Results 1 to 11 of 11
Thread: Squat rack
    Feb 2012
    Jacksonville, FL
    Squat rack
    My wife wants a squat rack. Pretty simple build minus all the hole drilling. Annular cutter on the mill for all the holes or can I get away with a twist drill?
    I plan to have it powder coated. The standard hole for these things is a 5/8". How much should I plan for the powder coating taking up...ie how big should I drill my holes so a 5/8" pin can fit into the holes?
    The model shown is about $800 plus shipping. I'd probably be close to break even after powdercoating but then I don't get all the brownie points.
    Feb 2012
    Jacksonville, FL
    Re: Squat rack
    Forgot the picture...
    Aug 2018
    'ta town, KS
    Re: Squat rack
    I would go a 32nd large and put a pin in your pin
    Mac
    Nov 2019
    North East Ohio
    Re: Squat rack
    I make them all the time. I like the advice of a 1/32 larger. I don't use annular cutters I use a 17mm twist bite. I make the holes every 2' apart. If you plan to lift with in the rack have the horizontal pieces at least 30" long. If squating out of the rack just make a 2 post lift and attach to the wall or make free standing. Go to Reebz Welding on face book and you can see a bunch of different styles.
    I just Paint them. If you want J Cup advice I can tell you what I do.
    Take care and have a good Thanksgiving
    Re: Squat rack
    Most bolt holes use the next size bigger than the bolt. This wouldn't be much different. If powder coated 1/16" bigger might be better. The holes aren't that critical.
    Feb 2012
    Jacksonville, FL
    Re: Squat rack
    Quote Originally Posted by Reebz View Post
    Thanks for the advice! Feel free to send all the j cup info you have.
    Re: Squat rack
    I would think if welding all day you not need squat rack. Just go out and move some steel.
    Quote Originally Posted by Ryanjax View Post
    Oct 2019
    Australia
    Re: Squat rack
    Op said it's for his wife.
    Re: Squat rack
    If I was to build one I think I would copy something like the smith machine.
    It’s nice to have the safety feature.
    Re: Squat rack
    Looks like the sample in the picture uses standard perforated telescopic tubing. Keep the hole drilling for the small parts.
    This is just a sample for reference. Local suppliers would be much cheaper. https://www.mcmaster.com/4931T152/
  12. #11
    Nov 2019
    North East Ohio
    Re: Squat rack
    The way I make my J Cups.
    2 sections of 3/8 thick Flat stock 11" long (22" total)
    2 sections of 3.5x3.5 Angle iron 1/4' wall cut 2" long (4" total)
    2 sections of 5/8 cold rolled cut at 4" (8" Total)
    I drill the 5/8 hole in the flat stock 1" from the top
    The first bend is 2" from the bottom and I bend it 31 degrees.
    The second bend is 6" the top and I bend it to 48 degrees. Spring back is the reason for the overbend
    If you want the plastic liner (not needed IMHO) I get it a McMaster Carr. Here is a link: https://www.mcmaster.com/uhmw-polyet...thickness~1-4/
Size:  134.5 KBName:  IMG_3188.jpg
Page generated in 1,713,306,347.07019 seconds with 21 queries
