Results 1 to 6 of 6
Thread: Tig welding 1/8 aluminum
    Apr 2020
    I知 welding 1/8 aluminum 1G corner joint. I need help on setting parameters. What would you guys set your amperage, balance and frequency to? I知 using 3/32 tungsten
    SoCal-LA
    Re: Tig welding 1/8 aluminum
    What brand and model welder?
    Nov 2014
    PDX PNW
    Trying 100- 125 amps Floored
  5. Likes ronsii liked this post
  6. #4
    Sep 2016
    Detroit, Michigan
    I promise I'm not saying this to be mean, but if the experts here (I'm not one) are going to help, you have to give them something to work with.
    Three days ago you posted the same question on the other forum and folks asked what machine, what position, what type of joint, etc. I believe you added that it's a flat fillet weld, but nothing else. Now you post the same question, and you're getting asked the same questions. If you want an answer that is helpful, you're going to have to fill in the details a little bit.
    Short of that, set your machine for 150amps, 30% cleaning action, 100Hz and see what happens....adjust from there and you'll figure out the answer yourself.
    http://mivise.com
    Hobart Champion Elite
    Everlast PowerTig 210EXT
  7. Likes WenValley, shovelon liked this post
  8. #5
    Laredo + Midland/Odessa
    Quote Originally Posted by Wildwelder96 View Post
    Generally 150A and go from there.
  10. #6
    Nov 2014
    PDX PNW
    Out corner joint dont take much. Inside acute corner takes about 3 times the amps. Set the machine to 150 and have another person look at the machine and let you know the amps being used or record it with your phone
  11. Likes ronsii, shovelon liked this post
Page generated in 1,713,262,809.88294 seconds with 18 queries
