Hi, complete noob here. I need to make a resealable pressure vessel for casting resins, and need some info / oppinions before blowing myself up! :blob2:
I won't be doing any of the making, a friend of mine is an experienced welder, and he's experienced at making air tanks as such, but is a bit unsure about making a resealable system. SO trying to gather info to make sure a) it's doable, and b) it's done safely.
Basic info:
- pressure will be no more than 50psi, more likely 30-40psi. Regulator etc will be in place.
- needs to be long but thin; about 1200mm long, maybe 100mm diameter.
- need to open one end to insert and remove the piece being cast.
My uneducated thought was to get a thick-walled steel tube, weld plate over one end, weld a flange to the other, and then use high-tension bolts to secure the removable plate to the flange (sandwiching a gasket). And possibly encase the body of the tube in reinforced concrete just in case...?
Any problems or tips people can point out? I've been searching the web for weeks, but most results are dealing with pressure of over 300psi, and not recommended as DIY.
The chamber would essentially be a longer, narrower version of the pressure pot listed here: http://www.hobbyengineering.com/H4139.html
PS. I'm generally more savvy than I may sound here. I do know the very real risks of working with pressure, hence being a bit cautious about the whole idea. I just don't know if 50psi is considered child's-play as far as pressure is concerened. (I know car tyres are usually around 30-40psi, so a properly engineered chamber shouldn't be too difficult...)
Basic info:
