Results 1 to 6 of 6
Thread: cutmaster 81 question
    Aug 2010
    West Central Ohio
    Can a Thermal Dynamics CM81 that is listed 460 volt be wired to run on 230 volts? The reason I ask is when I look at the diagram , the input is listed 460 3 phase and 230 1 phase. I will try to link the manual here for anyone who wants to check it out.
    Turns out I don't know how to post a link
    victortechnologies.com/IM_Uploads/.../lit_460_300X2957.pdf
    Apr 2008
    NW ON Canada
    Re: cutmaster 81 question
    My CM 52 will run on 208v-460v single or 3 phase.
    I use it on 230v single phase.
    Jason
    Thermal Dynamics Cutmaster 52
    Miller Bobcat 250
    Torchmate CNC table
    Thermal Arc Hefty 2
    Ironworkers Local 720
    Feb 2010
    BA, AR
    Mauricio
    Jan 2005
    Look at your tag on the machine. You either get Single or Three phase but not both. There is a 460 volt single phase machine, but it will not run on 208/230 volts
    That's the way my 101 and 151 were built. Same family as the 81 machine.
    Esab/Lorch ET-220i
    Esab 160i caddy
    Thermal LM-200/ Lincoln feeders
    Thermal 95s
    Thermal 60i- 3phase /RPC powered
    Thermal Drag-gun 35C
    Thermal 15c
    INE 1500
    Klutch 140i
    Aug 2010
    West Central Ohio
    Not my machine, but seen on craigs list. I think that is the manual for the machine in question. All I know is the model number. I am refering to the diagram on page A-6 for the question I ask.Thanks
    Delaware
    The 81 is wired from the factory for one voltage and can not be changed by the owner. The 82 can be changed by the owner.
Page generated in 1,638,198,236.79002 seconds with 11 queries
