Results 1 to 16 of 16
Thread: HF bender project-- Lambs tongues
    This demonstration is two-fold. First to show how to make lambs tongues using the bender and second to show an alternative method of mounting the bender.
    The Lamb tongue:
    Makes sure the joint is welded on both sides. The weld will split if joint is not welded on both sides, especially if heat is applied to make a more decorative looking tongue.
    Use any tool to get the notch--torch, bandsaw, cutoff wheel, grinding wheel-- I've used them all.
    Generally taper the notch about 2 inches from the end. Hammer the notch closed, tumbling the part so they the seam stays centered.
  2. Likes Shootr, chewinggum liked this post
  3. #2
    Re: HF bender project-- Lambs tongues
    Continued from previous post.
    This a reinactment for your entertainment.
    You can use your creativity to get better looking lambs tongues. Use larger dies for a more rounded look or some heat to turn up the tip more.
    Takes about 15 min to do one lamb tongue. You can do a long cap without a seam.
    The bender setup:
    Notice the set up with the bender. I was on-site Wednesday without my trailer my trailer has the reciever for mounting my tools.. This the way I came up with to operater the bender. I welded a square tube to the bender mounting plate laid the bender horizontally and stood on the tubing. It worked pretty well.
  4. Likes Shootr liked this post
  5. #3
    vermont
    Nice work!
    "Every choice you make will effect at least one other person"
  6. #4
    May 2006
    Very nice, is that for a hand railing?
    John
    - bleeding Miller blue!
    http://www.weldfabzone.com
  7. #5
    This would go on a hand rail. However I just did this one in my driveway to demonstrate "how to" and to show the use of the bender without a fixed mounting post.
    When the top rail extends over the newell post and turns down it is called a lambs tongue.
  8. #6
    May 2006
    Nice, it looked familiar, I just wanted to make sure. Great metalshaping.
    John
  9. #7
    Northern Cal., Shasta County
    Great work. Does or could that "tongue" weld to the upright down low then?
  10. #8
    Sandy
    Not sure what you mean by upright. Though usually the lambs tongue just hangs over a terminal post mostly seen at the bottom of stair rails. However, I have seen lambs tongues other places like gates.
    If a rail must be continuous and there is a lower rail, then I will extend the cap rail down to the lower rail and bend or cope the cap rail like crown molding to fit the lower rail.
  11. #9
    Quote Originally Posted by tapwelder
    Sandy
    I was kinda of picturing that lambs tongue rolling out like shown then back down to touch the post/upright that it sets on. At that point it could be tacked to the upright. Thinking on that it would need to be a little more scroll like that what you have there. No biggy, just mental rambling on my part.
  12. #10
    Done on the American Bender. I prefer smaller ones. The die is custom made 2 inch round bar.
  13. Likes DavidR8, wb4rt liked this post
  14. #11
    Lambs tongues installed. The larger cap cannot be be gone on the HF bender.
    The previous / initial lambs tongue with welded notch is very difficult to bend on HF. It slips and requires a very large portion to be inserted to be bent. Not attractive to me. The trimmed is the best way to go on the HF.
  15. Likes DavidR8 liked this post
  16. #12
    Apr 2020
    Canada
    That is some really nice work, thanks for sharing your process!
    David
    Millermatic 130
    Primeweld 225
    Victor Journeymen
  17. #13
    Nice job. The harbor freight compact bender is handy especially for the cost.I bought one 10 years ago and they were cheap. The floor model type was
    about $50.00. The dies can be used on a couple of pins welded to angle for other uses. it is handy for my metal artwork too
  18. #14
    Mar 2007
    MidWest
    PM sent, nice work
    Geezer
    Power Mig 255C
    185 TIG
    Blue 175 MIG
    Ranger 8 Kohler 20HP
    Victor/Harris O/A
    K 487 Spool Gun
  19. #15
    Mar 2008
    Georgetown, Texas
    Nice work Tap, I do it exactly the same.
  20. #16
    Feb 2019
    Snyder TX
    Portable stand for vice, bender, etc. use a short section if 6" channel with a socket (pipe or receiver) for tool. Turn channel up & park trailer tire or truck tire on channel. Extra strong - use longer section of channel & park one axle on the channel.
Page generated in 1,713,280,259.67848 seconds with 20 queries
