. Mine is the next number from the starting number. I haven't seen any earlier manual.
    SP-175 +
    Miller spot welder
  13. #11
    That's likely just a later version of the manual and the machine hasn't changed from late 73 models.
    https://www.millerwelds.com/support/serial-number-chart
  14. #12
    Jun 2014
    Southern Illinois
    The first ones were white face with little rectangular holes in the front panels instead of the louvres
    Steve
  15. Likes MinnesotaDave liked this post
  16. #13
    Jun 2014
    Southern Illinois
    Like this
    Steve
  17. Likes MinnesotaDave liked this post
  18. #14
    How much for the machine with leads and everything? Also how much does it weigh?
  19. #15
    Quote Originally Posted by Noidea87 View Post
    The plug is wired up and it's ready to plug in and weld. Test it any time.
    Weight is around 350-375 lbs as I recall - it's an industrial machine.
    Leads depend on what you want.
    Light duty leads aren't very expensive and this set goes to 200 amps at 100% duty cycle.
    Which means you won't overheat them even at max with this machine.
    https://store.cyberweld.com/howecase...rce=googlebase
    If you want heavier/longer leads, I can include them, but they can get expensive depending what you want.
    Syncro 350
  20. #16
    Thanks for the quick response. I'd have to ship it so unfortunately that weight rules it out for me. I didn't realize how much those things weigh.
  21. #17
    Aug 2012
    AR
    If you are anywhere near Dave, it would be worth the drive. Go on a "field trip" as my wife often says.....
  22. Likes MinnesotaDave, ronsii liked this post
  23. #18
    I'll include a set of 25' 1/0 cables for package price total $395.
    Wired up, ready to plug in and work
    Syncro 350
  24. Likes whtbaron liked this post
  25. #19
    Mount Tabor VT
    I sold a Dialarc 250HF to a fellow in Ohio?, if I remember. Mine included a TIG outfit along with cooler & 50' leads. It sticks in my mind it cost $190 to ship. Guy was here, called himself Tuscany. Maybe his memory is more accurate.
  26. #20
    From what I've seen, that's as good a price as one is likely to get.
    The Fastenal company has store-to-store shipping that is tough to beat as well.
    Syncro 350
  27. #21
    What is your zip code? Maybe I'll get some shipping quotes
  28. #22
    Mount Tabor VT
    A SWEET welder from a reputable seller. I don't need it, but I'm tempted.
  29. Likes MinnesotaDave liked this post
  30. #23
    I've researched a bit and read that this machine would require around 80 amp service to run well. Could I even run it off of my dryer outlet?
  31. #24
    Not a dryer outlet but a 60 amp or maybe even a 50 amp would work if you're not at the top end.
  32. Likes MinnesotaDave liked this post
  33. #25
    Jun 2014
    Southern Illinois
    I’ve always ran my Dialarcs and Idealarc250’s on 50 amp service and not had any issues
    Steve
  34. Likes MinnesotaDave liked this post
Page generated in 1,614,627,211.85019 seconds with 13 queries
