Results 26 to 50 of 61
Thread: Homemade Can Crusher
    Jan 2006
    In A Nice Comfy Chair
    Re: Homemade Can Crusher
    Quote Originally Posted by Go1lum View Post
    Wouldn't be doing that if you lived in Michigan.
    Or Mass.
    ...zap!
    I am not completely insane..
    Some parts are missing
    Do not attempt.
    Oct 2007
    central michigan
    or you can get a steel one on sale at harbor freight for $5.00. but not nearly as much fun.
    Mar 2008
    Pinokio Land and blue feri
    that is a can crusher monster edition... good recycle horror...
    Aug 2007
    Here is one that I built that is fully automated. The only thing it doesn't do is drive the cans to the recycling center.
    Link to the vacuum extraction system:
    http://designnews.com/article/CA6478...dustryid=43664
    Link the the crusher:
    http://designnews.com/article/CA6328...dustryid=43664
    Here is a description:
    This was a fun project but it requires a lot of time and skill in several disciplines. The design could be simplified significantly, but it would lack the "gee whiz" factor. Having more than one remote station requires a method to control the path of air flow. I wanted to make it fully automated so each station has an optical sensor, door position switch and a pneumatically actuated air flow control door. There are also 3 indicator lights and a mode switch on each remote panel. The can crusher unit can be seen in the gadget freak archives (#84). I chose 3" (3.5"O.D.) PVC electrical EMT for the vacuum tubing. For the run from the patio to the garage I used large radius metal EMT elbows to give a faster overall velocity (the can averages about 70 MPH for the trip). For the run inside the garage I have the tubing runs around 3 walls to make it from my work bench to the crusher for effect. I could have made it diagonal but that wouldn''t have been as fun. Because I wanted the tubing as close to the walls as practical, I used 3" DWV, large radius, ABS elbows. The radius is a lot tighter than the metal elbows but the cans make the turns with no problem with a bang at each turn. You can follow the can around the walls from the banging at each turn. This slowed the velocity to about a 50 MPH average. The 2 runs are joined together right above the crusher entrance using an ABS DWV ''wye'' connection. The vacuum line enters below where the 2 runs are joined using a ''wye'' connection that is a straight 3" feedthrough with a 2" branch. The 2" tubing penetrates the garage wall directly opposite from my air compressor shed which allowed me to put the blower in the shed to reduce the noise to almost nothing. I used a Harbor Freight dust collector for the vacuum source. I added a SSR to be able to control the power to it. I also fabricated a butterfly valve in a section of 3" EMT which has a pneumatic actuator to rapidly control the application or removal of vacuum the the system. The butterfly valve is connected to the inlet port of the blower and reduced down to 2" for the wall penetration. Right below where the 2" vacuum line joins the tubing is the flow control door the can exits the vacuum tubing and enters the can crusher. The flow control door on the exit was necessary to keep maximum flow in the tubung until the last possible moment. Having the system under the control of the MCU makes it really simple for the operator. All the operator does is flip a toggle switch on the remote panel, open the access door, insert the can and close the door. The indicator lights show when the job is done (approx 1.5 seconds). The actual sequence of events goes like this: When the toggle switch is flipped to one of the 2 modes, the MCU starts the blower, opens the air supply valve feeding the surge tank on the crusher and gives a green ready light on the panel. When an access door is opened, the MCU turns off the ready light and turns on the ''door open'' light. At this point when the can is dropped in, the optical sensor tells the MCU which remote station has a can in it. When the access door is closed, the MCU opens the butterfly valve to depressurize the vacuum tubing and opens the flow control door on the remote station to allow the air (and hence the can) to flow towards the can crusher. The MCU waits for the optical "arrival" sensor to be triggered by the can passing at which point the MCU opens the exit door and closes the vacuum butterfly valve and the can coasts the last 6 feet under it''s own momentum. The can drops into the crusher''s magazine and it''s sensors and actuators finish off the can which then drops into the trash bag in a holder right below the exit of the crushing ram. The can crusher magazine is made from a large radius EMT elbow and a short section of straight tubing. The magazine has 2 small rams in the vertical section to sequence the loading ogf the cans into the breech of the crushing cylinder. The sequencer alows a user to feed cans in one right after the other in the ''multi'' mode. That way, if you have a bag of cans to be processed, you don''t have to wait for each can to be finished befor inserting the next one. When ''multi'' mode is selected on the remote panel, the MCU leaves the flow control door open on the station and the user feeds the cans in through it instead of opening and closing the access door each time. There is a lot of smarts built in to the software for things like sensor failure, access doors opened when they shouldn''t be, can stuck in the crushing exit ETC. Ther is an LCD on the control module on the crusher that reads out diagnostic messages to tell me if something isn''t working like an optical sensor failure ETC. I have 2 toggle switches on the control module for maintence so I can turn the blower on, excercise the actuators ETC. All in all there are 7 optical sensors, 2 micro switches, 7 rams with 7 solenoid valves (8 coils), 5 toggle switches, a main air supply valve, RS232 port, programming port, LCD display and a solid state relay. The 40 pin MCU has only 1 I/O port left. As I said, it could be simplified a lot but it wouldn''t have been as fun to build or operate. I wanted to make the can travel as fast as possible so a lot of features went into that effort. Cheers, Ed
  5. #30
    Sep 2006
    Nice!!! I drink too much beer (so I'm told), but that outfit is a bit over kill for me. Looks like it was a hoot to build though, and watch.
    o.c.d.
  6. #31
    Mar 2008
    Missauga, Ontario, Canada
    hahah awesome .. way to go green
  7. #32
    Sep 2007
    Would you please post a shop drawing of your heavy duty can crusher. The photos are nice, but do not show dimensions.
    Keep up the good work.
    hturner781
  8. #33
    Jul 2009
    I want to know exactly you did it, because I got mine online and I'm not sure if it's working perfectly. Has anyone of you tried this?
    http://www.thehardwarecity.com/?sku=2436731
  9. #34
    Feb 2009
    Australia
    I got a 40 ton press, whack em in there and it's flat as a dime when it comes out !!
    Now THAT'S overkill
  10. #35
    Jan 2008
    Arkansas
    Cool!
    A butterfly without wings,
    is just an ugly bug
  11. #36
    Apr 2009
    Tucson, AZ
    Geez .... and here I used to drop the head of a 20-pound sledgehammer on my recycled cans just to avoid stomping 'em ..... nice work, pretty overkill, but nice nonetheless.
  12. #37
    Aug 2009
    Great job you got here. However, I have a faster solution, to get a can crusher online. Less hassle.
  13. #38
    Dec 2006
    That would be a major engineering feat for me.
    $300 can crusher
    I just dump'em out on my driveway and run over'em a few times with my truck
  14. #39
    Jul 2009
    Sugar Land Texas/ NY harbor
    Shoot, I gotta get glasses maybe, I thought the title of the thread was.......
    Homemade Car Crusher. I think that would be up to the task.
    What goes around, comes around.
  15. #40
    Nov 2008
    Lincoln, Ne.
    Don't think that's gonna wear out any time soon! Nice job.
    (Retired) Professional firefighter, amateur everything else I try to do...
    Oh yeah: Go Big Red! (You know: one of the 12 members of the Big 10 cuz we left the 10 members of the Big 12...)
  16. #41
    Jun 2009
    Arkansas
    Dude! Awsome! You are a pro! But man I paid $6 @harbor frieght for a can crusher. But I really admire your pro effort! You ought to build a experimental plane! You'll enjoy that!
    Nice work!
  17. #42
    Redwood Falls, Minnesota
    Wow, that is one that will never break or wear out. Will last forever.
    Welder- Miller Thunderbolt AC 225-DC 150
    Plasma cutter, Miller Spectrum 300
    O/P torch- Victor 100
  18. #43
    Sep 2011
    I was looking for a project for my students, this one looks great. Does anyone know the dimensions of the pieces to cut out?
    That would be a great help.
    thanks in advance
  19. #44
    Texas
    Nice. Something else I think I need.
    We are on our way to being farmers! Our site is always under construction so check back often for updates.
    http://www.philosophyfarmstyle.com/
  20. #45
    Sep 2011
    Woodsfield, Ohio
    Quote Originally Posted by agteacher View Post
    thanks in advance
    Yeah, it would be nice to have the dimensions, I might make some for Xmas gifts.
    This one is a copy of the Harbor Freight cheap one but will last. Plus he got the handle better and longer. Getting good compaction. You might look at my Magnum Dominator design too. Again that is a knock off design of one of the Harbor Freight ones, but miles better. All that Harbor Freight stuff is pure junk.
    The Dominator design is pure fun and you get that "sound of destruction". You feel the satisfaction.
    I've played around trying to design another one. The goal is better compaction. It appears the can can not be totally crushed in a manual type design because of the rim and keep a tight neat round foot print. You need massive amounts of force to do it brute force style. You want no jagged parts sticking out to cut the storage bags.
    The solution, might be to make a sort of die to accept the necked down top portion of the can, to deform the entire can into a smaller diameter, then have a round piston type ram come thru and basically blow the can thru itself. Probably going to take a fair amount of force to do it but far less than a total brute force method. The ram piston will be smaller diameter than the can to pass thru the die.
    I've tried experiments cutting the rim, dinking it, deforming, whatever but nothing works to get better compaction. They have designed the can well. So I plan to try to blow the rest of the can up into the rim area and fill it in with metal. Hopefully keeping maybe a smaller diameter final reject neat button of metal.
    Waiting for a guy to get me some pipe. Go bold and try to design something new. Gets tricky to make it simple to build but still perform to specs. This particular design here is good, simple and has decent performance. How to get good force multiplication can be another part of the problem. Then it has to have a decent cycle rate. Without spending a fortune. And it has to be practical with extreme long working life.
    For everyday, ho hum use, this is probably the best design. Tho it might be better with some type of auto reject feature. So many requirements.
    But also be careful around younger folks, these puppies can be dangerous critters, especially if they start sticking your hands in here to prove who is brave and who can "Take It". It will happen.
  21. #46
    Jun 2010
    raleigh nc
    what welder did you use to make it? How about to make the cuts? The holes for bearings?
    miller syncrowave 250
    hobart handler 140
    home made 400 amp engine driven in progress...
  22. #47
    Dec 2009
    Randle WA
    The OP hasn't been on here since 2009. As for AGteacher, I would have the students come up with dimensions. Have experiments to determine the force required to crush the can (linkage & handle length) and actually measuring the can and bearing for the rest. These are the skills that are missing in most of today's programs.
    Millermatic 200
    Hobart Handler 120
    Victor O/A & Ramco Bandsaw
    Lincoln 225 AC
    SnapOn AD Hood
    Miller XMT304/22A
    Hypertherm Powermax 1650 G3
    Lincoln Idealarc DC600 w/Extreme 12 VS
    Miller Digital Elite "Joker"
  23. #48
    Sep 2011
    Woodsfield, Ohio
    Yep, too many so called teaching programs hand out dumbed down projects. You didn't say the age of those involved.
    You actually can guessimate the dimensions by just putting the pixs into a drawing program and overlaying with dots / grid and scaling it off versus things shown that will have a known size as the starting point. That will get you well into the ball park.
    Then I would prototype in wood or even paste board to get a feel for the operation. So much easier, faster and can be modified a lot of times. Nothing like a working prototype, the first one of everything is always a bit flawed. Go to metal once the production model is fully firmed up.
    Actually I would go bold and try to design something using pipe. Do the entire process from an idea stage. The only manual can crushers I've seen on the web that sort of impress me after building the one I did, are made from pipe. Most of those, probably can be improved. Probably less things to consider, easier to build. The trick is to get the really killer model. Lay out the specs hoped for before starting the project.
  24. #49
    Jan 2006
    A cool project for an ag class is to give them the picture and let them replicate it. They can go for an exact copy, equivalent, or a modified version.
  25. #50
    Nov 2014
    We have a 10 cents deposite on returnables. Machines have to be able to read the bar code.
    Only carbonated drinks have a deposit. There are many others such as juices that do not. Aluminum cans weigh very little and they take up ALOT of space unless you crush them.
Page generated in 1,713,295,159.15761 seconds with 18 queries
