Results 1 to 23 of 23
Thread: Moment of inertia for angle iron?
    Jan 2015
    Lewis Center/Powell Ohio
    There's an online calculator I'm trying to use to figure out the deflection on 1/8" x 1", 1/8" x 1 1/2" and 1/8" x 2" angle iron for various spans. However, it wants to know what the moment of inertia is before it will do the calculation. I have no idea what that is. I looked online to see if there was a way to calculate that but the formulas given were way over my head. Would anyone here know what that moment of inertia is for the sizes I've given
    Feb 2016
    W. Texas
    Re: Moment of inertia for angle iron?
  3. Likes ronsii, JD1 liked this post
    Quote Originally Posted by WTXBTUMOVER View Post
    Nice WTXB
    According to that the values are:
    1 inch = .022
    1.5 inch = .078
    2 inch = .19
    And the deflection calculator says a 10 foot length of 1 inch angle with a 200 pound load in the center will deflect 10.9 inches
  5. Likes JD1, William McCormick liked this post
  6. #4
    Aug 2016
    Be real careful when calculating deflections (and strength) of angles under bending. Depending on the axis you are bending about, lateral restraints, and the placement of the load (relative to the shear center of the angle), an angle will experience lateral-torsional buckling way before it will reach the yield strength of the section.
    LINCOLN
    Square Wave TIG 200
    Power MIG 210 MP
    Ranger 330 MPX
    MILLER
    Thunderbolt AC/DC
    HYPERTHERM
    Powermax 190C
    Powermax 45XP
    HOUGAN
    HMD 130
    HMD 505
    FEIN/SLUGGER
    14" COLD METAL CHOP SAW
    9" COLD METAL HAND-HELD SAW
  7. Likes William McCormick, Dave66 liked this post
  8. #5
    Apr 2010
    JD1
    . . . I have no idea . . . way over my head . . .
    Agree - you don't know - whether your posterior
    'is punched or drilled' . . .
    PLS - describe your entire project, so the details
    can be properly eviscerated . . .
    hth
    Opus
  9. Dislikes JD1, VaughnT disliked this post
  10. #6
    I always overbuild . Depending on your use, I find people usually excede what it's rated for. Heavy is usually better.
  11. Likes ronsii, William McCormick liked this post
  12. #7
    Jan 2015
    Thank you all, except for Opus and his fascination with my a**. The project isn't at a critical level, if it were I'd look deeper into the concerns Ingenuity raised. I think I have the info I need now.
  13. Likes ronsii, VaughnT liked this post
  14. #8
    Jan 2015
    Nice WTXB
    1 inch = .022
    1.5 inch = .078
    2 inch = .19
    I assume that if that 200 lb load was supported with not one piece but two, like for a shelf, then the deflection would be half of that - 5.45" instead of 10.9"?
  16. #9
    According to the calcs site...yep... that was also just a 'supported ends' calc not a fixed ends which would add tension to the deflection resistance... and it is a technical number because I think we all know one piece of angle will twist all over the place with 200 pounds loaded in the middle of it 2 inch was a heck of a lot less deflection btw.
  17. #10
    Don't say that if front of Sammmy....
  18. Likes Louie1961, SweetMK, shortfuse liked this post
  19. #11
    Jan 2015
    Thanks ronsii, if the project goes through the angles will be bolted on each end so that helps. Specs are changing so I'm not sure it will go through but at least I know how to deal with it now.
  20. #12
    Nice WTXB
    1 inch = .022
    1.5 inch = .078
    2 inch = .19
    I highly doubt a 1" steel angle ten feet long is going to support 200 pounds at the center. Unless you anchor the ends and use it taunt like a piano wire.
    Sincerely,
    William McCormick
  22. #13
    Sincerely,
    William McCormick
    LOL!!! Yes, I just always like to put extreme values into calculators to see what the results come in at
  23. Likes William McCormick liked this post
  24. #14
    I would actually just bend up sheet metal to create the shelf myself maybe 1/16" material with a 2" face 1/2" return, and a two-inch bend on the back as well.
    Or you could do this. This is extremely strong. And you can load it so that it can take a lot of weight.
    Name:  shelfsupport3 - Copy.jpg
    Sincerely,
    William McCormick
  25. Likes ronsii, tackit liked this post
  26. #15
    Big Lake/Monticello MN
    Quote Originally Posted by OPUS FERRO View Post
    JD1
    hth
    Opus
    If your comments can't be useful in some way, you should be silent.
    A member noting that he doesn't know something, and wants help, is in no way an opportunity to insult them.
  27. Likes wb4rt, Oscar, shortfuse, Shootr, Dave66 liked this post
  28. #16
    Jan 2015
    Thank you Dave. I did comment about Opus in post 7, he's quite a challenge.
  29. Likes MinnesotaDave liked this post
  30. #17
    Feb 2011
    Southeast Louisiana
    Just for info relative to this thread, is angle stronger with "leg up' or "leg down" or is there any difference?
    Hobart 190 mig
    Lincoln/Century 140 mig
    Lincoln buzz box
    Chicago Electric cutoff saw
    Lotos LTP5000D Plasma Cutter
    HMC Swivel head band saw
  31. #18
    Laredo + Midland/Odessa
    Quote Originally Posted by cabranch47 View Post
    depends how it is suspended at the ends and depends on how exactly you plan to load it.
  32. #19
    The orientation doesn't change the moment of inertia (if I recall correctly).
    Leg up or down is the same "strength" as long as everything else is the same (support from twisting and load applied).
    Diagonal orientation is weaker though.
  33. #20
    I don't know about that equal force thing. On a bender it takes less force and gives you a better bend when pulling on the web vs pushing it, probably even more so with channel. I realize that that is a controlled bend and not just a force to failure thing but it stands to reason.
  34. Likes William McCormick liked this post
  35. #21
    Jan 2015
    Martha Lake, WA
    Moment of inertia relates to bending, not to strength in the pure sense. Sure if you have a long piece of angle it will "fail" with a relatively small weight on it and even distort/buckle from it's own weight if long enough, but moment of inertia is not used in basic strength calculations. When you pull on a short section of angle it is definitely easier to bend in one direction vs the other.
    Tweco Fabricator 211i
    Sieg X2
    AMT radial arm drill press
    AMT belt/disk sander
    HF 4X6 bandsaw
  36. #22
    Aug 2016
    The moment of inertia, I (more correctly termed the 2nd moment of area, for structural engineering) is an important structural property for ALL structural sections - for both stiffness (deflections) AND strength. For strength, the dominant structural property is section modulus (S for elastic section modulus) which is the moment of inertia divided by the distance from the section centroid to the extreme tip of the section (top and/or bottom), so S=I/y; and y is: ytop or ybot, depending on which way the section if orientated, and the stress you are looking at.
    The flexural strength of single angles is complicated. There has been several PhD dissertations and many research papers on the general subject.
    Depending on the orientation of the legs and the location of the load application (relative to the sections shear center), they suffer from local buckling (if ratio of the leg LENGTH to leg THICKNESS is too large), and lateral-torsional buckling if the tip of the leg is in compression and there is not adequate lateral restraints (like attachment to adjacent stiff members at close centers).
    The centroid and shear center of angles do not coincide. Any load NOT applied through the shear center will cause torsion to the section.
    Equal leg angles only have 1 axis of symmetry, and unequal legs have no axis of symmetry. So flexure about a X or Y geometric axis often needs to be resolved in the principal axis - the axis where the section has the maximum moment of inertia. An axis of symmetry is also a principal axis.
    Structural angles fare better under axial loads, especially tension - hence why you often see diagonal bracing using angles.
    If you have to use angles in flexure, double them up (back-to-back) and form a T section.
    LINCOLN
    Square Wave TIG 200
    Power MIG 210 MP
    Ranger 330 MPX
    MILLER
    Thunderbolt AC/DC
    HYPERTHERM
    Powermax 190C
    Powermax 45XP
    HOUGAN
    HMD 130
    HMD 505
    FEIN/SLUGGER
  37. Likes ccogg, MinnesotaDave, somorris liked this post
  38. #23
    That is because the centerline radius does not bend at pi. In other words when you start bending a straight piece when you get done instead of the centerline radius giving you the size radius bend of the centerline before bent it actually gives you a larger radius. Meaning the metal expands a bit more than it contracts. So when you try to expand the flat it takes more energy to compress the web because the flange does not want to stretch. It certainly matters which way the angle is oriented you are totally correct.
    Sincerely,
    William McCormick
Page generated in 1,713,274,503.95558 seconds with 21 queries
