Results 1 to 9 of 9
Thread: Wooden Step (No Welding)
    Mar 2014
    Troy MI
    I built a wooden step to help my wife get into bed. After she tried it out, she decided that it needed to be higher so I added a 2” addition to the step. In addition to the extension, I also added an outrigger to stabilize it if you stepped on the edge of the step. I used biscuits to attach the extension to the original step, because it would be the most minimalistic method and still allow for some lateral adjustment during gluing.
    1. Original 7-inch-tall step
    Name:  1. Original 7 inch tall  step.jpg
    2. Bottom view of step
    Name:  2. Bottom view of step.jpg
    3. Bottom dato
    Name:  3. Bottom dato.jpg
    4. Shelf dato
    Name:  4. Shelf dato.jpg
    5. Chop saw
    Name:  5. Chop saw.jpg
    Smith Oxyacetylene Torch
    Miller Dynasty 200DX
    Lincoln SP-250
    16" DuAll Saw
    15" Drill Press
    7" x 9" Swivel Mast Saw
    20 Ton Arbor Press
    Bridgeport
    Everlast PowerTIG 400 EXT
    Mar 2014
    Troy MI
    Re: Wooden Step (No Welding)
    6. Dato blade
    Name:  6. Dato blade.jpg
    7. Wobble blade
    Name:  7. Wobble blade.jpg
    8. Biscuit cutting machine
    Name:  8. Biscuit cutting machine.jpg
    9. Biscuit cutter
    Name:  9. Biscuit cutter.jpg
    10. Biscuit cut detail
    Name:  10. Biscuit cut detail.jpg
    Lincoln SP-250
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
  3. Likes ronsii, VaughnT liked this post
    Mar 2014
    Troy MI
    11. Biscuit installed
    Name:  11. Biscuit installed.jpg
    12. Side extensions glued and clamped
    Name:  12. Side extensions glued and clamped.jpg
    13. Front and back extensions installed and glued
    Name:  13. Front and back extensions installed and glued.jpg
    14. New 9-inch-tall step
    Name:  14. New 9-inch-tall step.jpg
    -Don
    Lincoln SP-250
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
  5. Likes AlabamaJoe, whtbaron, 12V71, ronsii, VaughnT liked this post
  6. #4
    Looks great!!! Your projects always look very professionally done. It looks like it will serve it's purpose well
    But.... no welding I guess it's ok as long as you used something like one of these
  7. #5
    Great job!
    Now you need to put a bottom on it, hinge the top, and you'll have a small storage nook for whatever the wife wants to store. Maybe add some decorative ironwork to give it that super-sexy traveling-chest/toolbox look.
  8. Likes ronsii, CAVEMANN liked this post
  9. #6
    Soda springs,Id
    Looks really good, Don!! Professionally done. Gorilla glue is my go to for wood projects.
    Hobart G-213 portable
  11. #7
    Mar 2014
    Troy MI
    Good Point
    Great job!
    Good idea to hinge the top.
    I do have Gorilla glue and I have used it. For some reason I just used Elmer's waterproof carpenter's glue for this project.
    -Don
    Lincoln SP-250
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
  13. #8
    Mar 2014
    Troy MI
    It took me a while to respond because I just had a double robotic hernia surgery. I was fading fast from the anesthesia, when I entered the operating theater, so I had to do a Google search for these pictures. The first picture shows the entire robotic surgery setup.
    15. Setup for robotic hernia surgery
    Name:  15. Setup for robotic hernia surgery.jpg
    The next picture shows the surgeons work station. The surgeon basically controls the robot with two joysticks.
    16. Surgeon's work station
    Name:  16. Surgeon's work station.jpg
    And last but not least the nurses station. The robot arm is shown in several positions at the same time.
    17. Surgical nurse guiding the robot arm
    Name:  17. Surgical nurse guiding the robot arm.jpg
    The advantage of this process is that the success rate is excellent and because it is minimally invasive the recovery time is reduced.
    -Don
    Lincoln SP-250
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
  15. #9
    Outside of Raleigh, NC
    Well done!
    Miller Trailblazer Pro 350D
    Miller Suitcase MIG
    Miller Spectrum 2050
    Lincoln 210MP
Page generated in 1,713,252,814.03780 seconds with 21 queries
