I have interest in Bore welding and have been doing these repairs for years. Reason for this thread is, Bore welders in general. I recently have purchased my second bore welder. The first was probably 10 to 13 years ago, seems like forever. This was Bore Repairs Boa, at that time it was the only model available, I can't recall the number but it was an early model. I have always had great luck in the shop with shop electricity, in the field this was a wreck. I was running the welder off of a trailblazer 250 with a LN25 feeder. I never did figure out the problem with stubbing. None the less, this means welding the bore over again, (after machining out the crap weld). I could run this bore welder off of my shop master 300 (Miller) with the (Lincoln) LN25 in the shop and never miss a beat. Only problem, my work is in the field. Long story short, after (re) welding bores in the field, I just did them by hand. Never a screw up, or much of one. This machine was sold at auction do to a divorce and I have to say I was happy to see it go. Todays update. With the ever increasing competition with Caterpillar and John Deere shops, plus a few others wanting on the band wagon in my area, I have been forced to nut up again and look at Bore welders. Now folks this is the truth, I call on Bore Repairs salesman as well as Bore Techs sales man, Climax just sells boretech. Set up a Demo to run off of a low hour Miller 302 trailblazer. I was skeptical as to a bore welder running with good quality welds off of a engine driven welder. Both sales men show up, promise the world, (the same day, same time) and not one of four machines will weld decent off of this newer 302 Trailblazer. Imagine that.... well I have to admit, I already had lots of these problems and was very skeptical as to what would happen. Although the salesman said this was a first (they always weld correct). I wasn't sure if I was getting smoke pumped up my butt. I opted to wait and think about it. Back to TODAY, low and behold, I purchased the same machine (newer version) 308I basic and anxiously await. I have opted to no longer try to run a bore welder off a engine driven machine. I have came to the conclusion that I can safely run the Miller XMT 350 at around 17 to 19 volts off of the Miller 302 trail blazer for bore welding. Most bores should only take around 20 to 30 minutes to weld. (duty cycle concerns). Maybe this seems to be the extreme, but fellas, and gals, nothing worse than having to weld a bore over because of poor performance. (stubbing, sticking, can't pick the weld up in the exact same place). It would be nice if I could always do these repairs in house, but 99% of my work is in the field. Its sad to say, but I threw big bucks away when the first bore welder sold for $300.00 at auction,and the replacement was $6300.00. I did mention to the salesman that I no longer desired to run it off of an engine driven welder, just the inverter of an engine driven welder. Even though he lives a great distance a way, I was sure I could look him up. I hope these changes will reflect into a operational bore welder, with many satisfactory welds.
Now folks, I do not proclaim to be a wizard or really want to be for that matter, I would just like some (field) bore welds that are satisfactory.
Questions are,
Has any one here welded bores by hand or mechanically?
In the field?
Bore welder manufacture?
Pros and cons?
Congrats to the folks welding by hand.
Any info on mechanical bore welding (in the field) shop also will be greatly used (over and over)
Thanks in advance for your input, it is appreciated
John
Questions are,
In the field?
Pros and cons?
John
