Results 1 to 5 of 5
Thread: TWECO 211i - can't vary speed???
    Jun 2011
    Texas
    I just installed a 1 lb. spool of Lincoln .035 fluxcore (MR-211) in my new 211i, and all seems to work well. I didn't weld with it, just got the wire running through it and made sure the tensions weren't set too tight. What jumped out at me was that I can NOT seem to vary the speed. I turn the wire speed adjustment up and down between 100 and 600, and it just keeps coming out at the same speed (not sure what that speed is). Everything looks good, connections are good, etc. Stick mode is wonderful. Any tips? Please tell me this machine isn't broken!!!
    Thanks,
    -Ruark
    "Become one with the puddle, grasshopper" - Welding Instructor
    Lincoln 3200HD
    Hobart Stickmate LX235
    TWECO Fabricator 211i
    Feb 2009
    Chicago
    Re: TWECO 211i - can't vary speed???
    Weld with it. After the puddle starts it ramps up. If that doesn't happen you have an issue
    Hypertherm Powermax45
    Esab ET220i
    Razorweld 195 Mig
    Razorweld 200ac/dc Tig
    Tormach 770, Tormach xstech
    Razorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
    Jun 2011
    Texas
    I'm told the 2T/4T feature doesn't kick on until a puddle's started. So maybe it's the same with the wire speed.......? Are most wire welders that way?
    -Ruark
    Lincoln 3200HD
    I'm told wire feed speed isn't accurate until you begin welding.
    Everlast PowerMTS 211Si
    Dec 2011
    Not sure if the above comments are right or wrong. The 211 has a run in feature that brings the wire speed up once the arc is established. On mine if I hit the trigger......not welding.......the wire comes out slow for about 6" or so then will go the speed.
Page generated in 1,634,840,981.87701 seconds with 13 queries
