Results 1 to 15 of 15
Thread: How much current should use?
    Sep 2007
    I want to weld a 12mm thick by arc welding and using size 10 or size 12 electrode. How much the recommended current shoud i use?
    Mar 2006
    Arizona
    Re: How much current should use?
    I wonder what it is that you might be welding?
    mild steel
    pipe
    plate
    cast iron
    aluminum
    stainless
    titanium
    I wonder what you are welding it to?
    I wonder if it's load bearing, like a bridge column or maybe a trailer, or could it be a lamp shade holder?
    More info would help.
    What type of electrode? Is it AC or DC?
    Lincoln AC225 stick welder
    Lincoln HD100 WeldPak flux core wire feed welder
    Three of the cheapest grinders money can buy
    Cassville, Missouri
    What he said plus what's a size 10 or 12 electrode? Is this same strange code like 10 being 10/64ths?
    May 2007
    Washington
    What on earth is size 10/12 electrode???
    Feb 2007
    Hamlin NY
    It can't be 12 mm plate and a 10mm (.400") rod.
    3/8" =.375"
    David
    Real world weldin.
    May 2007
    Washington
    Oh, I must have missed the mm part.
    Dec 2005
    Georgia
    "What we've got here is failure to communicate"
    Washman
    Sep 2007
    is welding 12mm thick mild steel plates.
    Jul 2007
    New Mexico
    Not enough info but in the US we use a rule of thumb that says the dia of the rod in thousands of an inch is the number of amps. So a 1/8" = 0.125" would be about 125A. I think this works out to about 4A per mm. This rule is only a rough guide and the dia refers to the dia of the steel rod inside the stick
    355# Hay Budden
    3# Hofi Hammer
    Propane Forge
    Idealarc TIG 300/300
    AllStates Oxy Propane torch
    Smith Little Torch
    Feb 2007
    Hamlin NY
    40 amps per mm thickness. 1mm = .039something inches.
    The rule of thumb is for one pass welding. Multi pass you can go less and it depends on the diameter of the wire part of the rod and what kind it is.
    Which brings me to another rule of thumb (put thumb smily here)
    .001 " for one amp works for rod size too. 1/8" rod AROUND 125 amps. Or 40 amps per mm of rod.
    That is why I asked about 10 mm? rods. 400 amps?
    David
    Real world weldin.
    Aug 2007
    Manassas, VA
    Yea yea yea....
    12mm thick lamp shade
    yea yea yea
    I vote for that!
    Don't talk about it, Just do it!
    Jul 2007
    New Mexico
    Quote Originally Posted by David R
    David
    Yeah thats right. My mistake
    355# Hay Budden
    3# Hofi Hammer
    Propane Forge
    Smith Little Torch
    Sep 2007
    electrode size 10 = eldectorde diameter 2.0mm
    electrode size 12 = electrode diameter 2.6mm
    Sep 2007
    Feb 2007
    Hamlin NY
    So 2.0 mm start at 80 amps. 2.6 104 amps.
    These are only recommendations. You may have to turn it up or down depending on the type of electrode you are using.
    David
    Real world weldin.
Page generated in 1,638,398,414.50724 seconds with 11 queries
