My trailblazer 302 will not run at high idle if you put the ignition switch on run and the hour meter display does not show up when you put the switch on run with the engine off.When you put it at run with the engine off it shows the hours for the oil change. The machine works fine from the run/idle setting.
Thank you for any help
