Results 1 to 12 of 12
Thread: AC/DC desperate
    Jan 2021
    AC/DC desperate
    I bought this 7 YO welder from a guy who gave up and bought a MIG. He stated that he had opened it up to clean and lubricate the AMP switching selector, which does work now. He stated he wasn't sure where the last 2 gray wires connected. I think looking at the approximation of the gray wires to the nearest bolt connectors, that this part of the problem I'm having is OK. What is confusing this ancient mind, '79 soon, is the RED circled connection. He said he could not remember if he loosened that connection but he said he did not think he did anything to it??
    Here is my problem, I sent an inquiry and this pic to Lincoln asking if they could ID this connection. WELL, I got a pic of the schematic that I already have or take to the friendly dealer. I do not read schematics! Not required for welding AFAIK.
    Help, can someone take a look at the pic and help an "old newby" out.
    bonesetter
    Outside of Raleigh, NC
    Re: AC/DC desperate
    It would help if you posted the pic of the schematic...
    Miller Trailblazer Pro 350D
    Miller Suitcase MIG
    Miller Spectrum 2050
    Lincoln 210MP
    Jan 2016
    northeast USA
    Re: AC/DC desperate
    Quote Originally Posted by bonesetter View Post
    bonesetter
    if you look close all 3 areas have black magic marker on them, by the white circle 2 hash marks on the strap, the middle one has the x on top with matching x on the grey wire and the green has 1 hash mark on the strap, nothing in the red circle...check the wire for hash marks to match up..
    Jan 2021
    Re: AC/DC desperate
    As I stated in the third sentence. The GRAY wires are not in question at this time. The small blue wire was never removed after questioning the previous owner.
    What remains now is the question of " why is the red circled area not tightened down"? Could this be an assembly blunder?
    I appreciate you chiming in with concern for me not wanting to cause damage to this welder.
    bonesetter
    Jan 2021
    Re: AC/DC desperate
    scsmith42, thanks for responding. I'm basically helpless because I have not clue when it comes to schematics. I hope this helps both of use. See pic of schematic this came from lincoln for this model.Name:  schematic.jpg
    Mar 2015
    Milwaukee, WI
    Re: AC/DC desperate
    Lincoln normally has good access to manuals, but they require you to provide the CODE # on your machine. It's likely a 4-digit number starting with "8".
    The picture that you showed is of the output rectifier. Here is Lincoln's repair and replacement procedure for one of their machines with CODE # 8777:
    https://lincoln-is-viewer.ptcmscloud...zE2MjYzMDczNn0
  7. Dislikes bonesetter disliked this post
  8. #7
    Jan 2021
    Re: AC/DC desperate
    Denis G, thanks for responding, Did you read all of my first post. I did all that with Lincoln. Quoting from first post, "WELL, I got a pic of the schematic that I already have or take to the friendly dealer. I do not read schematics! Not required for welding AFAIK."
    Link posted is a dead link.
  9. #8
    Mar 2015
    Milwaukee, WI
    Re: AC/DC desperate
    Sorry I couldn't help. Link works for me. You didn't provide the code # in your posts which limits how other people can help you. Best of luck.
  10. #9
    Dec 2015
    Re: AC/DC desperate
    https://www.instructables.com/Refres...ombstone-weld/
    Here’s a instructible that I used to refresh my tombstone twice . It may or not help you...
  11. #10
    Ceres, California
    Re: AC/DC desperate
    this is a duplicate thread.
    But this might help. when reading a diagram identify as many of the components you can and match up to diagram. Then think of the connecting lines a roads.
    Components are towns and lines are roads. So just like reading a map to get from one town to another you follow the lines. start at the input plug and work your self to the transformer. Or start at the weld terminals and work your way back into the welder. Through the polarity switch to the rectifier then the range switch.
  12. Likes ronsii, R2kone liked this post
  13. #11
    Nov 2018
    Re: AC/DC desperate
    I like how you put that. I have answered OP's question with some pictures from my Tombstone as I understand the frustration with schematics. Your post makes a lot of sense and I'll remember it next time I have to take a look at a schematics. Thanks.
  14. Likes bonesetter liked this post
  15. #12
    Jan 2021
    Re: AC/DC desperate
    R2kone, Thanks for your submission. Pics are the best. I did not seem to get my point across to the rest, so Thanks to you the Tombstone is alive and weling
    bonesetter
Page generated in 1,713,253,049.15603 seconds with 19 queries
