Results 1 to 25 of 47
Thread: Smoker Project
    Jun 2005
    La Verne Ca.
    Smoker Project
    Started our new smoker project.
    54" X 8' Main compartment to be mounted on stand.
    The frame is all tacked up with the base rail welded to the end supports.
    That's about as far as the passport can go for now.
    Jun 2005
    La Verne Ca.
    Re: Smoker Project
    Now its time to weld up the frame with the 350MP.
    I removed the frame from the drum and set it on the ground so that I would have access to all the joints.
    Now I'm on the to the landing pads for the adjustable legs.
    More Pics to follow.
    Ken
    Aug 2011
    Kuna, Idaho
    Re: Smoker Project
    Nice, taking the "Go big, or go home" thing to heart!
    Sep 2011
    Re: Smoker Project
    Thats no joke!
    Apr 2012
    Michigan
    Re: Smoker Project
    yea thats going to be a nice one
    Feb 2009
    Re: Smoker Project
    dam..just put the whole cow in there....
    Of all the things I lost I miss my mind the most...
    I know just enough about everything to be dangerous......
    You cant cure stupid..only kill it...
    Aug 2009
    Trinidad
    Re: Smoker Project
    nice
    you a lefthander ?
    MM 180
    Jun 2005
    La Verne Ca.
    Re: Smoker Project
    Ha Ha, no i am right handed. Do you ask that based on the direction of the welds or am I missing something else. I push or pull depending on access and visibility, this time I just seemed to pull most of them. Funny thing is, my passport likes to be pushed and doesn't like to sit in the puddle much at all, while the PM350 loves to backhand with its soft buttery arc.
    Ken
    May 2007
    SoCal
    Re: Smoker Project
    Sorry, I thought you said 54" x 8'. I must be reading something into this.
    Quote Originally Posted by roadkillbobb View Post
    Wait til they go to sleep, then sneak up and tip them over!
    Job 28:1,2
    Danny
    Jun 2005
    La Verne Ca.
    Re: Smoker Project
    Finished up the base frame with forklift sleeves and got the drum mounted to it. Laid out the doors and cut them in and then mounted on the hinge.
    My son was there today to help and I had him plasma cut most of the doors, this was the first time that he got to use it much and he sure enjoyed it.
    Included some artistic photos as well hope you like um.
    Me welding on the hinges.
    My son cleaning up the top cut of the doors before we mounted the hinge.
    Me finishing up the hinges.
    My son during final cuts for the doors.
    Thanks for looking,
    Ken
    Mar 2009
    upland, ca
    Re: Smoker Project
    EXCELLENT PHOTOGRAPHY!!!
    I love the "landing feet" definitely filing that one away for future references. How are the legs adjustable? I see that you have a telescoping square tube inside, but am confused on how the extended portion is fixed? Through Pin and holes every inch on the inner tubing?
    Jun 2005
    La Verne Ca.
    Re: Smoker Project
    Thank you,
    The legs are 2-1/2" perforated tubing nested inside of 3" tube. I have a temporary bolt holding them know for the build process. The pins just showed up today but I probably wont put them in until the end. If you look at the pictures with the drum mounted on the stand about 1-1/2" up from the leg bottom you will see the temp bolt. That's were the pin will live, and we can just pull them out when placing the smoker and the leg will fall out to the level that we want and then replace the pin. The closeup photos of the feet were earlier and the whole in the 3" tube wasn't drilled yet.
    May 2012
    Re: Smoker Project
    Jan 2012
    Lexington, SC
    Re: Smoker Project
    Whats the drum itself made from? Pipe or rolled sheet?
    Hobart Airforce 625 plasma cutter.
    Snapon MM140sl Mig/Tig welder
    Nov 2008
    Baton Rouge LA
    Re: Smoker Project
    wow, that is big. Great job.
    Thanks for the great pics!
    MillerMatic 212, Lincoln Precision TIG 225, Hypertherm 45XP
    Jun 2005
    La Verne Ca.
    Re: Smoker Project
    Jonboy, The drum is made of 1/4" rolled steel.
    Thanks kaos.
    Got the counter balance's mounted up today. Hopefully I will start the shelves tomorrow and I will post up some more pics then.
    Dec 2011
    Re: Smoker Project
    Quote Originally Posted by KGIOR View Post
    Thanks kaos.
    Where will the firebox be mounted? If you mount it on one side you need to create some internal flue system for distributing the hot gases evenly underneath the food. . otherwise what happens is the hot gas pours up one side, then forms a pool in the top of the unit. you end up with a small hot spot on that side of the cooker and don't get good convection. That tends to be a problem with with cheap offset-style grills you'll find at hardware stores.
    May 2010
    use to be Lake Elsinore, Ca now Clarksville Tn
    Re: Smoker Project
    Was that plate rolled local to you or was it ordered in? Nice job would like to come up and see that in person, also like the landing feet nice job on those.
    Ron
    Jun 2005
    La Verne Ca.
    Re: Smoker Project
    Josh: Yes the firebox will be at one end with the stacks at the other. I have a couple ideas for distributing the heat more evenly if I can get them worked out before it goes otherwise I will have to adjust after this season.
    Ron: I had it rolled to size at Pattons Steel in Ontario. More then welcome to come see it if your are in the area. It has to be completed next week and then will be gone for most of the summer then will be back after that.
    Ken
    May 2010
    Re: Smoker Project
    I might not make it in that time frame, I will probably make to pattons myself onTuesday but wont have the time to make it the rest of the way, I'll hold my breath till the end of summer. I know the San Bernardino store for Patton rolled but didnt think Ontario did, and meant to ask when I was there Thursday and didnt oh well. Thanks for the info.
    Jul 2011
    Saskatchewan, Canada, (right above North Dakota and Montana)
    Re: Smoker Project
    Nice smoker! Pardon me, but where is your guard for that angle grinder, thats how my boss knocked his two front teeth out, his grinder kicked back and boom no tops anymore. And I have had a grinder kick and hit me in the stomach, no guard and nice little scar about 3 inches long and 1/4" deep.
    Jun 2005
    La Verne Ca.
    Re: Smoker Project
    Ron, the rolling is new at Ontario. They rearranged the yard several months back and added the rolling section at the far end, away from the office.
    Thanks Malitia, That's actually a cutting wheel which I am always concerned about coming apart. I can never seem to get grinders into the places that I need with the guards on, I no it's not ideal but I actually use low power grinder for that reason.
    Jan 2010
    Mobile, Alabama
    Re: Smoker Project
    The first thing I thought of when I saw your smoker... a rotisserie smoker!
    If you dont have definite plans yet, look up "reverse flow smoker" plans. The design has several advantages that are worth considering for this large of a smoker.
    Jul 2011
    Re: Smoker Project
    The cutting disc are worse lol, they explode from time to time, thinner is worse. Ever seen air sanding disc explode, I will be in at work tomorrow, I will take pics of the sanding disc that is still emmbedded into the ceiling, which is sheeted with half inch plywood, safety safety, trust me, I have had enough close calls, I should be dead!
    Jun 2005
    La Verne Ca.
    Re: Smoker Project
    Progress so far.
Page generated in 1,627,454,711.99265 seconds with 12 queries
