Page 104 of 104 FirstFirst ... 45494102103104
Results 2,576 to 2,599 of 2599
Thread: Welding Fail! post pics here.
  1. #2576
    Jan 2009
    Sonoma County
    Re: Welding Fail! post pics here.
    Quote Originally Posted by Roert42 View Post
    I'll post my first project. Attached some panels cut out of a rusty refrigerator to a rusty mower deck
    That was a few years ago, my friend still uses the mower.
    Hey that's not a fail! Crude, yes, but a first-ever project that restores functionality and it's still running years later is a win!
    We're not all pros here. My farm repairs are mostly, equally simple. (But mostly on heavier material). Everything I've ever welded in 20 years has stayed welded.
    My welds have gotten prettier, but even the earliest ones were sufficient for their purpose.
    HF MIG-180 with all the mods.
    Grizzly H8153 Stick/Tig Pulse 130/160.
    Wards PowrKraft AC-230. Stick & carbon arc.
  2. #2577
    Southern California
    A not so pretty weld that holds for the life of the repaired item is a win to me!
    I hate a to call a perfectly good working weld UGLY, haha.
  3. #2578
    Oct 2019
    Australia
    I just finished browsing the entire thread, some very interesting attempts, even learned a few things.
    I'll post my first project. Attached some panels cut out of a rusty refrigerator to a rusty mower deck to cover some holes. Used a no name 120 stick welder with only a high low switch on the front, using 1/16 6013. The only way I could get it to run was to drag the rod across the deck towards the patch, by the time I got there the rod was hot enough it would stay lit. There is a few spots where he metal was so thin I kept blowing out, just kept welding onto the edge until I found something solid.
    Attachment 1729886
    Attachment 1729885
    Attachment 1729887
    Grunge or rat mower. Cool.
  4. Likes 12V71, Roert42 liked this post
  5. #2579
    John Beer.... I like it.
    Cut 50 Plasma
  6. Likes Roert42 liked this post
  7. #2580
    Jan 2009
    Sonoma County
    I see WeldingWeb won't allow re-post of a photo posted previously, so I'll just link to where it was posted.
    Narrow trenching shovel repaired.
    That weld screams 'amateur'. It was one of my early projects with the $72 HF 90A-AC flux welder that was my first 'upgrade' from my big AC stick welder. (I'm now two mig welders later. That HF welder was near useless, it was a poor tool to learn wire welding on).
    Ugly weld, yes. But I've used that shovel interchangeably with an undamaged one for nearly a decade now and the weld has held up. 'Good enough for the girls I go with!'
  8. Likes whtbaron liked this post
  9. #2581
    Looks like tank
    Attachment 1729886
    Attachment 1729885
    Attachment 1729887
  10. #2582
    Aug 2012
    AR
    Roert42, I think you did d*mn good on your patch job, but one critique....the "N" in John is backwards.......
  11. #2583
    Apr 2016
    CA
    Perhaps from drinking too much John Beer
  12. Likes whtbaron liked this post
  13. #2584
    Aug 2009
    Philomath, OR
    Saw this on a safety stand at my local Harbor Freight:
    Miller Dynasty 200 DX
    BuildPro TMA52238 (38" x 22")
    Miller MP-10 & Jackson Nexgen EQC
    20 Ton Press & Swag HD Press Brake
  14. Likes California, John Baptist liked this post
  15. #2585
    Jun 2008
    Crap that's scary. What would ever happen if someone used that to hold up a car for instance and it broke and killed someone? Would HF be responsible as the distributor? I'm thinking yes
    Is that actually the 'weld' side or is it suckback from welding on the other side?.............Mike
  16. Likes dhem liked this post
  17. #2586
    May 2011
    That's why I dont buy much from HF. I like their gloves, air nozzles (which break or get stolen anyways) and moving blankets, that's about it
  18. Likes dhem, VaughnT liked this post
  19. #2587
    Jan 2009
    Sonoma County
    Harbor Freight! Where final quality control is left for the customer to figure out. It saves HF some money. "Some Assembly Required" seems to mean you need to inspect everything before use.
    Notice they accept customer returns with no resistance. The clerks probably see stuff that doesn't meet spec, all the time.
    I've returned things for refund occasionally. The most blatant example of something not meeting spec was the '200 lb' plastic furniture dolly. I stepped on it , 180 lbs, broke it in half. Took it back and got the refund. Then went and stepped on and broke two more that were in stock, to illustrate the problem.
    Similar, the ratchet in the $7.99 socket set stripped with moderate pressure. I was under the tractor on my hands and knees pushing on the handle, not a position where I could apply much force. They smiled and gave me a whole new set. Stripped that, soon. Another new set provided. When I stripped that third ratchet I substituted a Taiwan no-name ratchet into the set and haven't had a problem since. This cheap set is left in the open for casual use where it's a nuisance to go get my locked up good tools, Craftsman, Thorsen, etc. HF should never have included a set of 1/2" sockets along with a 3/8" size ratchet.
  20. Likes dhem liked this post
  21. #2588
    Looks like Harbor Frieght welding.
    Any time buy from Harbor Freight there some redoing.
    That is why I posted a redo on (welder 170) I purchased from HF.
    Quote Originally Posted by dhem View Post
  22. Likes dhem, John Baptist liked this post
  23. #2589
    Jan 2008
    Richmond, Virginia
    Not sure if this a welding fail or not, as we don't get to see the final weld. Watch to the end!
    https://www.reddit.com/r/Welding/com...dford_england/
    or: https://www.facebook.com/watch/?v=272402127763410
    it's on youtube as well.
    Syncrowave 250 w/ Coolmate 3
    Dialarc 250, Idealarc 250
    SP-175 +
    Lincwelder AC180C (1952)
    Victor & Smith O/A torches
    Miller spot welder
  24. Likes Brazin liked this post
  25. #2590
    Feb 2016
    Oregon
    Well, no matter how you slice it, that's definitely a FAIL. Hope they have insurance.
  26. #2591
    Nov 2014
    PDX PNW
    OopsName:  20210825_090157.jpg
Size:  102.4 KBgot a mask I that got burned too a while back. I was going to use this tmstuff for Halloween
  27. Likes Shootr, whtbaron liked this post
  28. #2592
    Arizona
    I feel your pain - left the tv remote on top of the forge...
    Yeswelder MIG-205DS
  29. Likes jay gill, whtbaron, VaughnT liked this post
  30. #2593
    Aug 2009
    Philomath, OR
    Saw some good welds on the floor model Husky "Heavy Duty Industrial" shelving unit at my local Home depot:
  31. #2594
    Jan 2009
    Sonoma County
    I've said several times that HF's 90 amp AC "Mig" flux welders must be the export version of what's used in China for the crappy welds you find underneath furniture from Target, Walmart, etc.
    Looks like this shelving was fabricated using that model welder. I too got results like these photos, trying to use the HF AC welder long ago before I bought better gear. The splatter is the give-away of AC welding.
  32. #2595
    Mount Tabor VT
    Quote Originally Posted by California View Post
    I believe you are mistaken.
    I walked into the maintenance shop of an industrial facility. A box lay on the table, it looked like Hellen Keller welded it. The story was only one welding helmet was available. The helper used the helmet to position the pieces, the welder closed his eyes to weld. I wish I had been there to witness it!
  33. #2596
    Jan 2009
    Sonoma County
    Well he tried.
    Here's where the photo came from but there's no explanation of Why.
    https://www.reddit.com/r/pics/commen..._till_you_sea/
  34. #2597
    Well... if it's just ornamental it's not too serious... can't say it adds to the visual appeal though...
    Cut 50 Plasma
    Mar 2021
    Near Roanoke, VA
    I wish I knew where I could get a large steel sphere,,
    I would build that in a heartbeat, and add it to my driveway entrance,,,
  36. Likes whtbaron, robocow liked this post
  37. #2599
    Mar 2008
    Georgetown, Texas
    You can get them from King Architectural Metals.
  38. Likes Brazin liked this post
Page generated in 1,632,741,622.04265 seconds with 13 queries
