Miller Maxstar STR 200 help
5.7K views 8 replies 3 participants last post by  Jim Marshall
Can anyone give me more information on the MAXSTAR STR other than the Miller propoganda? I had a hard time finding it on Miller's site because it is listed as a stick welder. I probably will use it more for TIG and wonder how versatile the unit is.
I have a unit and the contractor's kit.
Jim
#2 ·
It is a very good stick machine. It is a good TIG machine, but requires a torch with valve (unless it has been changed since the units shipped in august07). It does have lift arc. Picked up three units at work in august, and all three have done champion service. On 120V single phase, there are output limits on TIG like with stick, but not as low.
#3 ·
If you're intending to use the Maxstar 200 for TIG more than stick, why not buy the SD or DX model, which are both made specifically for TIG, instead of the STR model? Both have the gas valve and high frequency start already built in. The DX also has pulse, if you're into that.
#5 ·
Oh ok, sorry I didn't understand your situation clearly. I guess you could hook up an HF251D1 freq box if you want high freq start and internal gas valve and pre/post flow gas timers. Kinda expensive though...
#6 ·
Unless you have a real need for HF, don't worry about it. I use lift-arc as much or more than HF on my 150, and the 200 lift arc is pretty much the same. The main issue is using a torch with a valve on it, which a lot of people don't like. You need to be careful to be sure the flow is on before strikeing, and to shut the flow off after breaking. That's all. You can use a remote to cut the arc (on the stepping that I have used, at least), or pull off to break it and bring the torch back in for postflow (which takes a little practice, but works fine) A foot or hand switch is easy to set up.... the main expense is the connector. Hold the button, lift, weld, release the button to stop the arc. It may also have the 2-touch button setting (Never looked to see on the 200. The 150s have it), where you push-and-release once to enable the machine, touch and lift to start, weld, then push-and-release a second time to stop the arc. Handy occasionally, especially in awkward locations.
The Miller TIG torch that you will want is probably a variant of the DB17V (150 amp at 100% duty cycle, air cooled), or any equivelant. The 'V' in the Miller part number is the valved version.
