The other day my TB 302 started acting up, I am hoping someone here might have some answers. The welder welds fine but if I turn the ignition switch to RUN it stays at low idle. I can't check the hours either. when I put it in the RUN position it shows the hours till oil change. I can't reset the hours till oil change. Everything else seems to work fine. Any help will be greatly appreciated.
