Page 2 of 2 FirstFirst 12
Results 26 to 37 of 37
Thread: best, cheapest, cleanaest way cut steel?
    Dec 2005
    arlington va
    Re: best, cheapest, cleanaest way cut steel?
    i didnt see any one mention a cut off wheel on a hand held grinder, i get really good cuts with these wearing a full face mask and the mateial clamped in a vise. kind of noisy for the neighbors but it i get good cuts pretty fast.
    bobs77vet/37ford4dr
    Eastwood digital TIG200
    HH190
    Lincoln Invertec 155s
    Lincoln weldpak 100
    sears/craftsman (lincoln) 50a 240v buzz box
    O/A rig Harris gauges
    nexion cut 50 dx
    chicago electric (HF) 240v spot welder
    Jul 2011
    Bossier Parish La.
    Quote Originally Posted by 37ford4dr View Post
    Hand held or angle grinders with cut off wheels were mentioned in posts 9,13,15 & 20. Go back and re-read, you must have missed it. I don't think he has one, but if he is going to do any welding he needs to get one or some anyway.
    Mar 2006
    New England
    Seems like the OP is doing some prototyping and needs nice clean cuts. I don't think anyone has brought up porta-band saws which are certainly a useful way of making a clean cut and if mated to a simple stand can make quite precise cuts. Not cheap but not horribly expensive either at about $250-300 for a Milwaukee or Dewalt. HF sells one for $90. Lots of home made stands on Youtube or you can buy a chop saw like stand from Milwaukee or a bench mount table from SWAG off road. Far quieter than the abrasive saws.
    Nov 2011
    Canada
    I'd just get a 7" grinder and some 3/32" zip discs, setup yourself a guide for both angles and flats.
    If you've got steady hands, you can do great with just a grinder. After that, I would just find a place that you can purchase your angles and flats from that will do all of your cuts for you, I'm sure that there has to be at least one supplier around you that offers that kind of service.
  5. #30
    Oct 2020
    Re: define 'heavy duty' table
    Bandsaws are quite similar to jigsaws. The critical difference is that they are table-mounted and powerful enough to easily cut through metal and wood, depending on the blade used. WEN 3975T 4-7/8-inch x 5-inch Metal-Cutting Benchtop Band Saw is effective for cutting brass, copper, aluminum, steel, and more pipes up to 5 inches in diameter and 5 x 4-7/8 inches rectangular materials. Here is the list of Bandsaws & their reviews that may help you to choose because those performs exceptionally well when cutting metal.
  6. #31
    Let me guess.... that link you posted is somehow related to what you do ??? maybe get compensated for it too
  7. #32
    That is good way.
    It green power no more gym membership need.
    Win win
    Horizontal band saw.
    Lacking the funds for a band saw I would recommend a hack saw with a guide... similar to the a hand miter saw.
    Goodell-Pratt used to make a bench hack saw. Keep your eyes open.
  8. #33
    Jan 2015
    Lewis Center/Powell Ohio
    I'm a little late to the party but a cutoff wheel on a RA grinder would work very well. Also, when I have to cut 1/8" I automatically pull out my jig saw with a metal blade if I have long cuts, not cutoff types. For cutoff types of cuts, it's either a cutoff wheel or my metal bandsaw. You'll have to deburr any cuts with any process, bench grinder/wire brush or flap wheel on an RA grinder.
  9. #34
    Nov 2020
    NJ
    Hi,
    Could someone tell me how to post a comment on this site ? I'm new here and can't figure the site out.
    Thank you,
    MAC
  10. #35
    Jan 2015
    Click on the reply to thread button, bottom left below the comments. But obviously you figured it out since you posted a comment in this thread.
  11. #36
    Jan 2015
    Quote Originally Posted by Macsr View Post
    I want to post in the general comment section I guess. I just had some Miller gas welder parts info I wanted to share with folks out there who may have had the same issue I had is all....
    Thank you
    Go to Forum, click on the appropriate sub heading, then click on Post New Thread in the upper left.
  12. #37
    Big Lake/Monticello MN
    Hi,
    Thank you,
    MAC
    I moved your post to its own thread in the Miller section.
    Syncro 350
Page generated in 1,713,257,488.82835 seconds with 17 queries
