Results 26 to 44 of 44
Thread: Redface- Red-Blue face
    Oct 2013
    cntrl FL
    Re: Redface- Red-Blue face
    Id like to find a short hood so I could compare the differences to my red face machines. My '63 burns 6010s as good as 7018s on my '80 green light machine. So smooth and easy.
    SA 200s : 1944 1945 1963 1965 1969
    1981 SA 250 D3.152 DC only
    1961 LincWelder DC 180 AS
    2004 Ranger 10,000
    Lincoln Pro Mig 135
    Miller Load Bank
    Hobart GPB 258 Pipeliner
    Hobart GPB 261 Mainliner
    Hobart Airforce 250
    Everlast PA 200st
    Ocvs are a big thing with the comparison, I like a short cause you run it in 3rd for everything from 3/32-3/16 7018
    ROCKVILLE ,,VA
    wow got suck up vortex/black hole again,even Andex responded
    Jul 2014
    MetalTown, USA
    Zombie thread lolz
    AWS CWI xxxx2171
    1968 SA200
    Quote Originally Posted by WelderMike
    I hate being bipolar, It's awesome.
    Quote Originally Posted by ZTFab View Post
    Nice work!
    Visit Regulator and Torch Exchange, Inc. for all your cutting and heating needs!
    Nov 2020
    NJ
    Hi. Could anyone tell me anything about a 1952 shorthand with a number of 2365 on it ? I am trying to figure out if it a red face or not.
    I have to admit, I'm confused on the topic and have heard from some old timers that all of the SA-200's (Red face & Black face) had all copper windings in the generators and the black face's had aluminum or copper coated aluminum in the armatures. This was supposed to be the only difference from what I have been able to gather to this point anyway.
    If anyone can help that would be great as this seems to be very confusing reading through many, many different comments and opinions or many different folks here.
    Thanks for any help trying to understand this. I just don't want to waste money on a project I would like to take on.
    Macsr
    You should have started a new thread. This one is 5 years old. It's short hood not shorthand. Red faces were built in the 60's however the first long hoods in 1958/59 were basically the same but had a black faceplate. I think early 70's machines before the octagon barrel (around 1973) went to black face plates too but the same as a red face. Red/blue face machines were apparently made for the military and had everything balanced. Any SA200 with a round barrel is the most desirable as they have all copper windings and a 1952 short hood would qualify. Might require a lot of work though. Red face machines have 5 amperages ranges and the best overall arc characteristics for 6010 or 7018. Short hoods are better for 6010 and not as nice for 7018.
    Nov 2020
    NJ
    Welder Dave,
    Thank you for taking the time to respond to my questions !
    And, thank you for the great information. I apologize for the "typos" as I was trying to write on my small screen cell phone but yes, I did mean to type "short hood". Sorry.
    I'm new to this site and didn't know how to start a "new thread", sorry again.
    I'll have more questions on this unit probably. But can you tell me what the # 2365 that I was given off of the unit may mean and,....is this a all copper wound generator and armature ? (It is a round barrel) And, if a unit has a black face plate on it, does it absolutely mean it is cannot be a "Red Face" all copper wound unit ? Or are just all "Red face plate" units the Copper wound units ?
    I was also told by the current owner that is stated life as a short hood and the prior owner converted it to a " long style " unit. I am going to look at it in person this week.
    Any suggestions on where to look for certain ID numbers on the engine & generator etc that can help further ID it would be greatly appreciated Sir.
    Thank you in advance for any further assistance you may be able to provide Sir.
    Mike
  8. #33
    Oct 2013
    cntrl FL
    Sounds like that machine is a mixed bag if the face plate has the code 2365, in a long hood frame, because I have a 1955 short hood with the code 2365 on it. Look on the generator housing for numbers stamped on the starter side of the machine, probably painted over a little, that will tell which generator it is. If you find four numbers, that would be a code number. If you find the letter A-xxxxxx, that will be the serial number that was stamped on most short hoods.
    I keep hearing the same old rumor about Red/Blue face machines being made for the military and how they where a balanced machine? Though the Lincoln service manual states as them being the same as any other Redface according to the wiring diagram specs, and load testing?
    2004 Ranger 10,000
    Lincoln Pro Mig 135
    Miller Load Bank
    Hobart Airforce 250
    Everlast PA 200st
  9. #34
    Maintainence and everything else likely wouldn't change because it was balanced. I saw a thread awhile ago by someone who sounded pretty knowledgeable and the red/blue face for the military is the most logical. If they were made for a large contractor someone would know which contractor.
  10. #35
    Oct 2013
    cntrl FL
    I'm not sure if the Red/Blue face machines have a flex plate on the main armature or not, but my 63 Redface has the armature bolted straight to the crankshaft and it very balanced and smooth. I'm keeping my eye out for one of those Red/Blue face machines, I really want see what there all about.
    2004 Ranger 10,000
    Lincoln Pro Mig 135
    Miller Load Bank
    Hobart Airforce 250
    Everlast PA 200st
  11. #36
    Apr 2020
    isn't there anyone that worked at Lincoln on here during those years to clear the red/blue face debate up ? i would think that if they were made for the military those machines would have been painted olive drab, just about everything i owned that was military from those years,(air compressor, generator, tool boxes) were painted olive drab
  12. #37
    There was a guy at Lincoln that knew what every code meant but he's long retired and don't think he's with us anymore. Changing a face plate isn't a big deal. Changing paint colors might be. Lincoln is all about branding. I think Red-D-Arc is the only company that Lincoln has made welders for but they've bought thousands and thousands of welders from Lincoln over the years. Red-D-Arc was originally a Lincoln dealer. Back in the early 80's I was looking at SA200's. They had a list with pretty much every year machine made from the mid 60's up to current machines. The list was probably 5 pages or more long. Red-D-Arc has got a lot bigger since then too.
  13. #38
    Feb 2021
    Quote Originally Posted by BYW200 View Post
Size:  192.5 KB this is my 1963 red/blue face Name:  2207.jpg
Size:  20.8 KBName:  2246.jpg
Size:  27.4 KBName:  2209.jpg
Size:  17.7 KB and has a flex plate...you take out the bolts and turn it a 1/4 turn to unhook it(nice to know but can be a pain gaining that knowledge as it's not in my manuals !)...It does have weights welded on the inside of the flywheel...Michael
  14. #39
    Feb 2021
    Quote Originally Posted by Macsr View Post
    Macsr
    All round barrel SA200s are "Red face" (i.e. copper wound) octagon barrel were made because Aluminum windings need the extra room but some of the first were supposedly copper wound and alot were later rewound in copper by their owners....if it's round it's copper wound because Aluminum windings can't physically fit
  15. #40
    Apr 2020
    i bought a red face / blue dial 4816 code , sa200 for $300, it wasnt running when i got it , has a F162 motor, but the barrel 's number code number is 5604, must have been swapped out at some point in time
  16. #41
    Oct 2013
    cntrl FL
    Thanks R&I for the clarification. Is your machine the code 4150? All the later SA machines I've split had the flex plate. I've always wondered why the 63' Armature I have, was bolted straight to the crank.
    2004 Ranger 10,000
    Lincoln Pro Mig 135
    Miller Load Bank
    Hobart Airforce 250
    Everlast PA 200st
  17. #42
    Feb 2021
    BYW200..Yes mine is code 4150....on the plate and stamped on the barrel... On the road welding and had a hell of a time getting on with my Nextbook...I have a love\hate relationship with computers and I don't know (or want to know) how to do this crap on my phone.... I'm an old Norwegian who thinks a phone is for talking
  18. #43
    Feb 2021
    Quote Originally Posted by gmcdeadhead View Post
    . I sanded mine down and it's Lincoln gray all the way to the metal (well, after you get through the light gray stuff)...no olive drab anywhere... I have a 600cfm air compressor that was military and that has military tags all over the place and was olive drab EVERYWHERE....Michael
  19. #44
    Lincoln is all about efficiency. It might be Lincoln grey and that's it. If used on ships, ships are grey.
Page generated in 1,713,305,892.27762 seconds with 20 queries
