Page 5 of 18 FirstFirst ... 3456715 ... LastLast
Results 101 to 125 of 436
Thread: HOW TO - make a 220V extension cord
  1. #101
    Re: HOW TO - make a 220V extension cord
    I got my 50 ft 6/3 SOOW from welding supply for $130ish. Shipping ended up only adding $4 to my existing order. Lowes/home depot did not carry and were not interested in ordering it for me
  2. #102
    Jun 2008
    SF CA
    Gent's (ladies too if any) the receptical needs to be in a box! Not just a code - but safety issue. Maybe look into changing the striaght blade plug on your welder to a twist-lock, and use an appropriate "cord cap". (A receptical intended to be on the end of a cord)
  3. #103
    Jul 2007
    Cape Cod MA
    Quote Originally Posted by e57 View Post
    You can get a cord version of almost anything.
    Twist-locks are nice but most wont want to spend $35/45 per connector.
    Me!
  4. #104
    Jun 2008
    Please note, the homemade extension cords in this thread will result in a OSHA citation if used on a site where they have juristiction & they show up, they do not like metal 4 square boxes on cords... The use of surface mount 30 & 50 ampere surface mount devices on a cord is a even poorer practice, 1st time someone drops it you have exposed parts making it a "Darwin award" in progress.
    Please do electrical work safely or hire a qualified electrical contractor.
  5. #105
    Jan 2008
    Here's mine the longer one I use for my 80gal air compressor which uses 240/30amp. I added on to my garage so the compressor is on the other side of the building so instead of changing location of the plug that I use for my welders also I thought I'd just make an extension cord for it. The smaller is an adaptor I use with the larger cord with my Hobart Handler210 so I can get it out of the garage to where it is needed. Both use the twist locks.
    It's not what you can buy, it's what you can build that matters
  6. #106
    Jun 2008
    ok i bought a 10/3 extension cord i want to plug it into my 3 prong L shaped dryer outlet to run my welder and air compressor on....question is which colored wires from my extention cord (colored green white black) go to the 30 amp L male plug i will be adding which only shows red black and white? which color goes to the L post? im assuming that the white neutral wire takes the place of a ground which would be the green wire on my cord and that would go to the L shaped conector? and the white and black from the extension cord goes to the red and black female flat blades the plugo.is this correct? (green/white ground L shaped blade) ( 110v each color red/black-black/white flat blades) any help?
  7. #107
    Los Angeles
    Quote Originally Posted by Dave Baker View Post
    Connect the Ground/Green wire to L
    MM211 (Sold)
    Klutch 120v Plasma cutter
  8. #108
    Los Angeles
    here is a Pic
    MM211 (Sold)
  9. #109
    Jun 2008
    thank you ive been to so many sites trying to clarify this seems half are wrong and dont know what there talking about............. so it confused me!!
  10. #110
    Dec 2008
    i have a lincoln ac 225 stick welder, would this setup work? it won't be used alot.
  11. #111
    Aug 2008
    Quote Originally Posted by dirtdriver11 View Post
    Two hots, and a ground. Just like 2 posts back.
    http://www.farmersamm.com/
  12. #112
    Jun 2008
    Central California
    Years ago, I acquired a 60' 4-wire construction cord with twist-lock connectors that I put NEMA 6-50 hardware on. Later, I picked up some very heavy cable at a recycling center (free), and last spring, got another construction cable w/ twist-locks really cheaply from Craigslist (I didn't need it but the price was too good).
    IIRC, the first is a 6-3, 8-1 and is as about heavy as my machine; I used to keep it on one of those 3' diameter wooden spools.
    Anyway, with all the cables I have, I think I could weld all the way around to the the other side of the block.
  13. #113
    Dec 2008
    Quote Originally Posted by MAC702 View Post
    It's always nice when you post something like that to at least mention to others who might try it, that it's illegal.
    You no doubt did it because you were using material you had on hand. Romex, as you can see in the photo, is not very flexible, and is really only designed to be bent during a permanent installation.
    Real cords are stranded with much finer wire, designed to take constant flexing which can break the larger strands in Romex, especailly if the utmost care wasn't taken during stripping of the individual wires. The slightest nick on the copper will be sure to be a broken strand in a short period of time.
    I'm not telling you not to use it, and you've obviously already learned how to deal with its tripping hazards.
    I ran that stuff out to my garage through 1 1/2 abs (i know not up to code) it was a pain getting it through them elbows i tell you what had to put each piece on individualy and then cement it together.
  14. #114
    Nov 2007
    Pittsburgh Pennsylvania
    Im probably gonna make a 20ft using 10/3. Question is, which plug would i need for it to plug into my 50amp dryer outlet? Heres a pic of it.
    http://i177.photobucket.com/albums/w...r27/outlet.jpg
    Thanks
    Shane
  15. #115
    Los Angeles
    Quote Originally Posted by welderShane View Post
    Thanks
    Shane
    The one that fits it
    MM211 (Sold)
  16. #116
    Los Angeles
    That is a 10-50R ( receptacle) so you either need to make Pigtail to go from yer 6-50P that is on the Machine's cord or replace the Plug on the cord with a 10-50P(Plug)
    BUT you will have to wire it differently than how a Dryer is wired.
    MM211 (Sold)
  17. #117
    Jul 2007
    Denmark, Zealand
    Hmm.... some of us have 230v as standard but normally it does not have enough amps to back it, a small inverting welding machine needs at last 16amps not to blow the fuses.
    If you got money, i've got time
  18. #118
    Feb 2009
    hot and humid South Florida
    Excuse me for my ingorance but after reading all that im still confused. MicroZone this question is more so for you since I think we have the same machine(Econotig) but different power source. I want to use the same extension cord as you but i need to know if it matters that my outlet that im pluging the cord in has four points instead of three points? The outlet is on a 50amp circuit. Heres a pic of the plug that came out of the outlet and the outlet.
    Thanks, Slim
  19. #119
    Los Angeles
    Slim-
    That is a 14-50 Outlet
    Go to Home Depot or Lowes and buy a 14-50 4-wire range plug and a 6-50R
    You will use the Red, Black and Green wires- cut back the White and tape off.
    MM211 (Sold)
  20. #120
    Feb 2009
    Thanks Broccoli, for now on I'll just pm you when I have a question. Always a good and fast response. I headed to Home Depot now
  21. #121
    Feb 2009
    So I should be looking for a 10/4 in 50' right?
  22. #122
    Los Angeles
    If you want to make a 50' extension cord then you won't need the Range Cord like I posted- that is just a short Pigtail.
    and you don't need 4-wire Cord since you'll only use 3-anyway
    Just buy 50' of 3-wire cord- I bet it is about 1.98ft
    1- 14-50p
    1-6-50R
    MM211 (Sold)
  23. #123
    Los Angeles
    Wire it up like this.
    MM211 (Sold)
  24. #124
    Feb 2009
    Do you think I should get 8 or 6 gauge just to be safe?
  25. #125
    Los Angeles
    Well the manual online suggests 6g
    http://www.millerwelds.com/om/o303v_mil.pdf
    Dern those Econotigs take some juice
    Gonna be a heavy duty cord
    MM211 (Sold)
Page generated in 1,627,456,730.44422 seconds with 12 queries
