Results 1 to 5 of 5
Thread: Snowmobile track swap
    Sep 2007
    Mesick Michigan
    So if i understand this right i have to remove the drive clutch, undo the speedo meter, then take the drive chain and gears out, drop the skid with the 4 bolts on the tunnel and then slide the drive shaft out towards the left till it drops out. Is that correct. Then just reverse the process to install new track.
    --Gol'
    Jun 2005
    Re: Snowmobile track swap
    Zap...
    where are you?
    My Babies:
    HF Drill press
    HF Pipe Bender
    3 4.5" Black and Decker angle grinders
    Lincoln Electric PROMIG 175
    thatīs it!
    Jan 2006
    In A Nice Comfy Chair
    Could'nt tell ya..
    I've never done it..
    But Marc has..
    ...zap!
    I am not completely insane..
    Some parts are missing
    Do not attempt.
    Oct 2007
    the clutch should be on a parallel shaft, u shouldnt need to remove that
    -Nate
    Miller Trailblazer 302g
    Miller Spoolmatic 30a
    LN-25 x 2
    Idealarc SP200
    Hypertherm Powermax 600
    Sep 2007
    Mesick Michigan
    I got it all swapped out. Now i have a good track on my 01 xcr 800 triple.
    --Gol'
Page generated in 1,713,263,484.60105 seconds with 18 queries
