Results 1 to 18 of 18
Thread: Cheap & Easy hole centering on tubing
    Arizona
    I needed to drill some holes in 3/4" tubing but they had to be centered, I had some grounding clamps laying around so I just pulled the screw and finished drilling thru the brass clamp then used it to center all my pilot holes on the tubing, worked great.
    Miller Challenger 172
    Miller Maxstar 150 STL
    Victor 100C
    Victor Journeyman
    Oxweld OA
    Harris O/A
    Smith O/A little torch
    No, that's not my car.
    Re: Cheap & Easy hole centering on tubing
    I would just make a jig.
    If could I use drill press
    I like that!!Name:  tkqe4fh-smiley-two-thumbs-up175028_285604.gif
    While on the subject....................WTF do stinkin' drill vises have the half azzed fixed jaw that doesn't extend all the way down to the vise ways?? Any kind of thin plate slides under the damn jaw, and makes it a PITA to center the vise for repeated operations. With a mill vise, you just shoot your center off the back fixed jaw, and you're good to go.
    One of these days, I need to mill a square spacer to place in front of the fixed jaw to close the gap.
  4. Likes William McCormick, Oscar, VaughnT liked this post
    Ct.
    I like it. Drilling pipe/tubing is always a problem
    because drill walks off top of pipe, even with center
    punch mark. Using a center drill works , but drill
    press table has to be raised because center drill is
    shorter than twist drill . I’m thinking that in a drill
    press, you could just hold top of ground clamp on
    pipe and use it to start drill. Ground clamp trick
    (using both parts of clamp)would work well in the
    field with portable drill.
    Miller a/c-d/c Thunderbolt XL
    Millermatic 180
    Purox O/A
    Smith Littletorch O/A
    Sep 2012
    Utopia,TX / Pasadena, TX
    Great idea, never thought of it.
  7. Likes William McCormick liked this post
  8. #6
    Good idea!
    UNITWELD 175 AMP 3 IN1 DC
    JEFF
  9. Likes William McCormick liked this post
  10. #7
    Mar 2008
    Georgetown, Texas
    I guess you don't have a center finder. They work great for this and on any size pipe.
  11. Likes BD1 liked this post
  12. #8
    I have a few little strips of plywood I keep around for that.... pain in the butt.
  13. Likes farmersammm liked this post
  14. #9
    Center finder works great. They increased in price like everything else.
    https://www.amazon.com/Jackson-Safet...NsaWNrPXRydWU=
  15. #10
    I like the tool. It appears to the tube in position for drilling. Would probably do a fixture similar to that rather than using a center finder tool. Center finder will mark the tdc, but not assure alignment if drilling through both sides.
    I have had a center finder tube for years. Used it for the first time a couple weeks ago on a pipe rail job. Awesome tool for aligning opposite ends and clocking miters and copes.
    Check.. Ebay and there are other brand available. I have the curve-o-mark purchased new in box for cheap price.
  16. #11
    Mar 2008
    Georgetown, Texas
    I have a center finder that I bought at a flea market that's probably the best ever made. It's in a little metal box and can find any place on the pipe in single degrees. I just went out and looked, it's called Miracle Point. i just looked and I'll be danged if they don't still make it.https://www.penntoolco.com/miracle-p...7C%20%24349.95
  17. #12
    Nice. Did you happen to check out the current price?
  18. #13
    If drilling smallish round stock I just set a 6" scale ruler between the stock and the drill. If it balances out level it's pretty much dead on center.
  19. Likes CAVEMANN liked this post
  20. #14
    Miracle points are a great tool, they're also expensive, last time I checked it was around $400.00 IIRC. I just checked again & they run between $350.00 & $400.00 for the one like we were issued in the Machine shop. There are larger sizes that are more expensive.
    JEFF
  21. #15
    Travers Tool sells one that appears identical for somewhere in the 180$ range. I have one of the miracle point branded ones and I believe it was around 150$ nearly 20 years ago
  22. #16
    Southern California
    tube grounding point and center finder all in one
  23. #17
    Mar 2008
    Georgetown, Texas
    I did and was stunned. I think I paid around $20 for the one I have. It is nice to use it though.
  24. #18
    Found this for 60 bucks, used. Knock-off brand. SPI 360 magnetic compass
Page generated in 1,713,280,166.08364 seconds with 21 queries
