Results 1 to 3 of 3
Thread: Have a thermal arc fan 250
    Feb 2021
    I have a thermal arc fabricator 250 with a 14 pin female spoolgun plug on it and I’m needing to know is what spool gun will plug into it every spoolgun I’ve looked at has way less than a 14 pin plug
    I got the machine used(I’m sure it’s atleast 10 or more yrs old but hardly ever used) and it welds great but I can’t do any aluminum work with it
    So I guess what I’m saying is I would appreciate any help I could get to find out which spoolgun I can buy new or used that will work
    Thank you so much for your time
    Ceres, California
    Re: Have a thermal arc fan 250
    Contact a local on online welding supply store. you have several options.
    I did a quick search on line and found an adapter the will allow the MK products guns to connect to your welder. this adapter may also allow some of the Lincoln spoolguns to work with your welder. or I will bet HTP will have a less expensive spoolgun that will direct connect. (847) 357-0700 Another option is systematics call them for information and a seller close to you. 1-800-abc-weld.
    Feb 2021
    I will give it a try thank you very much for your and ice and info
Page generated in 1,713,277,749.39874 seconds with 17 queries
